surf4444 Samba Member
Joined: July 13, 2015 Posts: 22 Location: Santa Monica, CA
Posted: Tue Apr 10, 2018 10:08 am Post subject: Where is the sink pump fuse? |
Does anyone know where and what the sink pump fuse looks like? Mine has worked fine since I purchased my Westy and all of sudden stopped pumping and I suspect its a fuse issue. Does anyone have a picture of what that looks like or any further advice? Thanks! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Tue Apr 10, 2018 10:20 am Post subject: Re: Where is the sink pump fuse? |
Is this it? If so, how do I go about changing those fuses and where do I get the replacements? I havent done this yet, thank you for the help! |
B.O.B.Wanders Samba Member
Joined: July 22, 2014 Posts: 351 Location: Atlanta, GA USA
Posted: Tue Apr 10, 2018 10:45 am Post subject: Re: Where is the sink pump fuse? |
That is a relay someone added. I don't have one there. At least in the older campers, the fuses for the sink and fridge are on the floor beside the driver's seat. It is a little black box with red wires. Unscrew the silver screw in the middle and you'll see the two fuses. One is 16 amp (red) and goes to the fridge, the other is 8 amp (white) and goes to the sink pump and LED lights on the stove panel. I can't ever remember which is in front without looking.
Are the stove panel lights working? Flip the toggle and see if the battery and water lights come on. If not, and they were before - that would suggest the fuse.
(edit) BTW - Mine are the old-style fuses and you can usually still find them at your FLAPS. The colors indicate the amperage. _________________ 83.5 WBX 2WD Assuan Brown Westy, B.O.B.
"It feels good to be lost in the right direction” - unknown
Last edited by B.O.B.Wanders on Tue Apr 10, 2018 10:47 am; edited 1 time in total |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Apr 10, 2018 10:47 am Post subject: Re: Where is the sink pump fuse? |
Not my photo, but the location & box are the same as on my '84:
Posted: Tue Apr 10, 2018 11:05 am Post subject: Re: Where is the sink pump fuse? |
Thanks guys! Here are couple more shots:
Posted: Tue Apr 10, 2018 11:16 am Post subject: Re: Where is the sink pump fuse? |
You might also mention what year that is - looks like it might be an air-cooled? |
Posted: Tue Apr 10, 2018 11:17 am Post subject: Re: Where is the sink pump fuse? |
Yes, it is a 1981 air cooled Westy |
kamzcab86 Samba Moderator
Posted: Tue Apr 10, 2018 11:19 am Post subject: Re: Where is the sink pump fuse? |
The '80-'81s have their camper equipment wired into the main fuse panel (Bentley manual page 97.32b). The sink pump goes to fuse 5. Fridge uses fuses 4 & 6. _________________ ~Kamz
2016 Golf GTI S
Posted: Tue Apr 10, 2018 11:36 am Post subject: Re: Where is the sink pump fuse? |
I just ran outside and replaced Fuse 5 but still nothing. Must be something else I suppose? I am heading into Mesa West for a big check up next week and I guess I can just tack that on to the list. Thanks for your help! |
Posted: Tue Apr 10, 2018 11:43 am Post subject: Re: Where is the sink pump fuse? |
surf4444 wrote: |
I just ran outside and replaced Fuse 5 but still nothing. Must be something else I suppose? |
Check for power at the pump connection. If power is there, could be a faulty pump. If no power, then there's something electrical gone bad between the pump and the fuse. _________________ ~Kamz
2016 Golf GTI S
jimf909 Samba Member
Posted: Tue Apr 10, 2018 1:10 pm Post subject: Re: Where is the sink pump fuse? |
As kamz said, start by using a voltmeter to check for 12 volts at the leads to the pump with the faucet turned on the faucet knob is actually an electrical switch that completes the circuit that sends power to the pump (at least that how it was in later years, I’m not sure about ‘81).
If there isn’t 12v at the pump the circuit can be incomplete at several places: connections throughout the circuit, faucet switch, fuse, etc.
If the pump was accidentally left on it may have been burnt out. This can happen when someone not familiar with the van pokes around or cleans and turns the faucet knob.
It can be fixed! _________________ - Jim
Abscate wrote: |
WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 141 Location: Canada
Posted: Tue Apr 10, 2018 1:40 pm Post subject: Re: Where is the sink pump fuse? |
In my '84, there is another, in-line fuse, near the pump, under the pump cover ("cover 1" on page 76.18 in Bentley).
It's one of those glass tube type fuses in a plastic twist case.
Bentley does not show the fuse I'm talking about, and it may have been an add-on by P.O., but looks "stock".
W _________________ Science has sacrificed Truth on the altar of its narrative. |
Posted: Tue Apr 10, 2018 7:12 pm Post subject: Re: Where is the sink pump fuse? |
If this is the blue cylindrical pump (like on my 84) it can get stuck - especially if it sat dry for awhile.
If it isn't stuck too bad you can often free it up by pulling it out (no need to disconnect anything) and flipping the impeller on the bottom. If the impeller breaks free and spins then try running the pump. |
OldSpice Samba Member
Joined: June 10, 2015 Posts: 178 Location: 87 syncro westfalia Subaru ez30
Posted: Sun Jun 13, 2021 9:29 pm Post subject: Re: Where is the sink pump fuse? |
Has anyone opted to wire these into a standard fuse box with the rest of their custom added accessories ? Not a fan of how tricky these fuses are to replace |
franrose Samba Member
Posted: Wed Jun 16, 2021 5:18 pm Post subject: Re: Where is the sink pump fuse? |
Does anyone know where I can by the small fuse box cover for the two fuses behind the drivers seat?? |
Posted: Thu Jun 17, 2021 5:50 pm Post subject: Re: Where is the sink pump fuse? |
OldSpice wrote: |
Has anyone opted to wire these into a standard fuse box with the rest of their custom added accessories? |
That's exactly what I did with a Blue Seas panel.
FWIW, after you remove the wires from the OEM fuse block, you can pull that small wire loom out of the larger main loom, where the two wires are individually spliced to their respective fridge/pump wires. (I.E., there is a lot of extra wire hiding in that main loom.) _________________ ~Kamz
2016 Golf GTI S
