williamtennal Samba Member
Posted: Thu Apr 05, 2018 7:08 am Post subject: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
I recently installed the Go Westy auxiliary battery kit in my 1984 Tin Top GL Non-Camper. Install went smooth, I am currently running the Go Westy 80W Foldable panel. For now I am just taking it out during the day when its sunny, but soon it'll be roof mounted. Thats besides the fact though!
I am getting charge to my controller and everything seems to be working fine minus my Pro Sport 12 dual power bank. Do I actually need to plug this thing into my AC Adapter? Without it plugged in even with it wired up to the isolator it still shows no power unless I have it plugged into the AC Adaptor. Do I have it wired up wrong? I woke up to my AC Adaptor going nuts because I left it on all night with the power bank plugged in...
Any advice appreciated, thanks!
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Thu Apr 05, 2018 7:44 am Post subject: Re: 1984 Tin Top Solar install(Specifically regarding the pro sport) |
I am confused. The sport 12 is going to charge the battery when connected to ac. The solar controller will charge the battery when you have sun. They are independent of each other. So to positive battery you should have solar controller as well as the sport12. Are you thinking the solar should go through the sport 12? |
Posted: Thu Apr 05, 2018 9:09 am Post subject: Re: 1984 Tin Top Solar install(Specifically regarding the pro sport) |
[email protected] wrote: |
I have the solar going through the Go Westy 10a solar controller.
The Pro Sport has two hook ups, one for each side of the isolator, and then a plug to AC. I have it hooked up, but its only showing the blue power on light, nothing about charging. Is this right? |
Posted: Thu Apr 05, 2018 9:47 am Post subject: Re: 1984 Tin Top Solar install(Specifically regarding the pro sport) |
Not sure I have no experience with the GoWesty isolator. I have a blue sea one and my charger is connected directly to aux battery. I would think your charger has to lead for two batteries? When I plug charger in to AC and it begins charging aux battery the blue sea relay will turn on allowing to charge the aux and start battery. I would think its the same for you. I would look at the GoWesty documentation or give them a call and they will set you straight. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
Posted: Thu Apr 05, 2018 9:57 am Post subject: Re: 1984 Tin Top Solar install(Specifically regarding the pro sport) |
Ok just watched tbe video. Sounds like you got it right. So you are wondering if tbe battery is recieving a charge. A full battery will be around 12.8v once you plug in charger battery should show around 14v. You can check with a meter or I would think your solar charge controller show show battery voltage. |
kamzcab86 Samba Moderator
Posted: Thu Apr 05, 2018 11:27 am Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
Where is the red wire from the battery's negative terminal going? _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Apr 05, 2018 4:58 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
kamzcab86 wrote: |
Where is the red wire from the battery's negative terminal going? |
Thats going to the negative post on the AC inverter, I just only had red wire.. of course... haha
To clarify I do have the solar charger hooked up directly to the battery, the pro sport is running to both sides of the isolator and has the AC plug, plugged into the inverter.
I went out and checked the charger after the panel has been out in the sun for most of the day... 11.8 V.... no good. The Prosport did have the "ready" light illuminated though which is new.
After I installed the system it rained for like 6 days and I was unable to put my panel out, the battery sat dead for a week. Could the battery be fried? |
Posted: Thu Apr 05, 2018 5:23 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
williamtennal wrote: |
the pro sport is running to both sides of the isolator and has the AC plug, plugged into the inverter. |
So, you have the inverter wired to the aux battery and the charger plugged in (and running off of) said inverter? If you do, that's a no-go. The inverter is drawing power as it runs, as is the charger. You're basically asking the aux battery to charge itself while powering said charger, as well as trying to charge the primary battery too. It's going to result in a depleted aux battery, as you discovered.
AC chargers really need to be plugged into AC power. Grab an extension cord, plug the AC charger into it, shut the inverter off, and you should see the ProSport start charging.
With the battery down to 11.8, it's considered down-for-the-count, but not dead. You can revive it, but it's life may have been shortened a bit. You can take it to Batteries+ (or similar store), have them charge it, then do a load test to verify that it's not fried... if desired. _________________ ~Kamz
2016 Golf GTI S
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Thu Apr 05, 2018 5:27 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
dobryan wrote: |
I am very confused. I think the prosport should be connected directly to the battery and plugged into 110v shore power. If the prosport is plugged into the inverter it seems you are trying to cherge the battery from the inverter which is powered by the battery???? |
This is exactly what it sounds like, which is a bit spooky. No offense intended OP, but if you are doing what Dobryan suspects, you may want to get someone with an electrical background to check your work. Electricity can do some very unpleasant stuff to you and your van. _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Posted: Thu Apr 05, 2018 7:28 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
Presently my wiring is following the Go Westy auxiliary battery schematic and the video they have on youtube, only difference is I don't have the relay that has the fridge power stuff on it. |
Posted: Thu Apr 05, 2018 7:33 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
This is exactly how I have it
Posted: Thu Apr 05, 2018 7:53 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
*IF* you have it wired exactly that way, then plug the a/c power cord into a 120v receptacle at your house/campground, etc, and you should be good to go. Plugging that cord into your inverter means you are trying to take your 12 volt d/c battery power, change it to 120v a/c via the inverter, and then recharge your battery using the ProSport to convert 120v a/c to 12 volt d/c. _________________ 1986 Westy Weekender
Now a full camper
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Fri Apr 06, 2018 12:48 am Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
There's no 12V isolator shown for the inverter. Without one, it'll draw a small amount of power regardless of any other ON/OFF switches on it. Some draw a significant amount when 'OFF', enough to flatten a battery in short order. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Fri Apr 06, 2018 2:40 am Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
fxr wrote: |
There's no 12V isolator shown for the inverter. Without one, it'll draw a small amount of power regardless of any other ON/OFF switches on it. Some draw a significant amount when 'OFF', enough to flatten a battery in short order. |
Can I run it on the isolator I already have?
This is the first I’ve heard of needing to run that on an isolator, I have it hooked right up to the battery! |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Fri Apr 06, 2018 2:15 pm Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
I'm not familiar with this Prosport. Are the two positive DC lines leaving it 100% independent? If not, you are bypassing the battery separator, which is not good. Normally, I would charge on the aux battery side and not the starter battery, letting the battery separator handle that action.
Also, the inverter should have a switch on it. 110V is rarely needed, and inverters tend to draw power even when not used, if connected.
Finally, either ALWAYS mark both ends of a wire that uses the wrong color. So if you are using red as a ground (not recommended, really), you MUST put black tape on both ends. I know, it's tempting to save time and money, but it's worse to have a short with 100+ amps of battery current shorting out. _________________ Rich |
Posted: Sat Apr 07, 2018 8:04 am Post subject: Re: 1984 Tin-top Solar Install (Specifically: ProSport Charger) |
RichBenn wrote: |
Finally, either ALWAYS mark both ends of a wire that uses the wrong color. So if you are using red as a ground (not recommended, really), you MUST put black tape on both ends. I know, it's tempting to save time and money, but it's worse to have a short with 100+ amps of battery current shorting out. |
Yep, it has two positives that I have ran to both sides of the isolator, and then two grounds that are both locally grounded together.
The battery had charged to near 13v after a day in the sun but we got snow last night (Missouri go figure) and now my panel has snow on it. Haven't addressed the ProSport at all, ordering a isolator for the AC Inverter today! |
