FullFender Samba Member
Posted: Mon Apr 02, 2018 7:19 pm Post subject: I think I just screwed myself - Cracked Case |
Welp, kinda at a loss here.
Just rebuilt the top end of my Turbo 1915cc and put it in my bug.
I had finished installing the full flow before putting in. I was investigating a "small" oil leak today when I noticed a small crack right above the return fitting leftmost if the lower pulley. It must've happened when I tightened it. Is this going to be fixable? I really don't want to replace the block...but it is what it is.
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Mon Apr 02, 2018 7:29 pm Post subject: Re: I think I just screwed myself - Cracked Case |
Yes it can be repaired, but you'll have to strip the case down. And, it'll have to go somewhere that can competently weld magnesium. Rimco and Brothers should be able to do it..
That damned fitting bites so many people in the ass! I have learned to NOT tighten it much, and instead rely on a copious amount of red loctite to seal it.
100% success rate so far
SD _________________ modok wrote:
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Mon Apr 02, 2018 7:33 pm Post subject: Re: I think I just screwed myself - Cracked Case |
I had a crack in the same place years ago. I dripped a small hole at the end of the crack to stop it from spreading. i then cleaned the case and applied a 2 part epoxy. 5 years and 60,000 miles later the engine failed totally unrelated to the crack. _________________ Glenn
Member #1009
#BlueSquare |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Mon Apr 02, 2018 8:19 pm Post subject: Re: I think I just screwed myself - Cracked Case |
This is where paranoia sets in |
nsracing Samba Member
Posted: Mon Apr 02, 2018 8:28 pm Post subject: Re: I think I just screwed myself - Cracked Case |
how many times are we gonna do this?
if it is a straight hole and you jab something tapered in there- yes it will crack.
i have said it so many t8mes taper ream it first then thread it. it will never crack that way.
small crack that is a true pain in the butt. |
Posted: Mon Apr 02, 2018 8:50 pm Post subject: Re: I think I just screwed myself - Cracked Case |
veeweeman wrote: |
Yah no kidding, it's always the little things that you never expect that get ya
nsracing wrote: |
Okay..before I do anything else to my car I will come to you first to make sure it is okay. |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Apr 02, 2018 9:05 pm Post subject: Re: I think I just screwed myself - Cracked Case |
So why is the oil taking a hard right after coming out of the fitting in the case?
You have got to be restricting flow a lot with that 2nd 90 degree fitting.
That crack doesn't look like it goes past the end of the fitting INSIDE the case.
I agree with Glenn, stop drill the crack, clean & fill. _________________ Good Luck
Al |
scotty timmerman Samba Member
Joined: January 10, 2010 Posts: 1000 Location: gigharbor W.A
Posted: Mon Apr 02, 2018 9:35 pm Post subject: Re: I think I just screwed myself - Cracked Case |
FullFender wrote: |
I agree with Glenn, stop drill the crack, clean & fill. |
Yes I agree that it is probably restricting but that is the only way to get an oil line on there without burning it on the header.
I'll most likely go the route you and glen have suggested. Hopefully it'll hold till winter when I can tear it down and have it welded or build it up into larger 2 liter using parts my buddy has collected.
I appreciate the help everyone. |
Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Mon Apr 02, 2018 11:32 pm Post subject: Re: I think I just screwed myself - Cracked Case |
You can also plug that port and have the type 3/ bay window style outlet /inlet mod done to the case. This also require full tear down, but get hoses out of the way of exhaust or engine hanger _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Tue Apr 03, 2018 10:29 am Post subject: Re: I think I just screwed myself - Cracked Case |
UK Luke 72 wrote: |
When will people start using parallel thread and dowty washers?
Totally nullifies this issue. |
I’ve never heard of this?
Got links? _________________ 1974 Thing |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Apr 03, 2018 5:32 pm Post subject: Re: I think I just screwed myself - Cracked Case |
I wonder if a pipe tap could be placed in that hole and then TIG weld the crack up. The weld would pull the two halves together.
Edit: Actually maybe just put the fitting back in on the loose side and then weld.
Then , don't spin in a 90 and stop where you want it pointed regardless of the torque applied. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
esde Samba Member
Posted: Tue Apr 03, 2018 8:59 pm Post subject: Re: I think I just screwed myself - Cracked Case |
UK Luke 72 wrote: |
I have just bought some #6 ORB (o ring boss) fittings and a tap to try. If
It works it'll be a much nicer connection than the npt threads..
The fittings are big though, so finding a combination that clears a stock pulley is the hard part.. _________________ modok wrote:
atafonso Samba Member
Joined: January 03, 2016 Posts: 33 Location: United Kingdom
Posted: Wed Apr 04, 2018 2:13 am Post subject: Re: I think I just screwed myself - Cracked Case |
esde wrote: |
SD |
Same here.
I tap and test the fitting until the fitting stays at the right position and tight ENOUGH. Then use red loctite. Takes a while, but it works perfect everytime.
Abel |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Wed Apr 04, 2018 2:15 am Post subject: Re: I think I just screwed myself - Cracked Case |
theKbStockpiler wrote: |
Then , don't spin in a 90 and stop where you want it pointed regardless of the torque applied. |
Can't weld a mag case like that, I believe they have to be welded under water or something like that. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Wed Apr 04, 2018 4:09 am Post subject: Re: I think I just screwed myself - Cracked Case |
Mag case can be TIG'ed but it's got to be CLEAN. I mean REALLY CLEAN.
If it were me I'd try to clean and prep the crack for welding while the engine is together (I have my own TIG rig). If that fails, I'd just do a full tear down and try again. If that fails, I'd consult a better welder (I'm pretty good but not a pro) or plan on a new case.
Magnesium is porous so it's absorbs oil. Couple that with the fact it oxidizes like crazy and it means very good prep work is required. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Posted: Wed Apr 04, 2018 8:00 am Post subject: Re: I think I just screwed myself - Cracked Case |
Quote: |
Can't weld a mag case like that, I believe they have to be welded under water or something like that |
I have never welded MAG myself but according to people that have only the dust ignites.
I had welding done on a MAG case. They cleaned it with brake cleaner and weren't a big pain in the ass about it. The end result was excellent. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Chad M Samba Member
Posted: Wed Apr 04, 2018 8:50 am Post subject: Re: I think I just screwed myself - Cracked Case |
I had welding done on a MAG case. They cleaned it with brake cleaner and weren't a big pain in the ass about it. The end result was excellent. |
This bears repeating if anyone here is so inclined to attempt the repair themselves.
https://isystemsweb.com/phosgene-gas |
