karlbrad878 Samba Member
Posted: Sun Apr 08, 2018 3:27 am Post subject: Found this in my rocker cover - What is it? |
Hi guys,
Just need a bit of help identifying this part.
I was doing a valve adjustment and this popped out of the rocker cover.
After doing some research it looks like part of a valve stem seal.
The engine is running fine, no unusual noises and it's only has 37k miles on it from new. It's not smoking either.
What's the worse case scenario if I drive it around with a missing valve stem seal (if it is that). It's my daily driver.
Thanks.
Karl. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Apr 08, 2018 4:42 am Post subject: Re: Found this in my rocker cover - What is it? |
looks like an old valve stem seal.
And none if it is an old valve stem seal. If you did a search as you say, that should have showed up _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4420 Location: Stuck in Ohio
Posted: Sun Apr 08, 2018 8:56 am Post subject: Re: Found this in my rocker cover - What is it? |
Ok, thanks for the input.
Karl |
scdevon Samba Member
Joined: October 18, 2017 Posts: 163 Location: Rockies
Posted: Sun Apr 08, 2018 9:55 am Post subject: Re: Found this in my rocker cover - What is it? |
Valve stem seals are pretty useless on these engines anyway and it's just one more thing to turn brittle and fall apart in the engine.
Most people just leave them out intentionally which is a good idea. _________________ 1970 Beetle 1600 DP |
mark tucker Samba Member
Posted: Sun Apr 08, 2018 11:43 am Post subject: Re: Found this in my rocker cover - What is it? |
Ive never seen one valve steel seal on a acvw. looks like you have possiably bolt on valve covers and that's a stud seal.I wouldent worry about it. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sun Apr 08, 2018 1:26 pm Post subject: Re: Found this in my rocker cover - What is it? |
The remains of a valve-stem seal . . .
look inside the springs and see if any other seals remain on any of the stems . . . if so, you might be able to remove them with a dental pick.
They are not critical and did not do much to "seal" the stem even when new.
As scdevon mentioned, they are rarely installed anymore.
Photos from TheSamba Gallery . . .
The book actually calls them "Oil Deflector Rings" . . . Shown as #5 . . .
_________________ Jesucristo es mi Seņor y Salvador! |
Posted: Sun Apr 08, 2018 2:21 pm Post subject: Re: Found this in my rocker cover - What is it? |
You've all been very helpful. Looks like I won't have to worry. Cheers.
I'll see if I can 'pick' out the rest of them (if any remain) on my next valve adjustment. |
