roscopeco10 Samba Member
Posted: Thu Apr 05, 2018 1:05 pm Post subject: Poor running 1641 TP |
Mayday pulling my hair out with this one! On my 3rd exchanged 34 pict Bocar carb. Fist had an air in leak issues so wasnt ticking over once choke had dropped out.
carb no.1 & no.2 had only done 50 odd miles before playing up and straight replacement ran fine each time but not for long. Lost count how many times I have done valve clearances, dizzy timing and usual 2 and half turns out procedure on each carb set up. Now I am on carb no.3, It runs ok with choke then pretty lumpy with big flat spots until it warms up some more and evens out but still only just ticks over. To get it ticking over only just, the carb screws are out like 4/5 turns!
Wondering if the stock fuel pump is not providing enough fuel ??
Its a recon block under 1k miles, 1641 TP new heads, pots, pistons, "CARB!" fuel pump & filter, pretty much newish everything
Would love any ideas _________________ 73 Dormobile now a 73 crew cab & 79 crew cab, ping me anything crew cab related! |
Starbucket Samba Member
Posted: Thu Apr 05, 2018 2:03 pm Post subject: Re: Poor running 1641 TP |
Feel the heat riser under the manifold, it should be too hot to touch after 3-5 min.s running, if OK look down the carb (motor off) and open the throttle slowly, the accelerator pump should start squirting gas as soon as you open the throttle and continue until WOT, if not adjust the cam screw toward +. |
Posted: Thu Apr 05, 2018 2:31 pm Post subject: Re: Poor running 1641 TP |
Will check riser in the morning and check carb. I am guessing I am looking for fuel being squirted from what is in the float chamber _________________ 73 Dormobile now a 73 crew cab & 79 crew cab, ping me anything crew cab related! |
Posted: Thu Apr 05, 2018 3:31 pm Post subject: Re: Poor running 1641 TP |
roscopeco10 wrote: |
Yes that's what gives the motor power when the throttle is opened and the vacuum drops. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51125 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Apr 05, 2018 3:34 pm Post subject: Re: Poor running 1641 TP |
Please tell us about the condition of your fuel tank and what the last fuel filter looked like inside. Also tell us what distributor you have and how you are timing it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2536 Location: Ocean Beach in Beautiful BLUE California
Posted: Thu Apr 05, 2018 4:12 pm Post subject: Re: Poor running 1641 TP |
Mayday pulling my hair out with this one! On my 3rd exchanged 34 pict Bocar carb...........
Would love any ideas |
If all else is in fact good then that one word above **just may** be your problem.
Look on here for "Volkzbitz" -- he rebuilds carbs. He produces an incredible 34 Solex PICT. Check his feedback. Purchase and it might just solve your problems. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
SGKent Samba Member
Posted: Thu Apr 05, 2018 4:46 pm Post subject: Re: Poor running 1641 TP |
I'd also check the manifold boots for leaks and cracks, as well as the brake booster to be sure it is not leaking. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
wcfvw69 Samba Purist
Posted: Thu Apr 05, 2018 7:13 pm Post subject: Re: Poor running 1641 TP |
Post some pictures of your engine and engine compartment. As others have stated, most aftermarket carbs are better used as door stops.
Volkzbitz.com sells beautifully restored German Solex 34-3 carbs. I run restored German, Solex carbs, Pierburg fuel pumps and Bosch distributor.
