CaptainKingsmill Samba Member
Joined: March 25, 2018 Posts: 30 Location: Staffordshire
Posted: Mon Apr 02, 2018 7:18 am Post subject: 69 Bay Engine tear-down after overheating. |
Last weekend I posted about my 69 Bay which ran without oil and broke down,
Original Topic
https://www.thesamba.com/vw/forum/viewtopic.php?t=696633
So this weekend we've stripped it back to find out what exactly had broken.
Firstly, here is Betty in all her glory... and in working condition.
Bumper and engine plate removed.
and finally the engine out, which was as easy as expected.
as you can probably see, there are no heat exchangers on this bus, we knew this when we bought her and it was something i was planning on looking into.
So now that the engine is already out. I'll be fixing this.
Engine bay is a little dirty, so while the engine is out, that'll be completely cleaned
Firstly we took at look at the breather tube, which WillaimM pointed out was corrugated, and that this is bad.
Well it turned out to be worse than that! Not only was it corrugated inside, it was also not held on with anything, and was simply slotted over the cut existing hose... very poor, and very lazy whoever did this.
stripping off the ancillaries was also very easy, nothing bound or locked, which is probably due to the engines age, or lack of.
Back to long block, nothing untoward so far.
opening the sump and viewing the filter mesh it became very clear that something was very wrong.
Large chunks of metal shavings visible. oh dear.
The heads while in need of some TLC, all seem to have survived with only mild corrosion showing. the cylinders are all clean and clear from any marks. the pistons look okay from the top, with the exception of one, which is showing overheating
Most of the spark plugs looked okay, all had a degree of carbon however.
The exception was this one from chamber 4, which had some crap on it.
removing piston 4, all of the problems became visible.
it shows impact with something on the inside edge,
The view inside shows a that a bearing seems to have melted to the con rod, or shattered, causing the crank to seize,
it will rotate, but only through about 30degrees,
as a result, I am unable to remove 2 of the 4 pistons without cracking the case.
the last 2 photos, show the extent of the metal work within the case.
So, as you can see. quite significant damage to the one piston, the crank is also likely dead, and the case will need to be split, inspected, and polished to remove any marks caused by the metal being flung around.
with regards to my options.
it is possible to buy just piston heads? I only seem to be able to buy pistons AND cylinders.
Are they paired in such a way that you can only purchase them as a set??
My thinking is, the cheapest way to fix this, would be a new short block, and new pistons.
reuse existing heads and cylinders rebuild, and away we go!
second option would be a new long block, which obviously would be more expensive.
If I can only buy the pistons and cylinders as a set though, then there wouldn't be a worthwhile saving buying a short block and I may as well buy the long block.
Does anyone have any thoughts, on what they would do?
Thanks for your help so far. I've really enjoyed the process of learning this engine so far, looking forward to getting a new one and getting her working again. |
SGKent Samba Member
Posted: Mon Apr 02, 2018 7:39 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
you will need to inspect the case carefully. When a bearing gets hot enough to melt, then the case adjacent to that bearing gets hot too and it can warp. When this happens the case halves will not sit together properly causing the next build to fail also. Look at the color on the crank bearing that seized. If it is blued then the case may be no good.
The pistons have to fit to the cylinder at a specific clearance. They are matched at the factory. If you buy oversize pistons then a machine shop has to bore out the existing cylinders which may cost as much as new pistons and liners.
If it is a rod bearing that has seized, check carefully for a loose oil pickup. If you were low on oil or sucking in air that air usually exits on #2 rod. If it is #2 that is damaged consider that the engine was low on oil.
Also inspect the oil pump carefully. That much metal floating around may have scored the oil pump badly.
Do inspect each part until you understand why it failed. Do you have an oil pressure gauge on it? If so, what was it saying before it failed? How many miles are on the engine? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Apr 02, 2018 7:49 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
Ouch, looks rough. Thank you for sharing the carnage, it's good for the rest of the newbies here (me) to have a better understanding of what bad looks like, and how much metal would be in the sump plate. In my opinion, if you don't have someone to guide you through your first long block build, then I would buy a long block. I do not think you can buy just pistons without the cylinders (except in the classifieds maybe, actually my buddy here in Detroit would probably sell you just pistons. Let me know if you want his contact info), and I'm not super convinced you would want to. They need to fit together very well and if the new ones aren't made just right you will put excess stress/wear on your rings and pre-maturely wear them out. The performance engine/trans forum would have better knowledge of that though. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Apr 02, 2018 8:10 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
thats good advise all around- I have a set of oversize pistons -however- discovered the shops wanted $60 each to over bore them- and most wouldn't even take the job as they had no way of securing them in the machine- might have just been an excuse.
