Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Tue Apr 10, 2018 12:36 pm Post subject: How to install 12V gauges in a 6V system |
12V gauges can be used in a 6V system with a DC to DC converter. The converter seen in the pic is available on eBay. The 12V light in the gauge can be connected to the 12V output or the light switch if the bulb is changed to 6V.
The Volt gauge in the center is connected to the converter output. The other gauges are oil pressure, oil temperature and tachometer.
Note: The DC to DC converter output voltage must be adjusted to 13V before connecting it to the gauges.
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
Bryan67 Samba Member
Joined: January 01, 2003 Posts: 2942 Location: Fresno, Ca.
Posted: Thu Jul 19, 2018 5:35 pm Post subject: Re: How to install 12V gauges in a 6V system |
I have to ask... why are you using those digital gauges in that car? Or really any gauges in a stock VW like yours? I just think that look totally out of place. _________________ If you`re going to do something, do it right. |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Fri Jul 20, 2018 12:03 am Post subject: Re: How to install 12V gauges in a 6V system |
I made a similar solution.
But instrument lighting is still at 6V so is regulated together to the rest of original instruments.
My temperature sensors are on: intake manifold, air escaping from heads, and oil.
On the amperometer: I will prefer a 0-central instrument to have a good indication of charging-discharging of the battery.
With this you can also appreciate how, at idle, battery is DISCHARGED by generator, about 7A, with its reverse current. If also stop light are depressed the sensation is that a nightly use in a city of a 6V VW is very critical!
P.S. solid state regulators do not drain reverse current at idle. |
Posted: Fri Jul 20, 2018 2:36 am Post subject: Re: How to install 12V gauges in a 6V system |
For curiosity: where did you placed (or have in mind to place) the remaining 11 temperature sensors? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31385 Location: Hot Arizona
