nacradriver Samba Member
Joined: January 15, 2009 Posts: 760 Location: Ventura, CA
Posted: Thu Apr 12, 2018 7:53 am Post subject: Years Most Prone to Fail |
In my quest to find a good EV have a few questions regarding the Eurovan... timing chain, water pump, and transmission as these seem to be the "big ticket" repair items.
First, lets take the 93-95 vans off the table... I know they are tanks... and most of their quirks are with the body and electrical components.. If I could find a clean 93 with a manual transmission it would already be sitting in my drive way... Sadly most of them, at least the ones I have seen are a little long in the tooth. But I am still looking
That said, lets dive into it for models year's 1999 to 2003
Transmission.. are there specific years that are prone to the failure? Reading around I know it was a quality control issue, and I am assuming the later years 2002-2003 maybe this was caught or is this across the whole run? Also does the 24 valve engine add to this problem...
Timing Chain is this specific to the 12 or 24 valve engine? Seems that many of the 2002-2003 sellers I am talking with mentioned having that work done.
Water Pump - haven't met a VW yet that doesn't have this problem... but again is the problem specific to a year or across the whole run? I know for a while they were using plastic impeller on the Vanagons... same issue here?
That is all for now.. _________________ Güdrun -1989 Westfalia - 2013 - 2018
Petra - 1985 Vanagon - 1985 to 1991
Zisa - 1974 VW Van "Bus" - 1974 to 1985 |
Zeitgeist 13 Samba Member
Posted: Thu Apr 12, 2018 8:08 am Post subject: Re: Years Most Prone to Fail |
I'm not sure what the problem is with the H2O pump you've heard about, but I've got to say that it's got to be just about the easiest unit to R&R I've ever encountered.
I believe all of the autos are prone to "issues", though there are many examples from all years that have made it to 200k.
I would just plan on buying a VR6 model that has had the timing chains replaced, or factor that task upon purchase, especially if the vehicle has 150k or more. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
mvaska Samba Member
Joined: February 26, 2015 Posts: 135 Location: United States
Posted: Thu Apr 12, 2018 9:09 am Post subject: Re: Years Most Prone to Fail |
water pump issues in 99-03 are one of those phantoms. you hear far more about people replacing them than you do about actual failures. they are cheap and easy to replace is perhaps why.
transmissions; a lot of this concern stems from articles RE catastrophic failures due to manufacturing defects. now that the fleet in the US is getting older these defective transmissions are (completely?) fixed/gone.
failures now are due to lack of appropriate maintenance in terms of : overheating (stock heat exchange can't handle more extreme heat situations) or worn out fluid or valve body issues. often these issues are interconnected; for example: a little extra heat breaks down the fluid which causes more heat which impacts the valve body solenoids which causes even more heat.. etc. etc.
point: get a van that still shifts well when good-n-hot and then take good care of it.
chains; it's not the chains as much as the guides and sprockets that wear so quickly. in 99-mid 02 some intermediary sprockets were too soft. overheating, bad oil/filter, sludge.. all impact guide wear. |
Chi-town Samba Member
Joined: February 06, 2017 Posts: 22 Location: Disneyland
Posted: Thu Apr 12, 2018 1:10 pm Post subject: Re: Years Most Prone to Fail |
nacradriver wrote: |
First, lets take the 93-95 vans off the table... I know they are tanks... and most of their quirks are with the body and electrical components.. If I could find a clean 93 with a manual transmission it would already be sitting in my drive way... Sadly most of them, at least the ones I have seen are a little long in the tooth. But I am still looking |
My 93' 5 speed is exactly that, a tank, reliable as hell but still a tank |
volkybus Samba Member
Joined: November 03, 2013 Posts: 481 Location: CASTLETON VT USA
Posted: Fri Apr 20, 2018 6:34 pm Post subject: Re: Years Most Prone to Fail |
I have a 93 weekender ,5 speed for sale ! These vans are trouble some compaired.to a bay which I've had several but , Eurovans are nice to.drive n very comfy
I'm asking $5 grand and a parts van is avable also
The first one orginally came from Cafornia , The van is in Puerto Rico an will cost a grand to ship to JAX ONLY Problem is it keeps fouling plugs w carbon. I live here in winter m Vt. The rest of the year. thanks VW BILL PS I'M A CARB MAN ONLY |
