dkoesyncro Samba Member
Posted: Mon Apr 09, 2018 8:05 pm Post subject: LT wheel cylinders |
Does anyone know the facts, I'm interested? Im going to rehab my rear brakes and am curious if these cylinders fit the 14" brakes. I've read a lot of comments of folks using them, no details though! One comment said the slot was to large for the male end of the shoes. That's what I got...kinda lacks substance! |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10250 Location: N. Idaho
Posted: Mon Apr 09, 2018 8:14 pm Post subject: Re: LT wheel cylinders |
I don't know the facts, as in the differences between the LT/Vanagon's rear wheel cylinders bores, stroke, orifice sizes, fitment, etc. But I do know that brake components like wheel cylinders that literally determine the rear brake pressure profile are extremely precisely matched. Putting a rear brake cylinder in from another model vehicle is a total crapshoot, unless (such as may be the case here with the LT/Vanagon) it is the same rear wheel cylinder by coincidence.
So, I would urge you to purchase new Vanagon wheel cylinders rather than experiment with a random wheel cylinder.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
r39o Samba Polizei
Posted: Mon Apr 09, 2018 8:19 pm Post subject: Re: LT wheel cylinders |
They are one inch bore.
Only useful really with bigger front brakes. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Apr 09, 2018 8:29 pm Post subject: Re: LT wheel cylinders |
Wow thanks for the fast response...
I am running larger brakes, girling60 with 288 rotors with BMW booster. This alone was a marked improvement but now it's time to give the rear some attention. |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4094 Location: East Kootenay, British Columbia
Posted: Tue Apr 10, 2018 11:46 am Post subject: Re: LT wheel cylinders |
Buy some, install and report back!
Or you could go all out and replicate the Syncro 16" rear brakes, which are LT, although this will most likely be expensive as the parts are scarce. _________________ Currently:
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Gruppe B Samba Member
Posted: Tue Apr 10, 2018 8:03 pm Post subject: Re: LT wheel cylinders |
Just bought them!
Thanks for the post, been wanting to try these for a while |
Posted: Wed Apr 11, 2018 9:54 am Post subject: Re: LT wheel cylinders |
Gruppe B wrote: |
Just bought them!
Please report back after you get them installed. Be interesting to find out if you can tell the difference. _________________ Currently:
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Wed Apr 11, 2018 10:42 am Post subject: Re: LT wheel cylinders |
MsTaboo wrote: |
Or you could go all out and replicate the Syncro 16" rear brakes, which are LT, although this will most likely be expensive as the parts are scarce. |
That's what I did. Got the bearing housing and the backing plate (as well as a pair of 16 inch trailing arms) used from Oberschlachter in Finland. Bought the rest new. Also installed 312x25mm discs in the front. And the brakes feel great. Even with 245/75R-16 wheels I can easily lock the rear wheels on dry asphalt with the hand brake. _________________ 1991 VW Multivan syncro 1,9 TD |
Posted: Tue Aug 21, 2018 3:32 pm Post subject: Re: LT wheel cylinders |
I got 25mm LT wheel cylinders on ebay from a seller in Latvia or Poland can't recall. Came in under $60 shipped for a pair. I also bought semi metallic lined performance brake shoes from a vendor in LA, and Zimmerman rotors. I'm going to arc the shoes to the new drums I have access to an arc machine.
I'm hoping that rear upgrade balances well with 312x25 slotted rotors and G60 calipers with Hawk yellow ceramic pads. Using Epytec adapter brackets. _________________ Steve
Steve's 87 Syncro project |
