Numbers matching Thing?
4118thing
4118thing is offline
PostPosted: Sat Apr 07, 2018 6:23 pm    Post subject: Numbers matching Thing? Reply with quote
Iíve got to admit, Iím a newbie on this and really need some help, quick. Iíve got my Thing at the body shop ready to paint, and I was planning on changing colors, but the more I look, the more it looks like it might be a numbers matching Thing, and I should not change colors.
The VIN# is a 183, but the sticker on the post shows a 10/73 build date. I know if this were a beetle, a 10/73 build, would make it after August year change. But Things May have been different.
The motor number is AH359087. From what I can tell is this is a Ca emission motor, and if I look at the Beetle engine decoder, shows a late 73 production date.
Originally, I thought that since it had heater snorkels on the fan shroud, and heater boxes, it was a replacement. But if this is a Ca engine, it might have been configured that way even though I have a gas heater.
As you can see, Iím confused as to numbers matching, and ready to paint. Please HELP.
Al Capulco Premium Member
Al Capulco is offline
PostPosted: Sat Apr 07, 2018 10:04 pm    Post subject: Re: Numbers matching Thing? Reply with quote
Your motor number should start with AM, if not then it's not an original motor for a Thing. You have a '73 model and someone replaced the motor. Not uncommon.
Deckard
Deckard is offline
PostPosted: Sun Apr 08, 2018 4:26 am    Post subject: Re: Numbers matching Thing? Reply with quote
Do you mean the silver sticker in the post between the driver and the rear passenger's seat? There are also two other VIN number locations: On the front trunk's left side and on the transmission tunnel under the rear seats. The silver sticker is notoriously difficult to read.
4118thing
PostPosted: Sun Apr 08, 2018 5:10 am    Post subject: Re: Numbers matching Thing? Reply with quote
Yes, Iím referring to the perforated sticker. Mine is basically the same as yours.
What confuses me is that Beetle years changed in August. My engine is an AH, which from what I can determine is a California engine. I donít know if California required a different engine, to conform with their emissions.
I guess Mexico years changed with the calendar, and did not follow the German production year.
Deckard
Deckard is offline
PostPosted: Mon Apr 09, 2018 5:40 am    Post subject: Re: Numbers matching Thing? Reply with quote
The engine case should still be AM. As far as I know the '74 California/Emissions engines had an EGR valve in the manifold. Attached pic is not my car
Wildthings
Wildthings is offline
PostPosted: Mon Apr 09, 2018 9:26 am    Post subject: Re: Numbers matching Thing? Reply with quote
Do you have muffs (intake air ducts) on the sides of your engine compartment? No muffs would indicate it came without exhaust heat.
My first Thing was a 183*** with a post 8/73 build date and had a gas heater. It was originally registered as a '73, but when it was in a wreck the adjuster gave me credit for it being a '74.
