slave1pilot Samba Member
Joined: February 22, 2010 Posts: 1152 Location: Yuba City CA
Posted: Wed Apr 11, 2018 1:07 pm Post subject: HELP! I need a template for the front turn signal location |
my 63 bug has had the front turn signals removed and welded over (very common)
and I want to reinstall the signals.
But I don't know exactly where to drill the holes or the sizes of the holes.
does anyone have a template to locate them?
Thanks in advance. _________________ Currently:
1959 pan with a 64 body and a 63 ragtop grafted in Herbie replica
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11211 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Wed Apr 11, 2018 1:19 pm Post subject: Re: HELP! I need a template for the front turn signal location |
Like... this one?
https://www.thesamba.com/vw/archives/manuals/techbulletins/e12.php
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Wed Apr 11, 2018 2:13 pm Post subject: Re: HELP! I need a template for the front turn signal location |
I couldn't find that using the terms I was trying.
I would have actually liked a template to lay over the fender, but can measure and mark I suppose. _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7452 Location: Clyde, TX
Posted: Wed Apr 11, 2018 2:17 pm Post subject: Re: HELP! I need a template for the front turn signal location |
| slave1pilot wrote: |
I would have actually liked a template to lay over the fender, but can measure and mark I suppose. |
Using the measurements provided above, draw up a template you can lay over the fender. Problem solved.  _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36316 Location: Conejo Valley, CA
Posted: Wed Apr 11, 2018 4:31 pm Post subject: Re: HELP! I need a template for the front turn signal location |
No paper template could lay over the fender... one is flat, the other curved in multiple axes.
Jeez, I thought you were pretty well served, with an official diagram posted within 12 minutes!  |
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Thu Apr 12, 2018 8:52 am Post subject: Re: HELP! I need a template for the front turn signal location |
| They didn't all come from factory perfectly placed. I have OG fenders on my 63 that were stripped before repaint and the signal is noticeably closer to the hood than the other side. And they weren't re-drilled. This was the factory placement. My 62 has its original fenders and they seem to be the same. Must have been a Monday morning hangover part. |
Posted: Thu Apr 12, 2018 10:50 am Post subject: Re: HELP! I need a template for the front turn signal location |
I took an original left front fender (that came with the holes punched) and did a rub technique on a sheet of 8 1/2 x 11 paper that I placed on the fender.
I was able to get a decent template started .
I gotta work with it a little and clean it up. It's just a scanned image that's still in pencil.
Just in case someone else comes on here looking for an actual template instead of snarky comments
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Thu Apr 12, 2018 11:35 am Post subject: Re: HELP! I need a template for the front turn signal location |
Would be nice to have these for all the holes. Turn signal, bumper override supports, taillights. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Thu Apr 12, 2018 11:48 am Post subject: Re: HELP! I need a template for the front turn signal location |
I concur.
The turn signal holes are useful as the remanufactured fenders don't normally come with the holes in place.
I know they change over the years, so I assume that's why they aren't pre-punched. _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Posted: Thu Apr 12, 2018 12:27 pm Post subject: Re: HELP! I need a template for the front turn signal location |
Just in case someone else comes on here looking for an actual template instead of snarky comments |
Oh the Burn ...
I would even think some templates with strips of material would work fine.. just need point of reference..
. _________________ aka Ken {o\!/o}
Last edited by VOLKSWAGNUT on Thu Apr 12, 2018 12:34 pm; edited 2 times in total |
mukluk Samba Member
Posted: Thu Apr 12, 2018 12:34 pm Post subject: Re: HELP! I need a template for the front turn signal location |
| VOLKSWAGNUT wrote: |
Oh the Burn ...
I was thinking blue painter's tape. You could lay it down pretty easy on the one fender, measure and mark where the holes need to be, drill/cut said holes right through the tape mask, then easily peel it off and transfer over to the other side needing only to measure the distance from the headlight ring back and inner fender edge outward to get it positioned the same. An added bonus is if the fenders are a bit off from side to side, just peel it back up and reposition until it looks right. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Thu Apr 12, 2018 12:36 pm Post subject: Re: HELP! I need a template for the front turn signal location |
| mukluk wrote: |
| I was thinking blue painter's tape.. |
and.. I was thinking Yellow Frog painters tape.. for delicate surfaces.
that stuff peels easy..
Having a known original fender as the guide.. is key
I assumed.. slave1pilot.. didn't have a fender for reference.. ?? ??
Hence the referenced bulletin measurements..
KTPhil  Samba Member
Posted: Thu Apr 12, 2018 1:16 pm Post subject: Re: HELP! I need a template for the front turn signal location |
<Snarky warning>
Why not just print the manual page provided (within 700 seconds of your request), scaled to become the template you oh so deservingly ask for? That probably would have taken less time than posting a whine here. You have to print and scale the "template" provided lower in the thread anyway.
Or maybe you'd like one printed for you and hand delivered? Sort of Samba Prime Expedited Delivery? That's what we are here for, after all.
<end snarky> |
Posted: Thu Apr 12, 2018 1:27 pm Post subject: Re: HELP! I need a template for the front turn signal location |
That's the thing.
The diagram you linked gives dimensions to everything with a single starting point. The center of the headlight housing.
As the housing is round, bisecting it can be done at any angle.
so, ultimately I marked one side with the dimensions in the linked image but also used the homemade template to match the other side.
it was still a PITA but now I have matching holes. _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
Posted: Thu Apr 12, 2018 1:32 pm Post subject: Re: HELP! I need a template for the front turn signal location |
| KTPhil wrote: |
<Snarky warning>
<end snarky> |
I'm not quite the primadonna that you guys seem to want to make me out to be.
As I stated, I was unable to find that page myself (using the terms I tried) using the search function. Hence my query (read: whine) regarding a template that might already exist. I also have explained that the dimensions aren't all-inclusive .
the donor fender I used for the pencil template was of an unknown year and I wasn't certain that the dimensions stayed the same . _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
Corney13 Samba Member
Joined: July 06, 2014 Posts: 265 Location: Castaic, California
Posted: Fri Apr 13, 2018 11:02 am Post subject: Re: HELP! I need a template for the front turn signal location |
| I did not see this right away. Did you cut the holes? We can make a template off of one on my fenders. They are 63 correct. Or I could take some measurements to verify your positions. |
Posted: Fri Apr 13, 2018 3:38 pm Post subject: Re: HELP! I need a template for the front turn signal location |
PM sent. _________________ Currently:
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
