airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Apr 11, 2018 8:29 am Post subject: EMPI Complete Axle Assembly teardown |
Last week I saw a splatter of CV joint grease near my starter, and a slight rumbling on left turns also told me it was time to dig in…
81,223 miles on these, according to my log book, and the boots are just starting to give up:
I never removed these axles from the car. I never cleaned and repacked them, and I never swapped them side to side. I did add a little grease one time to each joint when I had them partially disconnected for wheel bearing packing and transmission removal on separate occasions.
The balls looked brand new except for one which had a haze to the finish.
The ONLY visible damage was extremely localized; the rest of the joint had so little wear, so I'm a little disappointed that I won't be re-using the joints.
I don't know what causes that kind of acute pitting, but I'm guessing it was a metallurgical or casting flaw. Either way, I can safely say that these complete axle kits are a bargain at around $100 a pop, even if for how long the boots last compared to the horror stories of other brands.
www.airschooled.com |
sodbuster Samba Member
Joined: August 08, 2004 Posts: 1085 Location: wherever my baywindow takes me.
Posted: Wed Apr 11, 2018 9:04 am Post subject: Re: EMPI Complete Axle Assembly teardown |
CV joints are not cast. They are forged. I'll venture that they are also heat treated and surface hardend as part of the heat treating process. Different heat treating processes yeald different results. Hardening or softening depending on the process and need. That pitting is a result of the ball wearing through the surface hardness and getting into softer material underneith. At least that is the way I have always understood it. |
Posted: Wed Apr 11, 2018 9:08 am Post subject: Re: EMPI Complete Axle Assembly teardown |
I am also suprised that the EMPI boots lasted so long. The last set of those axles I installed the boots lasted less than six months and less than 3000 miles. I had held my old axles and repacked them with new boots and put the EMPI axles on deck for repair. |
Posted: Wed Apr 11, 2018 9:32 am Post subject: Re: EMPI Complete Axle Assembly teardown |
If those were Lobros, I would just swap them to the other side of the rig and run with them likely getting another 100K or more out of them. With EMPI's I would just replace them.
You might trying buying replacements with Autozone, Oreillys, or some other outfit that will give you a lifetime guarantee if you don't want to pay the price for Lobros.
Posted: Wed Apr 11, 2018 11:36 am Post subject: Re: EMPI Complete Axle Assembly teardown |
Thanks for the info, sodbuster!
Wildthings wrote: |
You might trying buying replacements with Autozone, Oreillys, or some other outfit that will give you a lifetime guarantee is you don't want to pay the price for Lobros. |
I “retired” the EMPI joints since I had my bus’ original CVs and axles stashed away for a day like this. The original joints spent a while in the Aeromech Commemorative Ultrasonic Cleaner and came out looking new except for some very smooth wear where the balls rode. There packed and installed already.
Robbie
aeromech Samba Member
Joined: January 24, 2006 Posts: 16970 Location: San Diego, California
Posted: Wed Apr 11, 2018 1:20 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
I'm actually hearing good things about Empi boots. I do remember Larry in OB saying his Autozone replacement axle CV's failed fairly quickly but maybe they weren't Empi? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
timvw7476 Samba Member
Posted: Wed Apr 11, 2018 1:33 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
Question for asiab3:
Are those EMPI boots on your latest axles?
80k+ till failure is muy bueno. |
Posted: Wed Apr 11, 2018 2:44 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
timvw7476 wrote: |
They are- I want to give them a shot since the complete axles EMPI boots lasted so much better than the crap parts I’ve seen come out of professional shops. Of course they are probably made in a different factory out of different compounds now though... And those miles weren’t all rainbows and butterflies...
Robbie
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2541 Location: Ocean Beach in Beautiful BLUE California
Posted: Wed Apr 11, 2018 3:10 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
aeromech wrote: |
I'm actually hearing good things about Empi boots. I do remember Larry in OB saying his Autozone replacement axle CV's failed fairly quickly but maybe they weren't Empi? |
Yep...actually it was O'Reilleys (not labeled EMPI) axle assembly boots that failed quickly. The EMPI one I put on has been fine for......a year? Two years? I don't really remember.