Noticed you have no stoppers in the fan shroud where the bright tubes are coming from. That would have bled cooling air from the motor and fed it to the j pipes- But if your going for new heater boxes that should solve that.
with out more cleaning and disassembly of the heads- they look suspicious- one spark plug hole may have a crack and the seats look a little deep to me on a few. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
SGKent Samba Member
Posted: Mon Apr 02, 2018 9:07 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
reviewing your photos, to me it looks like the clearances are so tight from a long stroke that the piston was hitting a crankshaft counterweight when it was at BDC. See if there is aluminum transfer onto the counterweight that piston connects to. Maybe the endplay got excessive so the crank moved into the piston. I don't know but that is one possibility, although the inspection will reveal what actually happened. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Mon Apr 02, 2018 10:45 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
Those J-pipes heat the heads. The holes in the fan housing need to be plugged (tennis balls work in a pinch). Heater boxes are cooled by the fan or the cores would melt. Also thicker cylinder walls are better than thinner, no boring.
Sorry about the mess, been there. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
cmonSTART Samba Member
Posted: Mon Apr 02, 2018 10:56 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
Ouch!
Sorry for your issues, but thanks for following up on your previous post! Good luck with the repairs - sure is a pretty bus! _________________ '78 Bus 2.0FI
de K1IGS |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Mon Apr 02, 2018 11:08 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
Most of your tin looks like aftermarket stuff, which lacks a lot of the correct air vanes and baffles. Looks like the wrong Type I tin used in the front and not the correct Type II tin with the extension.
If it's not cooling right that leads other systems to fail. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5994 Location: Brooklyn
Posted: Mon Apr 02, 2018 12:23 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
While you are working on this engine build do yourself a favor and source a correct VW fan housing. You have some aftermarket garbage on there now which certainly could lead to cooling problems.
A Bus being pushed around by that 1600 needs the stock cooling system in good working order.
Also source yourself a correct oil bath air cleaner. You'll be amazed how much better the Bus drives when you have the intake air preheat function of the stock air cleaner working as it was designed, especially in your climate.
You've got a lot of work ahead of you, sad to say. Do take SGKent's advice, this is not gonna be a "slap some new pistons and a new crank in and call it good" kinda job. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2736 Location: Hamble, Hampshire, UK
Posted: Mon Apr 02, 2018 12:58 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
You might find for instance that somebody has a complete set of secondhamd pistons and cylinders that were removed before an upgrade of the engine. Like I have a set of worn but usable 1641 pistons and cylinders sitting in a cardboard box. I do not want to throw them away but nor do I ever wamt to use them myself. They had new rings fitted but they did not improve.
Get some prpoerly fitting tinware and block the air ducts .. its probably why the oil light always flickered. .. my old engine had to get seriously hot to flicker the oil light at idle.
And a tinware seal.
Even if the case is damaged you might get lucky .. I picked up a rusted up semi water filled siezed engine for £51 and after a lot of cleaning up I had a case which has now run 19000 miles without reboring .. needed new bearings pistons ans cylinders amd recycled cylinder heads asfter lappjng in the valves. Total xost £600 but the pistons and cylinders were £250 of that ... almost used the old ones.[/code] _________________ Ancient vehicles and vessels
Posted: Mon Apr 02, 2018 2:13 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
Thank you all for your replies so far! Most appreciated.
I think, based on the advice, I'm going to go with a new long block, rather than try and salvage anything from this one.
I think it's the best option to avoid any future issues.
SGKent wrote: |
reviewing your photos, to me it looks like the clearances are so tight from a long stroke that the piston was hitting a crankshaft counterweight when it was at BDC. See if there is aluminum transfer onto the counterweight that piston connects to. Maybe the endplay got excessive so the crank moved into the piston. I don't know but that is one possibility, although the inspection will reveal what actually happened. |
I think you might be right, there does appear to be aluminium on on a counterweight, so it looks like this is where it has struck.
mikedjames wrote: |
Get some prpoerly fitting tinware and block the air ducts |
Volswagon wrote: |
The holes in the fan housing need to be plugged (tennis balls work in a pinch). Heater boxes are cooled by the fan or the cores would melt. |
williamM wrote: |
Noticed you have no stoppers in the fan shroud where the bright tubes are coming from. That would have bled cooling air from the motor and fed it to the j pipes- But if your going for new heater boxes that should solve that. |
it hadn't occured to me that the silver flexi pipe not being connected to anything would cause an issue,
Do these tubes connect to the heat exchanger?
If so, does that not cause similar issues diverting airflow away from the engine?
a few people have pointed out that the tin work is aftermarket and of poor quality,
Does anyone have an good quality image of original tin, or even a link to where I can buy some, I can't see much difference if any difference between my tin work and stuff I've seen online.
Could someone identify the part shown mounted to the wheel arch here, it looks like a relay of some kind, however it wasn't connected to anything, so I've got no idea what it was for.
Anyway, since the engine bay was empty, and I currently don't have a new engine to go back in, I thought i'd take the opportunity to clean up the engine bay.