These were high quality parts that are easily restored back to like new condition. _________________ Contact me at [email protected]
The Samba member since 2004.
aeromech Samba Member
Joined: January 24, 2006 Posts: 16959 Location: San Diego, California
Posted: Thu Apr 05, 2018 8:50 pm Post subject: Re: Poor running 1641 TP |
A Volkzbitz Solex 34pict-3 is about $250 outright. Best money you could spend. As others have said, there are many other things to consider such as manifold heat and what distributor you’re using. Vacuum leaks, contaminated fuel, etc. all need to be considered. Best thing you could do right now is post 4-5 pictures of your engine. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Fri Apr 06, 2018 4:50 am Post subject: Re: Poor running 1641 TP |
Thank you for the tips so far, pics will be posted later today after I get chance to try some of the suggestions out. _________________ 73 Dormobile now a 73 crew cab & 79 crew cab, ping me anything crew cab related! |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Fri Apr 06, 2018 6:30 am Post subject: Re: Poor running 1641 TP |
What cam is in it? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Fri Apr 06, 2018 6:24 pm Post subject: Re: Poor running 1641 TP |
In my short time around the block with aftermarket carburetors.. I have found they need to be opened up and cleaned, and you need to set the float height. Pull all four jets out and blow them and their passages out with shop air.
The number of turns out on the idle mixture is not really as important as how rich or lean the mixture actually is, but you won't know that info without an air fuel ratio gauge.
There is a good possibility the throttle shaft is too loose in its bores and is leaning out the mixture.. you can't adjust a throttle shaft vacuum leak out, but you can hide it by running too rich at idle. Yes new carburetors can have too much clearance at the throttle shaft bores.. it's not from wear, it's from bad machining tolerances during manufacture. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Apr 07, 2018 6:01 am Post subject: Re: Poor running 1641 TP |
SGKent wrote: |
I'd also check the manifold boots for leaks and cracks, as well as the brake booster to be sure it is not leaking. |
This! Especially brake servo line.... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
deezal Samba Member
Joined: February 21, 2008 Posts: 138 Location: pike county
Posted: Sat Apr 07, 2018 8:49 am Post subject: Re: Poor running 1641 TP |
To much fuel pressure maybe? |
Posted: Sat Apr 07, 2018 9:44 am Post subject: Re: Poor running 1641 TP |
So cant see any juice squirting in the carb with engine off when I pull throttle lever and pre heaters vary in temp after 5 mins definately not hot under the carb mount.
https://youtu.be/uGJyzrDbvms
Delayed sorting this issue, down to the Accelerator pedal hinge snapping yesterday !! woohoo _________________ 73 Dormobile now a 73 crew cab & 79 crew cab, ping me anything crew cab related! |
Posted: Sat Apr 07, 2018 9:56 am Post subject: Re: Poor running 1641 TP |
That's quite the combination of aftermarket new stuff, a little flaw here and a bit of underperformance there all adds up to a less than optimal engine.
At first glance I see:
Aircleaner
Carb
Distributor
Possible small lower pulley
Long belt (slow fan)
No crankcase breather
No wire on oil pressure switch
Some needs immediate attention, others can be replaced one at a time for a gradual improvement in performance. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Apr 07, 2018 11:12 am Post subject: Re: Poor running 1641 TP |
Yep clogged pre-heat pipe and look at the accelerator pump cam and adjust it toward the +. The pre-heat tube is clogged with carbon and needs to be cleaned out. |
SGKent Samba Member
Posted: Sat Apr 07, 2018 11:50 am Post subject: Re: Poor running 1641 TP |
or the muffler wasn't drilled out for preheat. Some come with a welded plug and have to be drilled to allow the pre-heat to work. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
OB Bus Samba Member
Posted: Sat Apr 07, 2018 11:59 am Post subject: Re: Poor running 1641 TP |
SGKent wrote: |
or the muffler wasn't drilled out for preheat. Some come with a welded plug and have to be drilled to allow the pre-heat to work. |
Forgot this one time. Engine ran poorly for "no apparent reason" until I drilled the muffler pipes out. _________________ Larry in OB
Posted: Sun Apr 08, 2018 8:50 pm Post subject: Re: Poor running 1641 TP |
On a positive note, it’s clean.
You know, a new guy walks into a VW parts house and he sees all this crap for sale. He doesn’t know better and relies on the parts guy to steer him in the right direction. That’s where the error lies _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
