tthoms Samba Member
Joined: October 27, 2016 Posts: 184 Location: Los Lunas, NM
Posted: Thu Apr 05, 2018 7:13 pm Post subject: Fuel filler tube connection |
I had my tank cleaned, and in the process of putting it back the tube that connects the filler tube to the tank refused to fit. It looks like the PO overtorqed the clamp ring and deformed it.
I found a replacement on Aircooled.net, but the description throws me.
http://vwparts.aircooled.net/Fuel-Filler-Neck-Hose-Inner-Seal-113-201-215-p/113-201-215.htm
Its labeled as an inner seal, while the tube that I removed went around the fill tube and the fuel tank opening (it reminds me of radiator hose). Have I identified the wrong part, or did someone put the wrong part on before me? Any ideas on a fix?
Thanks in advance! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9954 Location: Huntington Beach, CA
Posted: Thu Apr 05, 2018 8:34 pm Post subject: Re: Fuel filler tube connection |
Pictures???
That part goes on the steel gas tube, right behind the barb. Then the filler hose slides over that ring to further seal vapor release.
Check out this page.
http://www.wolfsburgwest.com/wolfsburg_new/fuelsystem/index.cfm?type=1
It has a diagram for the parts. Part 33 is the inner seal you have a link to., in your post. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
tthoms Samba Member
Posted: Thu Apr 05, 2018 9:05 pm Post subject: Re: Fuel filler tube connection |
Here's a picture of the tube that I removed:
It doesn't look like the set up you referred to from Wolfsberg.
Bummer. |
Posted: Thu Apr 05, 2018 9:09 pm Post subject: Re: Fuel filler tube connection |
That is the number 34 part.
The part you referencd before was 33, which goes in each end on that hose. _________________ Jimbo
TDCTDI wrote: |
tthoms Samba Member
Posted: Thu Apr 05, 2018 9:21 pm Post subject: Re: Fuel filler tube connection |
Now I get it. Thanks! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Fri Apr 06, 2018 7:49 am Post subject: Re: Fuel filler tube connection |
tthoms wrote: |
Those @%^%$#&#@^## hoses in my 1970 really needed to be 1/2 inch longer, was tough to get them leak free when I removed my fuel tank last year.
Yes - I was too $%&%#%^*&$##^&& cheap to buy new hoses for there. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Fri Apr 06, 2018 8:43 am Post subject: Re: Fuel filler tube connection |
I did buy new ones for mine and they were too short. So, I over tighten the clamps and guess what, they stretched out. Made that inner rubber band make sense. No leaks for over a year now. Time will tell if I got it figured out. _________________ Jimbo
TDCTDI wrote: |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Fri Apr 06, 2018 9:29 am Post subject: Re: Fuel filler tube connection |
seems like as good a time as any to ask this, but is there a reason you can't use one long hose to go from the fuel fill door to the tank? I never really understood the need to use 2 pieces of rubber, 4 seals and a metal pipe when you could possibly just use one big rubber hose. Would eliminate a few points of failure in terms of vapor leaks. _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Apr 06, 2018 10:51 am Post subject: Re: Fuel filler tube connection |
Maybe use some fuel fill tubing from kartek or something. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Fri Apr 06, 2018 11:36 am Post subject: Re: Fuel filler tube connection |
Gates 23930 or Dayco 80305, 1-7/8" fuel hose (48mm), runs about $45 for a three foot stick.
You can also get rid of the plastic adapter that has the vacuum hose attachment if you no longer use it by using a single length of 19/32" PCV hose. |
tthoms Samba Member
Posted: Fri Apr 06, 2018 3:32 pm Post subject: Re: Fuel filler tube connection |
So, to recap, the replacement hoses from Wolfsberg are the ones to get, or are they too small? I've placed my order already.... |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6592 Location: Houston, Texas
Posted: Fri Apr 06, 2018 5:38 pm Post subject: Re: Fuel filler tube connection |
My 73 has two tubes and in the middle a metal elbow. The filler hole fits on to one tube and the end of that tube fits to the elbow. The elbow then fits onto the other tube and the end of that tube fits onto the tank.