Before
After
An incredible difference i'm sure you'll agree!
Lastly, I mentioned in the last post about the paneling the the top of the engine bay which can be seen in this last photo,
This looks like some kind of asbestos, and it's very warped and ideally, I'd like it gone.
I'm guessing since its asbestos, it's there as some kind of heat shield between the engine compartment and the cabin.
Is there something I can replace it with?
Thanks again for all your help so far. |
SGKent Samba Member
Posted: Mon Apr 02, 2018 2:22 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
Sometimes when a rod bearing fails the crank journal is so eaten away that the piston travels farther than it should and hits things.
Buying a long block is probably a good decision, ask around to find who is building the most reliable engines these days. You want something that will last 70,000 - 90,000 miles. Air cooled Buses & Vanagons are really hard on engines compared to any other air cooled VW. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
spanky324 Samba Member
Joined: September 28, 2006 Posts: 1070 Location: Greeley Pa
Posted: Mon Apr 02, 2018 2:29 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
Awesome Powdercoat sell nice tins! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21512 Location: Oklahoma City
Posted: Mon Apr 02, 2018 2:33 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
The square relay looking part you found is a voltage regulator for a stock type 4 style VW alternator. Ray |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Apr 02, 2018 2:50 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
raygreenwood wrote: |
Also for pre internally regulated type 1 alternators. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Apr 02, 2018 8:06 pm Post subject: Re: 69 Bay Engine tear-down after overheating. |
CaptainKingsmill wrote: |
Yes, those tubes connect to the heat exchangers.
No, that does not cause similar issues.
The heat exchangers get air from the fan housing all the time, regardless of whether the heat is off or on. When the heat is on, the heated air is piped into the cabin. When the heat is off, the heated air is dumped under the car.
The heat exchangers with air constantly flowing through them help to keep the heads cool. If you don't have heat exchangers then you need to plug those outlets on the fan housing or else you have an unrestricted outlet to waste a ton of your cooling air.
The stock VW fan housing was carefully designed and tested to maximize cooling. There are all kinds of intricate vanes and ducts inside (search this site, there are pics of one cut open). The aftermarket ones...not so much.
The VW cooling system works very well when it's all there but there are some critical elements. All the tin is critical. There are some seemingly minor but critical bits such as the "Hoover bit" (search it) and the little tins that snap in the bottoms of the cylinders. Put it this way: each bit of tin is there for a reason. VW could have saved a lot of money leaving tin off if it wasn't needed.
The whole cooling system is based on keeping the bottom side of the engine separated from the top side.
It is therefore critically important that all the tin around the engine is in place and also critically important that the rubber seal between the tin and the body is in place. If you can see the ground from inside the engine compartment, you have a problem that needs to be addressed.
Cool air enters the engine compartment from the vents at the rear of the body. That should be the only path for air to enter the engine compartment.
That cool air is taken in by the cooling fan and forced over the cylinders and heads and through the oil cooler, then ducted out under the car. Any path that allows that heated air to re-enter the engine compartment from below is bad news. _________________ 1965 Volkswagen 1500 Variant S
GBear29 Samba Member
Posted: Tue Apr 03, 2018 1:53 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
Before
After
Great clean up job on the engine bay. Looking forward to getting stuck in with the new long block once you’ve sourced it (I’m the friend who couldn’t fit one in my bag ).
Any of you guys in the UK have suggestions where we can get hold of some second hand original parts? Guessing there must be some specialist breakers yards for classic bus / bettle etc?
The more time I spend working on Betty the more I want to find a bus of my own...! |
Posted: Wed Apr 04, 2018 6:05 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
Hi all!
I've managed to source a reconditioned engine! Picking it up on Friday, planning to install it next weekend!
it's a 1600 to directly replace the one currently in.
The good news is, I've also managed to get a set of heat exchangers, i'm hoping that will go a long way to reducing the overheating issue.
This weekend, as if a new engine wasn't enough to contend with, I'm planning to rewire Betty.
The existing wiring is a mess, and realistically the only way i'm going to be able to get it back to a decent standard is to rip the lot out and start again!
I've got cable arriving on Friday.
I will of course try to take photos for you.
Wish me luck!!
also, If anyone knows, I could really do with an answer on the asbestos looking stuff in my previous post as I was hoping to get rid of that this weekend. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Wed Apr 04, 2018 7:30 am Post subject: Re: 69 Bay Engine tear-down after overheating. |
I don't know if the tarboards contain any asbestos, it's likely safe to assume they do to some degree just in case. I usually remove them during a job such as the one you are currently on and get them wet, then I lay them out on a concrete floor and lay a sheet of plywood on them with sand bags or other weights, in a few days to a week they are dry and ready for another 40+ years of sagging.
They don't do alot to stop heat, but they definitely soak up some sound, buses I've driven when they were removed were much louder back there. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
