Fuel gauge sender
sub-hatchtim
sub-hatchtim is offline
PostPosted: Sun Apr 01, 2018 11:02 pm    Post subject: Fuel gauge sender Reply with quote
Trying to find a source for a new gauge sender that isn't a POS
I've been advised that the Wolfsburg West senders are garbage
Does anyone know of a quality sender that's being made today
(o\!/o)
ON-ON RU
58' pg/sg sub hatch westy
90' doka 1.6td jx import from germany soon to be a bew tdi
76 Porsche 911S
Bruce Amacker
Bruce Amacker is offline
PostPosted: Mon Apr 02, 2018 6:12 am    Post subject: Re: Fuel gauge sender Reply with quote
https://www.thesamba.com/vw/classifieds/detail.php?id=2086963
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Mon Apr 02, 2018 7:10 am    Post subject: Re: Fuel gauge sender Reply with quote
These work perfect!! I've done two so far and no complaints at all!
PeteSC
PeteSC is offline
PostPosted: Mon Apr 02, 2018 7:53 am    Post subject: Re: Fuel gauge sender Reply with quote
New VDO gauges of all lengths, made in Brazil:
https://www.egauges.com/category-s/33327.htm
I have the 280mm in my '58 KG....it works perfectly (the red crimp shield has been corrected and is now heat-shrinked Wink ).
BarryL Premium Member
BarryL is offline
PostPosted: Mon Apr 02, 2018 9:21 am    Post subject: Re: Fuel gauge sender Reply with quote
Measuring an original German VDO it came out to this one https://www.egauges.com/7-5-190mm-90-0-Ohms-p/224-219.htm
I have two on order there but they guy said they are back ordered. Should I change to 280mm?
PeteSC
PeteSC is offline
PostPosted: Mon Apr 02, 2018 9:26 am    Post subject: Re: Fuel gauge sender Reply with quote
No! Donít change your order....get whichever fits your tank. I only mentioned mine as a reference to almost any length being available depending on the tank depth.
sub-hatchtim
PostPosted: Mon Apr 02, 2018 1:46 pm    Post subject: Re: Fuel gauge sender Reply with quote
Thanks Bruce just ordered one, your helpful replies are very appreciated
(o\!/o)
ON-ON RU
76 Porsche 911S
Nubby
Nubby is offline
PostPosted: Mon Apr 02, 2018 8:23 pm    Post subject: Re: Fuel gauge sender Reply with quote
Did you order one from egauges?
BarryL is offline
PostPosted: Tue Apr 03, 2018 11:29 am    Post subject: Re: Fuel gauge sender Reply with quote
sub-hatchtim I hope you didn't think I was steppin' on your thread.
Also I thought the link Bruce had posted was for only one used sender although now it appears to be new.
sub-hatchtim
PostPosted: Tue Apr 03, 2018 12:51 pm    Post subject: Re: Fuel gauge sender Reply with quote
Barry feel free step all over the thread you'd like, what you posted was helpful.
I ordered the one Bruce posted
(o\!/o)
ON-ON RU
76 Porsche 911S
velvetgreen
velvetgreen is offline
PostPosted: Tue Apr 03, 2018 2:41 pm    Post subject: Re: Fuel gauge sender Reply with quote
The sender out of my 65' bus measures in at about 7.25" or 18.5 cm's long
not sure how much the tanks changed over the years but that should give you an approximate idea
Bruce Amacker
PostPosted: Tue Apr 03, 2018 4:43 pm    Post subject: Re: Fuel gauge sender Reply with quote
Between my Ghia and two busses I have a whole pile of junk fuel senders as they take the same PN. Many of them work initially but the floats sink within a year. VDO senders have some kind of supply problem as they're getting scarce- maybe they're out of production?
Stick with VDO, they're the only ones I've had last.
'66 Deluxe Bus
'65 Standard Bus
Build threads:
PeteSC
PeteSC is offline
PostPosted: Wed Apr 04, 2018 5:42 am    Post subject: Re: Fuel gauge sender Reply with quote
If you don't mind please keep us posted if egauges comes through with the backorder. Looking at VDO's site (link below) it doesn't appear that they list the 0-90 Ohm tube senders in their catalog anymore, so It'll be informative to see if egauges is able to get new stock.
https://www.vdo-gauges.com/sensors/fuel-level-sender.html
nlorntson Premium Member
Crazy VW Lady
nlorntson is offline
PostPosted: Wed Apr 04, 2018 6:16 am    Post subject: Re: Fuel gauge sender Reply with quote
Does anyone know how the egauges folks measure their gauges? Is it from the top of the mounting flange to the bottom of the sender or from the bottom of the mounting flange?
PeteSC
PeteSC is offline
PostPosted: Wed Apr 04, 2018 6:18 am    Post subject: Re: Fuel gauge sender Reply with quote
From the bottom of the flange (page 3 of instructions):
http://www.donssport.com/Instructions/VDO/TU00-0772-5107120_Tube_Type_Fuel_Sender_Instructions.pdf
BarryL is offline
PostPosted: Wed Apr 04, 2018 8:48 am    Post subject: Re: Fuel gauge sender Reply with quote
From ^^^^ what PeteSC said to the bottom of the center rod with threads on the bottom.
My two senders came last evening. Anyone want pictures?
sub-hatchtim
PostPosted: Wed Apr 04, 2018 10:12 am    Post subject: Re: Fuel gauge sender Reply with quote
Yeah Barry let's see them
(o\!/o)
ON-ON RU
76 Porsche 911S
BarryL is offline
PostPosted: Wed Apr 04, 2018 11:03 am    Post subject: Re: Fuel gauge sender Reply with quote
These are exactly 190mm or 7.5". You get two spades each for "ground" and "send". Nut on the bottom is built in I guess. I prefer cork but these have the red rubber. Anyone know how well the red works and how tight to tighten with it?
Don't forget to remove the tape and pull the pin.
PeteSC
PeteSC is offline
PostPosted: Wed Apr 04, 2018 1:48 pm    Post subject: Re: Fuel gauge sender Reply with quote
I've been using the red gasket for about 2 years with no issues. I don't have a torque setting, but it doesn't take much for a good seal. If you over tighten the rubber can start to break apart; it's very soft and tears easily.
velvetgreen
PostPosted: Fri Apr 06, 2018 7:39 am    Post subject: Re: Fuel gauge sender Reply with quote
Barry - thanks for pics of Fuel sender. Did you order this one?
or did you order it from another vendor?
