Was $3500 CAD too much for this? |
Yes |
74% |
[ 37 ] |
No |
26% |
[ 13 ] |
Total Votes : 50 |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Wed Apr 25, 2018 7:17 am Post subject: Re: 67 Kombi Build |
thats an ambitious project- Did you find the stub axle yet? How are the gears- PM me for some parts- pretty sure the postage to Canada will be a bit steep-- Are you doing any trans work? lots of good info on putting that RGB set up back together. Personally I would go in search of a bus carcuse to scavenge parts off of. I have a 68 body we cut the roof off - to repair my 78 and then have all kinds of body parts left. So that might be an option for you.
Keep in mind -the thousands you would have used to get a welding class. Now you have one in your yard
If you read some of the "build threads" here - you will see how many people bought a Harbor freight welder and then listened to the welding advise on here and literally became welders before the forum's eyes-
Thats a pretty good core engine with the DP heads and dog box oil cooler.
[img][/img] _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
frothbeast Samba Member
Posted: Wed Apr 25, 2018 10:09 am Post subject: Re: 67 Kombi Build |
Thanks, I will test it and fix it. Nice thread! |
Posted: Wed Apr 25, 2018 10:32 am Post subject: Re: 67 Kombi Build |
williamM wrote: |
Thanks for the reply, I have not found the stub shaft, but it appears i have lots of work to do , I can ignore some problems until I can't ignore them anymore. I haven't counted the teeth on it yet. I ran a die down the threads and 'cleaned' them. Now I have what resembles an acme(square) thread with outer diameter 29mm rather than 30. I will see if a new nut will hold it for now. I will temper the hardness out of the steel and thread it with a 27mm x 2 or 27mm x 3 then harden it again, if I can't get a shaft easy enough. That will bring the safety factor down, but I think it will still be more robust than the what is on the cars they build today.
Right now I am going to get some steel bent for a 'frame rail' then i will level, measure, rotate, measure, level, rotate, etc then connect the front and rear suspension with good steel.
I haven't done anything to the tranny, but once i replace the missing metal on the horns that hold it, I will change the oil and see how it does. I don't really want to dig into it unless I need to. If this transmission is relatively the same as my two swing axle bugs ('58 and '60) then I am not to worried about tearing it down for no reason. Same with the engine. I will take the heads and jugs off to see the condition of the rings and valves, but no reason to dig deeper unless something grenades itself. |
Posted: Tue May 08, 2018 10:58 am Post subject: Re: 67 Kombi Build |
I am waiting for some steel to get bent for me, and also some plates plasma cut for me too. While I wait I will get this old engine running again.
Please ignore the complicated mess in behind, but note the solo cup full of beer!
I welded a few nuts to this broken stud before I got it to come loose(Thanks Jeff D. for the method)
Posted: Fri May 11, 2018 12:36 pm Post subject: Re: 67 Kombi Build |
Here is my state of the art Valve lapping station:
Had to remove a bur from one valve to stop it from gouging the guide. It would not come out nice until I filed it a bit:
One more broken bolt took about 12-15 nuts welded to it before it came out
Posted: Tue Jun 19, 2018 6:09 am Post subject: Re: 67 Kombi Build |
I attempted to weld a frame rail to the torsion tube. I have achieved a 'birdpoop' weld on the outside and I blew through a bit on the inner side. I used a 3.5" hole saw for tube hole in the 'frame' rail. I spent some time cleaning the tube ahead of time, but I see this is not clean enough. I have used flux core wire for too long now. I must unlearn what I have learned. I will have to figure out how to get my hands/body/grinder in there to dig the outer weld out and do it again. Has anyone ever pressed or slid a sleeve inside the tube and then plug weld it in there?
Posted: Fri Jun 22, 2018 9:44 am Post subject: Re: 67 Kombi Build |
I laid on the ground and did some spot sandblasting. Then I laid on the ground and welded the "frame". These are not pretty welds, but I think I can use these welds to hold things together when I flip the bus upside down.
