Red5 Samba Member
Joined: December 09, 2017 Posts: 111 Location: Burlington, Vt
Posted: Thu Apr 05, 2018 8:48 am Post subject: Changing Steering Box/Column Angle |
I was doing some preliminary fitment with my new front beam and steering shaft. I set the steering box angle using the little bumps/indexes found on the front beam. Following that angle up to the driver's seat with the steering shaft shows that the bottom of steering wheel would end up being way, way too high. Reducing the angle of the steering box by about 20 degrees (according to the angle finding app on my phone) lowers the steering wheel to a reasonable height.
I'm wondering if changing the steering box angle by that much will cause issues with the steering geometry. Seems like a change that large might cause some binding once the tie rods, spindles and other steering components are put on.
What are my options? Would adding a universal joint between the steering wheel and steering box be the best bet? Thanks again. |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Fri Apr 06, 2018 4:49 am Post subject: Re: Changing Steering Box/Column Angle |
If you flip your clamp around & line it up with the bump it should lower the wheel. One is set for Bugs, the other is for Ghias... The Ghia setting lowers the wheel a bit... Or you could grind off the bump & set it where it needs to be, I would think... _________________ ~X-Man~
'60's Spatz Buggy body on '74 Chassis (Budget Build)
'69 Bug (Baja-to-be partial daily)
'10 Silverado (My daily) |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Apr 06, 2018 10:42 am Post subject: Re: Changing Steering Box/Column Angle |
When your mocking it up are the inner tie rod mounts on the box level ( parallel with the floor)? Is this in a buggy or car? If you don't have a steering wheel mount yet then you can just put a u Joint on the box and shoot the steering shaft straight to it. |
Red5 Samba Member
Posted: Sun Apr 08, 2018 12:33 pm Post subject: Re: Changing Steering Box/Column Angle |
Yeah, I should have started off with pictures. I've now configured the steering box to set at the shallowest angle possible using indexes on the clamp. As it turns out, the angle isn't too bad:
But it does look like I'll have to cut and move the lower "windshield" tube up an inch or two so the steering column bushing can be welded to its bottom.
I also put the connecting rods on and took a couple of closeups of the steering box. Will the steering coupler be able to handle that angle between the steering box and steering column?
mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Sun Apr 08, 2018 1:49 pm Post subject: Re: Changing Steering Box/Column Angle |
Use a couple of U-joints with a support somewhere in between similar to this. If you rotate the steering box and therefore the pitman arm, you start affecting the angles of the tierods which is mostly never beneficial. Since yours is basically a straight shot, one U-joint would probably work out as mentioned already.
_________________ Michael
Pit Boy 6163 Spec Trophy Truck |
