Solar install suggestions
Page: 1, 2, 3  Next
physast
physast is offline
PostPosted: Thu Apr 12, 2018 5:37 pm    Post subject: Solar install suggestions Reply with quote
Hello all. I just purchased a 100 watt solar panel and charge controller. I have what I think is two options for my install.
1) connect directly to the house battery
2) back feed through my blue seas fuse panel.
Anyone install using the back feed method? I have a NOCO Genius charger and a yandina battery splitter.
Anyone reason to pick one install over the other?
1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L
shagginwagon83
shagginwagon83 is offline
PostPosted: Thu Apr 12, 2018 5:42 pm    Post subject: Re: Solar install suggestions Reply with quote
I charge through my fuse block because, well fused.
Brandon
Instagram @joannthevan
dobryan
dobryan is offline
PostPosted: Thu Apr 12, 2018 6:08 pm    Post subject: Re: Solar install suggestions Reply with quote
I connected from the charge controller to the house battery.
Dave O
The Western Syncro build
jimf909 Premium Member
jimf909 is offline
PostPosted: Thu Apr 12, 2018 6:27 pm    Post subject: Re: Solar install suggestions Reply with quote
I’m 99% certain I used this path:
Solar panel >>> fuse panel >>> battery (and other items connected to the fuse panel)
I also have an in-line fuse a few inches away from the battery post should the batt. cable somehow connect to ground in the run to the fuse panel.
I can’t tell you if this is an optimal arrangement.
- Jim
Abscate wrote:
RichBenn
RichBenn is offline
PostPosted: Thu Apr 12, 2018 7:28 pm    Post subject: Re: Solar install suggestions Reply with quote
What do you mean by the "backfeed" method? I'm an electronics engineer and have not heard of it.
Rich
shagginwagon83
PostPosted: Thu Apr 12, 2018 7:54 pm    Post subject: Re: Solar install suggestions Reply with quote
Basically OP wants to know if it's okay to charge aux battery by going into fuse panel to battery. Like I have in the diagram top left.
Brandon
physast
physast is offline
PostPosted: Fri Apr 13, 2018 7:34 am    Post subject: Re: Solar install suggestions Reply with quote
Yes by back feeding I am just implying going through the fuse panel.
I think I will do an install directly at the battery. If I go through the fuse panel then I would be charging both the house and starter battery correct?
The solar panel is for camping and I want all power going to the house batteries.
shagginwagon83
PostPosted: Fri Apr 13, 2018 7:41 am    Post subject: Re: Solar install suggestions Reply with quote
Well is your fuse panel powered by both batteries? It's hard to say if it will charge both batteries without a wiring diagram.
Brandon
physast
physast is offline
PostPosted: Fri Apr 13, 2018 8:07 am    Post subject: Re: Solar install suggestions Reply with quote
Good point. I will need to double check. I know both batteries are charged by the alternator. The fuse panel is likely just house battery.
physast
physast is offline
PostPosted: Fri Apr 13, 2018 8:08 am    Post subject: Re: Solar install suggestions Reply with quote
Do you guys have an on/off switch connected to the charge controller so that the battery is not running the controller when you do not have the solar panel connected?
shagginwagon83
PostPosted: Fri Apr 13, 2018 8:23 am    Post subject: Re: Solar install suggestions Reply with quote
Well in the setup I posted - when the engine is running, the relay gets a signal to turn on the SI-ACR (combine battery) unit. The unit then detects a higher voltage for 30 seconds on the starting battery - then combines the battery.
However when strictly solar charging with the engine not running - it just charges the house battery.
The solar charger should have little vampiric drain when not in use. My solar charger is bluetooth and I leave it always running.
Brandon
RichBenn
RichBenn is offline
PostPosted: Fri Apr 13, 2018 8:24 am    Post subject: Re: Solar install suggestions Reply with quote
Fues exist to limit current to what the wiring can handle. Fuse boxes can be single source (like house battery) or individual(where you wire to each individually). You should NOT have the two batteries connected through the fuse box in any way. The ones we use are not typically rated for either the wire size or current that could happen when the batteries are connected.
I prefer to connect my battery to the solar controller through a fuse, (the fuse located close to the battery), then from the battery to the fuse box, which is a single input type. But everything connected to the fuse box is separate from the circuits that run off the starter battery.
Rich
dobryan
dobryan is offline
PostPosted: Fri Apr 13, 2018 8:25 am    Post subject: Re: Solar install suggestions Reply with quote
No switch on mine. No issues either.
It sounds like you may be over thinking this.
The easy way is to hook the solar controller directly to the house battery and let the battery isolator/combiner do its job of combining the starting and house batteries when there is a charging source on either one (solar or alternator) and separating them when there is not.
I do have a switch on my yandina that allows me to force a separation even if there is a charging source for when I want the solar to only go to the house batteries.
Dave O
RichBenn
RichBenn is offline
PostPosted: Fri Apr 13, 2018 9:30 am    Post subject: Re: Solar install suggestions Reply with quote
I do the same for mine, although I have enough solar that I leave them separated 99% of the time. You can also force connect them, which I’m sure you know, which could be usefull if the starting battery is flakey.
Rich
kamzcab86
kamzcab86 is offline
PostPosted: Fri Apr 13, 2018 10:02 am    Post subject: Re: Solar install suggestions Reply with quote
No switch. However, when my van is parked in the garage, it gets plugged into AC power, which keeps the battery charged up via the NOCO.
As for the original question, you can do it either way, but I went with the direct-connect route with a separate in-line fuse.
~Kamz Anxious
2016 Golf GTI S
0to60in6min
0to60in6min is offline
PostPosted: Fri Apr 13, 2018 10:09 am    Post subject: Re: Solar install suggestions Reply with quote
my solar installation is this:
solar panel -> fuse -> charge controller -> fuse -> aux. battery -> fuse -> fridge or other devices.
no on/off switch because the current goes one way only from charge controller to battery.
Wendy.the.Westy
Wendy.the.Westy is offline
PostPosted: Fri Apr 13, 2018 7:00 pm    Post subject: Re: Solar install suggestions Reply with quote
What model charge controller are you using? Some solar charge controllers have a dedicated port for loads which allows it to charge the battery while maintaining a regulated 12V for the load connections.
If your charge controller only has two ports, one for the PV module and another for the battery then either way will work. That being said, best practice would be to connect the charge controller directly to the battery and only connect loads to your fuse panel. This makes it easier to service the fuse panel or the connected loads in the future because removing all lugs on the positive terminal of the house battery removes all voltage sources from the house loads. ie. more intuitive for others that might work on your equipment.
ID.BUZZ
Steve M.
Steve M. is offline
PostPosted: Sat Apr 14, 2018 5:18 am    Post subject: Re: Solar install suggestions Reply with quote
Just a thought on what else might be connected to the fuse panel and drawing power while you are trying to charge the batteries?
JudoJeff
JudoJeff is offline
PostPosted: Sat Apr 14, 2018 5:34 am    Post subject: Re: Solar install suggestions Reply with quote
Just a note to say purchase top of line controller. $50 one failed and burned down my 89 Westfalia.
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout)
jimf909 is offline
PostPosted: Sat Apr 14, 2018 7:44 am    Post subject: Re: Solar install suggestions Reply with quote
It hurts a bit to hear that story again.
Have you purchased a charge controller since and if so, what did you get?
Thanks.
- Jim
Page: 1, 2, 3  Next
