Need some help... 1955 oval ragtop semaphore.
Andrezleuro
Andrezleuro is offline
PostPosted: Tue Apr 03, 2018 4:43 pm    Post subject: Need some help... 1955 oval ragtop semaphore. Reply with quote
Hey guys, first off..... thanks in advance for any help. Does anyone have a picture of the dash on a 1955 oval ragtop semaphore car? Just picked one up a few days ago off of here and it has a few holes that where done at come point along its life. Want to go back to og and fix it. Need to know what it should look like. Once I figure out how to post pictures on here I will add some. Also would like to know the knob and what they control . Thanks !
Andrezleuro
PostPosted: Tue Apr 03, 2018 4:45 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Just about forgot...it is a 11/55. Two fold w semaphores so Iím assuming it started itís life somewhere other than the states ?
56Cabrio
56Cabrio is offline
PostPosted: Tue Apr 03, 2018 4:54 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
My 1956 convertible (build date Aug 9, 1955) yours would be the same minus clock,gas gauge
& grab handle
(WTB) San Fernando Vokes Motors plate frame & San Fernando Mission VW plate frame
F#ck Cancer !
https://shop.stjude.org/GiftCatalog/donation.do?cID=14262&pID=24671
Stop dead photo links! Post your photos to The Samba Gallery
Andrezleuro
PostPosted: Tue Apr 03, 2018 4:57 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Thanks a lot, from left to right ... what are the knobs ? Also would there be a semaphore witch or would it be the turn signal switch ?
56Cabrio
56Cabrio is offline
PostPosted: Tue Apr 03, 2018 5:02 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Here you go and yes turn signal switch activates semaphores.
https://www.thesamba.com/vw/archives/manuals/56beetle/5.jpg
F#ck Cancer !
Andrezleuro
PostPosted: Tue Apr 03, 2018 5:04 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Awesome man thank you so much. Would you know if it would have been an import from somewhere since it has semaphores?
BulliBill
BulliBill is offline
PostPosted: Tue Apr 03, 2018 6:03 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
By Nov '55 (1956 model year) all USA spec Beetles had blinker systems, not semaphores. Your car probably was not a USA spec car. You'd have to write to VW in Germany with your chassis number and pay for a "birth certificate" which usually tells what country your car was initially shipped to.
Bill
Cape Girardeau - Adams Volkswagen
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
Keith
Keith is offline
PostPosted: Wed Apr 04, 2018 12:00 am    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
As a Bill mentioned, you donít have a Ď55, you have a Ď56. Semaphores were dropped for the American market early in Ď55 and the Ď55 model year only went from January í55 to Aug of Ď55 thatís when the official Aug-Aug model year started for VW from there on out, so Aug Ď55 is the Ď56 model year. It wasnít like that before. You have a euro market Beetle. Ď 55 was the first year for bullet turn signals with snowflake tail lights and towel rail (ram protection) bumpers standard for the American market and would have a 3 fold ragtop, and ribbed doors as well.
Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind
Andrezleuro
PostPosted: Wed Apr 04, 2018 7:33 am    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
My vin plate up front stamped 1955
Keith
Keith is offline
PostPosted: Wed Apr 04, 2018 8:14 am    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
As mentioned, Any date stamp starting in Aug of Ď55 is a Ď56, you donít have a Ď55.
If you go out to whatever modern car you have right now and look at the sticker in the door jam of the drivers door it is likely that your 2003 Chevy suburban was made in the previous year of what it is, 10/2002 for example, that doesnít make it a 2002.
Manufacturers have the practice of Model years starting in Aug of the previous year and run to Aug of the current year for that model. As mentioned, VW started this practice in Aug of Ď55. Before that they went with the calendar year.
My Ď65 beetle was made Aug of Ď64 and sold in Aug of Ď64 to the original owner.
Andrezleuro
PostPosted: Wed Apr 04, 2018 8:15 am    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Got it, thanks a lot !
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Wed Apr 04, 2018 8:02 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
... please tell us the stamped body number... that's the number, behind the spate tire, next to the brake reservoir....
... sometimes lots of things are changed and we get confused... this body number will clear things up... if your plate states 1955, it might be... just digging a little deeper.
1/54 black, 11C sedan
2/55 Reed Green, on a '65 pan
3/1955 stratos silver, 113 sedan
1960 Single Cab
1962 SO-33 with SO-42 interior
9/63 Ghia
'87 Toyota MR2
German sausage are the wurst.
ZENVWDRIVER
PostPosted: Wed Apr 04, 2018 8:14 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
... you might look in the technical section, here on thesamba, look at a 1955 owner manual dash, to learn where everything is located on the dash..... here's mine, a 3/55, body number 747 714
... is your speedo in MPH or KPH... do you have a smaller hump gas tank or a bigger rectangular one with a huge 100 mm gas cap... ? We'll get to the bottom of this... many times there is a date on the back of your speedo... that'll tell you roughly what year and month your car was built...
1960 Single Cab
9/63 Ghia
'87 Toyota MR2
Andrezleuro
PostPosted: Thu Apr 05, 2018 11:10 am    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Plate is stamped 1955
Keith
Keith is offline
PostPosted: Thu Apr 05, 2018 4:17 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
As it has been said already, that doesnít matter. The vin is what matters.
You have a 2 fold, so if that is original and not an incorrect graft, you are already looking at it being a Ď56. Do you have ribbed or smooth doors, large square gas tank or humped gas tank? Smooth rear apron or dual outlet rear apron? Sure, many of these could have been changed, but they paint the picture.....speaking of picture, pictures sure do help us.
Andrezleuro
PostPosted: Thu Apr 05, 2018 4:18 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
I believe itís a 56 since itís 11/55 build. Iíll post pictures soon
Keith
Keith is offline
PostPosted: Thu Apr 05, 2018 4:23 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Yup, Ď56 and NOT a Ď55
Ď55 shares a lot with the split window bugs and Ď56 was the change over year. They donít really share much with Ď55 and down. Doors are different, gas tank is different, door jamb stamping is different, floorpans are different, seats are different, inside door handles and window winders are different, engine stuff is different, and on and on and on.
Andrezleuro
PostPosted: Thu Apr 05, 2018 4:47 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
Good to know, itís a complete car only thing missing is the driver seat.
ZENVWDRIVER
PostPosted: Thu Apr 05, 2018 6:23 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
... what's your body number?
1960 Single Cab
9/63 Ghia
'87 Toyota MR2
Andrezleuro
PostPosted: Thu Apr 05, 2018 6:36 pm    Post subject: Re: Need some help... 1955 oval ragtop semaphore. Reply with quote