The EMPI axle just seemed like a more substantial product than the one from O'Reilleys. I did pump an extra little tube of CV Joint grease in between the balls and races before assembling them. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
Posted: Wed Apr 11, 2018 6:09 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
asiab3 wrote: |
timvw7476 wrote: |
Robbie
Is that a Border Patrol vehicle on your ass? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
SGKent Samba Member
Posted: Wed Apr 11, 2018 7:26 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
aeromech wrote: |
Is that a Border Patrol vehicle on your ass? |
no - it is Colin trying to get his tools back............ _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Wed Apr 11, 2018 8:30 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
aeromech wrote: |
I'm actually hearing good things about Empi boots. |
I just rebuilt my axles last weekend. I got 40k out of a set of EMPI boots. I used new EMPI boots on the axle rebuild and reused the 4 LOBRO CVs dated 3/68. EMPI does make something good, just not everything. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
wcfvw69 Samba Purist
Posted: Wed Apr 11, 2018 8:48 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
My 69 bug I've owned for 20 years. It has the original VW CV joint boots on them. They are still perfect almost 50 years later.
For full transparency, the bug has probably 150k total miles on it with only 8k in the last 20.
Sad that we can buy that quality of boot 50 years later... _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Wed Apr 11, 2018 9:51 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
EMPI boots went unavailable a while back, maybe 6-8 years ago. I think the quality dropped badly for a while once they became available again. I think the boots on my 83 1/2 Vanagon are EMPIs, they are maybe 12-14 years old and failing badly at this point. Maybe 100K miles on them. |
Posted: Wed Apr 11, 2018 10:10 pm Post subject: Re: EMPI Complete Axle Assembly teardown |
SGKent wrote: |
aeromech wrote: |
no - it is Colin trying to get his tools back............ |
Ha! It's actually Ranger Solomon from Death Valley National Park. We've known each other since middle school, and he was on the inaugural trip where Buddy the Bus got his name…
Going in for the requisite re-torque today… We'll see if my whacky non-VW-approved torque technique works for these guys or if the retorque shows some creep.
Posted: Fri May 18, 2018 11:58 am Post subject: Re: EMPI Complete Axle Assembly teardown |
sodbuster wrote: |
I am also surprised that the EMPI boots lasted so long. The last set of those axles I installed the boots lasted less than six months and less than 3000 miles. I had held my old axles and repacked them with new boots and put the EMPI axles on deck for repair. |
Update; I installed the original set of axles back into my single cab early last year when I installed the rebuilt transaxle. Repacked with new boots. I have not driven it in a few months because I was busy with the engine rebuild on my camper and once done I was out on the weekends enjoying it.
Well last weekend I got the single cab out to give it the once over, because I need to use it this coming weekend for a bicycle show. I got it in the driveway and started crawling around underneath checking things. sure enough all four boots installed a year ago were shredded crap!
I decided to give the EMPI boots another go. I went and picked up four EMPI CV boot kits and repacked the set of EMPI axles I had removed from the truck last year. I installed them last Wednesday.
The EMPI CV's looked fine when I went through everything and put it back together with the new EMPI boot kits. I am taking a wait and see attitude on this round. Lets see how this plays out, stay tuned. |
69BahamaYellow Samba Member
Joined: April 22, 2011 Posts: 537 Location: Talbott, TN
Posted: Sat May 19, 2018 5:18 am Post subject: Re: EMPI Complete Axle Assembly teardown |
Back in 2012 or 2013, I went through multiple sets of complete axle assemblies from Advanced Auto that would only last maybe 3-6 months, before they started knocking in turns. They came with lifetime warranties, and were around $100 for a complete axle, so I figured it was a safe bet. Man was I wrong. No warranty is worth the trouble of replacing those things once or twice a year, so I finally gave up and returned them for a full refund and just applied that toward some quality lobro joints. Those have never given me a bit of trouble, but I was not so lucky with boots. I think they're starting to get better with the neoprene ones, but still nothing close to OEM service life.... |
Posted: Sat May 19, 2018 8:10 am Post subject: Re: EMPI Complete Axle Assembly teardown |
69BahamaYellow wrote: |
The OEM service life was no where near as good as many like to make out. I bought a '73 Thing with low mileage back in the mid 70's, IIRC two of the boots had already been replaced at that time. |
