ELFRIED Samba Member
Posted: Thu Apr 12, 2018 6:05 am Post subject: How to remove nose grill ? |
anyone knows how to remove the nose grills?
I see 2 phillips scews which I could remove but nothing comes loose ???
thanx |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Thu Apr 12, 2018 8:19 am Post subject: Re: nose grill |
Although I've never done that job myself, instructions for removing the fresh air inlet trim can be found on page A-67 of the 1960 VW Karmann Ghia Shop Manual - Body Section (which can be found here in The Samba Technical Archives under the Karmann Ghia Owner's Manual section). |
c21darrel Samba Member
xzener Samba Member
Posted: Thu Apr 12, 2018 9:07 pm Post subject: Re: nose grill |
Nurse... Scalpel! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Fri Apr 13, 2018 1:51 am Post subject: Re: nose grill |
thanx all, as I understand I ll have to get them out at the front and not from inside.... |
NWGhiaGuy Samba Member
Joined: March 16, 2005 Posts: 700 Location: Bellingham, WA
Posted: Sat Apr 14, 2018 6:59 am Post subject: Re: nose grill |
If it's a 1960 model, there is a third screw at the top!! |
Posted: Sat Apr 14, 2018 8:46 am Post subject: Re: nose grill |
no it s a 63 model |
amjady Samba Member
Posted: Sat Apr 14, 2018 5:15 pm Post subject: Re: nose grill |
There is a small tab on the side opposite the screw also. Be careful not to bend or break when you pull it forward. If you start pulling it forward on the screw side you should be safe (speaking from experience on a 71) |
Posted: Sun Apr 15, 2018 11:12 am Post subject: Re: nose grill |
I see
thanx this week I m gonna try to take them out carefully..... |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Thu Apr 19, 2018 7:08 pm Post subject: Re: nose grill |
IDK if it works on Ghia grilles but to remove the plastic vents in the dash of a mkI/II, I would bend two tight 90* in the end of a coat hanger with a pair of needle nose & insert it into the vent , turn it 90* & hook the back of one of the slats & pull them out that way. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Apr 20, 2018 8:14 am Post subject: Re: nose grill |
anyone has a picture of the back side of the grill ?
a picture tells more than 1000 words hm..... |
Posted: Fri Apr 20, 2018 10:37 am Post subject: Re: nose grill |
wow thanx a lot
this is what we needed , i know understand how it is hooked... |
Artistic gearhead Samba Member
Joined: June 26, 2022 Posts: 86 Location: Vancouver Island
Posted: Wed Aug 02, 2023 12:20 pm Post subject: Re: How to remove nose grill ? |
Thankyou for this post. Super helpful. |