The old tubes has this tiny extra piece of rubber that fit inside the tube and helped seal it up. I didn't use it on the new ones. The tubes should be hard to put on otherwise you might not have the right size. Clamp them up and you are good to go. Fill the tank all the way (top it off) and you will know if it leaks. Carry a fire extinguisher just in case. _________________ www.vwnos.com [email protected]
tthoms Samba Member
Posted: Tue Apr 17, 2018 10:01 pm Post subject: Re: Fuel filler tube connection |
So I recieved the inner bands and the replacement tube from Wolfsberg West. Comparing the new tube with the old one, I noticed a problem.
I double checked the part number, and according to the website, the new part is the "correct" one. I didn't feel like cutting into it, so with the new bands, I made the old one work.
I also added a rubber fitting to the filler tube opening. It doesn't fit quite right, but that could be personal ineptitude on my part.
I've put a gallon in, and I'll see what happens tomorrow after the battery charges. |
heimlich VWNOS.com
Posted: Tue Apr 17, 2018 10:18 pm Post subject: Re: Fuel filler tube connection |
Put the new tube in a vise and take a hacksaw and cut very slowly. The slow race wins here. Even a wood saw will work. These are not banded with metal.
The issue with your old tube is, if you take it off and look, the ends will be cracked. I can see the age from the cloth band around it. You either replace it now or soon. It's really up to you. Probably with the new bands you were able to tighten it down a bit more. You really won't see any issues until the gas is sloshing around in the tank and some of it sits next to the entry so it times to work it's ways through the cracks. _________________ www.vwnos.com [email protected]
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Wed Apr 18, 2018 3:13 am Post subject: Re: Fuel filler tube connection |
Hello, I recently bought two of the hoses and cut each to juuussst over half to make both sided of the metal elbow. I used a exacto knife to make a clean, easy cut. No leaks. |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1105 Location: Martinez, CA
Posted: Wed Apr 18, 2018 11:03 am Post subject: Re: Fuel filler tube connection |
busman78 wrote: |
I'd have to go outside to check which I used, but I also used one hose from the filler to the tank. That piece is a bitch to cut with the metal bands, but I've never had a leak from that hose in about 8 years... _________________ -Adam
'59 Mango Bus
'69 Bug |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Wed Apr 18, 2018 11:26 am Post subject: Re: Fuel filler tube connection |
When I first replaced those hoses on my 69, they came from WW as 2 separate ribbed hoses. They lasted about 10 years before I started smelling fuel and changed them again. This time WW sent that single hose that you have to cut in half. Works fine and no more fuel smell. _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
tthoms Samba Member
Posted: Wed Apr 18, 2018 9:25 pm Post subject: Re: Fuel filler tube connection |
Sounds like I have an appointment with a hacksaw. The old tube is holding for now. I'm going to have to disassemble the whole gas tank assembly to repaint the inside of the bonnet in about 6 months. I'll make the change then. |
Posted: Wed Apr 18, 2018 10:19 pm Post subject: Re: Fuel filler tube connection |
Yes, you need to cut that hose in half. Easy with a utility knife with a NEW blade. Wrap a piece of masking tape around the outside as a reference line to cut to.
Change that old hose. The hose fails from the inside out. After you have replaced it, cut it in half lenght wise and bend it against its inside curve. You will see the fissures that are present and soon will leak, with our highly aggressive fuels out in the marketplace. _________________ Jimbo
TDCTDI wrote: |
AlmostHeavenWV_VW Samba Member
Posted: Thu Apr 19, 2018 6:46 am Post subject: Re: Fuel filler tube connection |
VW_Jimbo wrote: |
Change that old hose. The hose fails from the inside out. After you have replaced it, cut it in half lenght wise and bend it against its inside curve. You will see the fissures that are present and soon will leak, with our highly aggressive fuels out in the marketplace. |
Bought a kit from MidAmericaMotorworks, same deal. One small stick of hose, cut it in half. Though I dislike the unnecessary multi-piece filler neck set up and will be replacing with the one piece of Gates hose mentioned above this summer.
Also, far far far before that old hose starts leaking liquid gas, it will become gas permeable. No good for your health. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
