Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sun Aug 19, 2018 12:02 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Re using some ones old panels. Love the pockets on earlier door panels.
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
Skim Rants Master
Posted: Sun Aug 19, 2018 6:38 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
obus wrote: |
those were some great swap scores there Skim! |
Yeah man I think the Okrasa heads are pretty much sold.
This week I should have the rest of the door panels on. Then realized I still gotta weld on the middle seat tabs to the floor - even though I don’t have one for it yet. I’ll probably need to pull that long panel off. I really need to clean them really good. _________________ GFK
1953 Kabriolet
1954 Sunroof
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Aug 21, 2018 10:01 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Skim wrote: |
obus wrote: |
This week I should have the rest of the door panels on. Then realized I still gotta weld on the middle seat tabs to the floor - even though I don’t have one for it yet. I’ll probably need to pull that long panel off. I really need to clean them really good. |
back in my beetle days i would have loved to have a pair of those 40horse Okrasa heads. _________________ regards
Uli
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Tue Aug 21, 2018 4:25 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Bus is looking sweet!! That paint blending on the wheel wells turned out killer. _________________ Brandon |
Skim Rants Master
Posted: Fri Aug 24, 2018 6:05 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
oakman wrote: |
Bus is looking sweet!! That paint blending on the wheel wells turned out killer. |
Thanks brotha I’m still trying to find a few odds & ends. Wanted to work on it this weekend but I’m going to the show in Eureka Springs so I’ll have to wait till I get back. _________________ GFK
1953 Kabriolet
1954 Sunroof
WildIdea Samba Member
Joined: September 17, 2016 Posts: 928 Location: Black Hills, South Dakota
Posted: Thu Aug 30, 2018 7:56 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
I have to say, thanks for posting your builds. I've said it before, your El Pavo thread initially gave me the notion to try some rust repair and paint blending on a split myself.
You had mentioned that the turqis color had given you some fits and that you worked through them with your supplier and kept at it and I think we would all agree it came out sweet. Especially on the long wall that I would venture to say is the toughest spot to blend. So exposed and out there visually.
With that said, I have been thinking that my SWR bus would be an easier color to work within I found out it is not as easy as I would have initially thought. I've been watching this build and Burlyhammers SWR build and actually afraid to open up the updates and see you guys breeze through the projects while I falter. I admit I took a little comfort in your admission that the SWR color is a tough one to deal with as well.
I will give a little back story without hijacking, so no pictures of mine here, but I started cutting out the rust on my patina 65 over New Years break this year and had slowly and methodically replaced the sections with funky green and around July was finished with the filler and prep. I had a flawless application of grey primer and all was going well. When I shot he paint, it was just not the right color. A kind of rose color with a clay terra cotta look to it. It was just all wrong.
In hind sight, I realize that the pieces I had cut off the bus and taken into to be read had a film of oxidization and the reader must have picked up some of that. We all said it was just too far off to live with and decided to go for a second attempt. I also believe I had polished the paint on the long wall simply wiping it down each time I cleaned up between filler sand sessions, changing the look and removing the oxidization as well, which really brought out the red in the paint.
So my paint shop has some great guys and its a decent size company that has stores all over the state. They said they had a dif type of paint reader getting shipped from Sioux Falls and that they would like to try that reading directly on the bus along the long wall where I'm blending. If you look close, the paint changes ever so slightly from the belt line to the rocker, with a bit of primer showing at the top and having thicker paint lower. Likely from its exposure to the elements and how that played out on the curvature. Sounded good to me, and right around then I had to bail on the project to work the 3-4 weeks of Sturgis bike week, so I said take your time. They had fits getting the reader to work, it is a remote handheld deal that talks to a tablet and needs wifi to work and there was def a learning curve, but after a few days they said I had some paint to pick up. They were really into my project and super cool to have support like this.
Anyway, I sanded it all down and remasked the project and got it shot last night. Looks killer. Well worth the second effort. The break did me some good too and I'm back to staring at this bus and amazed at how cool it is and loving it. I have to say, all of these projects have steps that can take me few times to master but it pays to not get frustrated and keep hammering and not cut corners. I always joke that my next bus will be better, but it's true. At least I'll have some experience and some tricks. These things are quite a challenge and I appreciate the roadmap you and others have left for me to follow. |
p horvath Samba Member
Joined: December 29, 2003 Posts: 1225 Location: south carolina
Posted: Fri Aug 31, 2018 9:25 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
updates????????????? |
Skim Rants Master
Posted: Sun Sep 02, 2018 8:02 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
@WildIdea thank you. I’m glad it helped motivate you. I’ve been inspired by so many others in here too. _________________ GFK
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Sep 02, 2018 8:03 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Reassembled the original bumper with new guards.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Sep 02, 2018 10:05 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Welding up two extra gauge holes in the dash
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Sep 02, 2018 10:52 am Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Sep 02, 2018 12:51 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
One down one to go
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Sep 02, 2018 2:22 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Hole #2 gone. Had an old EMPI amp gauge here.
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Sun Sep 02, 2018 3:14 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Much better
1953 Kabriolet
1954 Sunroof
Dubskii Samba Member
Posted: Sun Sep 02, 2018 10:00 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
That looks damn good! Did you skim coat those as well and then paint? _________________ 69 Sunroof Deluxe - Montana Red/Cloud White (Sold)
57 Kombi - Dove Blue http://www.thesamba.com/vw/forum/viewtopic.php?t=648240
WTB Early Dove Blue Bus Driver's Side Door
WTB Joe Heishman VW Arlington, VA License Plate Frame or Other Memorabilia |
western auto Samba Member
Posted: Sun Sep 02, 2018 11:06 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
little oops on that speedo pod... |
Skim Rants Master
Posted: Mon Sep 03, 2018 1:22 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
western auto wrote: |
Gotta little buck wild with the roll-loc disc _________________ GFK
1953 Kabriolet
1954 Sunroof
Skim Rants Master
Posted: Mon Sep 03, 2018 1:24 pm Post subject: Re: Out of Sheer Boredom. Metalwork on a 62 15 window. |
Dubskii wrote: |
That looks damn good! Did you skim coat those as well and then paint? |
Little primer wet sand and rattle can _________________ GFK
1953 Kabriolet
1954 Sunroof
mdege Samba Member
Joined: January 16, 2018 Posts: 939 Location: Niederkruechten, Germany
