fastbackdavid Samba Member
Posted: Thu Apr 05, 2018 7:14 pm Post subject: Okrasa engine |
Has anyone used a vacuum advance distrib. with the Okrasa set up? |
Posted: Fri Apr 06, 2018 5:46 pm Post subject: Re: Okrasa engine |
Hello Bueller Bueller anyone? |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Fri Apr 06, 2018 6:08 pm Post subject: Re: Okrasa engine |
Just vacuum? Or SVDA?
What are you trying to accomplish?
With what carbs? _________________ modok wrote:
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Apr 08, 2018 6:33 am Post subject: Re: Okrasa engine |
This is the dist the op is asking about using. VJUR4BR8
_________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
1958ghia Samba Member
Posted: Sun Sep 15, 2019 10:42 pm Post subject: Re: Okrasa engine |
I am interested in knowing this too, anyone running a Vac/mech advance distributor like the VJUR4BR8 with an Okrasa or Okrasa-style Kit? Is there a place to tap off one or both carbs for vacuum? Thanks! |
swanlakers Samba Member
Joined: July 17, 2005 Posts: 370 Location: Lost in space
Posted: Sun Sep 15, 2019 11:10 pm Post subject: Re: Okrasa engine |
Oettinger used a vacuum advance distrib. with the Okrasa
Posted: Mon Sep 16, 2019 7:37 am Post subject: Re: Okrasa engine |
Ah very interesting, good catch there! thanks! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76912 Location: Sneaking up behind you
Posted: Mon Sep 16, 2019 7:41 am Post subject: Re: Okrasa engine |
They also used VJ4BR25 (010) mechanical only. _________________ Glenn
Member #1009
#BlueSquare |
56samba Samba Member
Posted: Mon Sep 16, 2019 7:46 am Post subject: Re: Okrasa engine |
swanlakers wrote: |
Always liked this illustration as it also shows a 25hp fuel pump, used to mount the 8mm fuel line without needing an adaptor?
Regarding the question about the vacuum support: I'm sure you can add a vacuum line somewhere, keep in mind these Solex 32 carbs were used on several boring German and European cars that also came with a vacuum advance distributor. On the carbs I have, there is always a little screw used to block this exit.
When you search the gallery or the WWW for pics of old original Okrasa engines, you will notice plenty of them have a vacuum cans, in fact I would say most of them.
It's a little off topic, I'm unsure if I have the rights to upload collected pics here after the new EU data law. |
Posted: Mon Sep 16, 2019 8:00 am Post subject: Re: Okrasa engine |
Thanks guys! Trying to keep my stock distributor to keep the numbers-matching parts as much as I can on my '59 Ragtop. Right now just found out the cam and lifters HATED each other and decided to eat each other, so those are going away along with the heads that were ran too long with over 80-thou valve clearance... So new heads were a must anyways, so why not give it some more kick?! Here it is before teardown:
Posted: Mon Sep 16, 2019 8:59 am Post subject: Re: Okrasa engine |
Just found this interesting picture showing the full path of a vacuum advance line over to the far passenger side for some reason...
Posted: Sun Sep 22, 2019 10:04 am Post subject: Re: Okrasa engine |
So I just received my WW Okrasa Kit, and it specifically states you have to go to a dizzy distributor because the carbs aren’t set up for a vacuum take-off. In doing some digging I came up with this military site that shows drilling out of a port next to the accelerator pump as you can see. I was thinking about drilling this out and tapping at 6.0x1.0 standard threads to be able to utilize the standard 4.0mm OD copper tube vacuum line and original 36hp vacuum fittings.
https://forums.g503.com/viewtopic.php?t=133909
This port has an obvious path that heads down to the intake surface but has a brass plug, would that need to be drilled out and gasket opened up?? |
Posted: Sun Sep 22, 2019 7:08 pm Post subject: Re: Okrasa engine |
Update: drilled & tapped the port mentioned above, then drilled out the small brass plug from the bottom so now I can cut a small notch in the carb gasket to pull vacuum from the intake!
For reference, this is just a temp mock-up with original 36hp 4mm OD vacuum line, I’ll likely need a longer line so I can route it better! I hope this helps somebody in the future, it was a bit scary drilling into a brand new carb!!
texstardetail Samba Member
Joined: May 24, 2009 Posts: 91 Location: Georgetown, Texas
Posted: Mon Sep 23, 2019 5:27 pm Post subject: Re: Okrasa engine |
I had the kit in my cart to purchase too! Guess you beat me to the punch.
What distributor are you needing to run with this kit? I too wanted to keep the OG distributor, but figure I'd rather install a new distributor vs tapping a carb. I know I'd screw it up somehow |
Braukuche Samba Member
Posted: Tue Sep 24, 2019 1:53 pm Post subject: Re: Okrasa engine |
texstardetail wrote: |
Get an 010 _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
