JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Sat Apr 14, 2018 8:23 am Post subject: Re: Solar install suggestions |
Will never add solar again. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
kamzcab86 Samba Moderator
Posted: Sat Apr 14, 2018 10:28 am Post subject: Re: Solar install suggestions |
JudoJeff wrote: |
Will never add solar again. |
Totally understand your decision, but remember that portable panels come with controllers mounted to the panels. While some of us have removed those controllers to mount inside our vans, the safer route would be to leave them as-is (mounted to the panels). Thus, if the controller should melt down, it won't be inside, it'll be outside and away from the van. _________________ ~Kamz
2016 Golf GTI S
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Sat Apr 14, 2018 10:36 am Post subject: Re: Solar install suggestions |
after a fair amount of $$ spent, my experiences with solar panel are about 50% (or less) than I expected...
on my trips I use shore power whenever I could... |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Sat Apr 14, 2018 11:03 am Post subject: Re: Solar install suggestions |
No offense to anyone doing it this way but I don't understand why anyone would want to run their solar arrangement through the vehicle fuse panel if that's what is being proposed. It adds an unnecessary level of complexity and increases the odds of fire. To charge a battery run it directly to that battery. If desiring to charge two batteries simultaneously then use a splitter.
My set-up is similar to several on here. Mobile Renogy 100w dual panel with controller on the back. Plug in to aux battery when ready (and engine not running). If there's a fuse it's built-in along that line somewhere. Very simple/stupid |
Posted: Sat Apr 14, 2018 9:09 pm Post subject: Re: Solar install suggestions |
WestyBob wrote: |
No offense to anyone doing it this way but I don't understand why anyone would want to run their solar arrangement through the vehicle fuse panel if that's what is being proposed. |
We're talking about a Blue Seas auxiliary fuse panel, not the van's factory fuse panel. _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Apr 14, 2018 9:15 pm Post subject: Re: Solar install suggestions |
kamzcab86 wrote: |
We're talking about a Blue Seas auxiliary fuse panel, not the van's factory fuse panel. |
Ok thanks - got it. But question still stands. Why bother ? In-line fuse, direct run solar to powered item(s). |
kbeefy Samba Member
Joined: March 10, 2006 Posts: 600 Location: Central Oregon
Posted: Sat Apr 14, 2018 9:23 pm Post subject: Re: Solar install suggestions |
Agree. Fuses are after the battery in my arrangement. _________________ 86 syncro CHC, NorthWesty subbie 2.5, decoupler, locker, custom interior, 225/75r16 Duratrack's on CLK's, Toyo cabin heater, ARB fridge, 300w Zamp Solar, Gowesty bumpers/skid/rails, Fiama awning
'86 Syncro Westy. Stock for now.
2000 F350 7.3 CC LB 11' Northland Cabover
2006 Subbie OBXT
2002 Tacoma DoubleCab 4x4
1969 Mustang Basket Case 351c/FMX/9
http://kbeefy.blogspot.com/ |
Multiman mv Samba Member
Joined: January 24, 2017 Posts: 987 Location: Martha's Vineyard, Ma
Posted: Sun Apr 15, 2018 5:37 am Post subject: Re: Solar install suggestions |
JudoJeff wrote: |
Just a note to say purchase top of line controller. $50 one failed and burned down my 89 Westfalia. |
Do you know what condition led to the failing of the controller and or wiring? Did you have an in line fuse between the panel and controller? My controller directions recommended a fuse between panel and controller. This always puzzled me as the wiring was set up for a direct connection to the controller. One would have to cut the stock wiring to connect an in line fuse. Did you have an in line fuse between controller and battery? Was the wattage of the panel too high for the controller or was this simply a defective controller? I guess the only reason why I ask is to help prevent the same experience with someone else’s solar set up.
Sorry to hear about your van. I would certainly be in your camp if I experienced what you did with a solar set up. I wouldn’t touch it with a ten foot pole. I hope you’ve been able to rebuild or find a new van. |
Posted: Sun Apr 15, 2018 6:01 am Post subject: Re: Solar install suggestions |
physast wrote: |
shagginwagon83 wrote: |
physast wrote: |
Yes by back feeding I am just implying going through the fuse panel.
I think I will do an install directly at the battery. If I go through the fuse panel then I would be charging both the house and starter battery correct?
The solar panel is for camping and I want all power going to the house batteries. |
Well is your fuse panel powered by both batteries? It's hard to say if it will charge both batteries without a wiring diagram. |
Good point. I will need to double check. I know both batteries are charged by the alternator. The fuse panel is likely just house battery. |
A lot of times the fuse panel has one side connected to the auxiliary battery and the other side to the starting battery. Does your panel have two separate sides to it with multiple fuse locations on each? Some simple testing with a volt meter will tell you the story. If you don’t have this setup, it is one to consider. It makes it easy to add accessories and you can easily choose which battery you want to draw off of. |
Paulbeard Samba Member
Posted: Sun Apr 15, 2018 11:26 am Post subject: Re: Solar install suggestions |
What I installed:
Panel
Controller
Fuse panel
ACR
I was mindful of JudoJeff's tragedy and chose a charge controller that solarbob on the interwebs recommended. It has a small gap for ventilation when mounted and I improved on that with a set of small nylon washers as standoffs.
The biggest thing I have learned is the importance of good solid grounds. I didn't use the seatbelt bolt, instead making my own with a self-tapping screw and washers. But until I did a really good job of sanding down to bare metal I wasn't getting all of the power I was harvesting. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
physast Samba Member
Posted: Sun Apr 15, 2018 7:20 pm Post subject: Re: Solar install suggestions |
Thanks for all the replies.
I have the blueseas fuse panel where the battery connects directly to the top and bottom ports. So if I decide to run through the fuse panel it would be no different then going directly to the battery. I will have a fuse from the panel to the controller and from the controller to the battery.
I purchased the Renogy Rover 20 amp MPPT charge controller. Probably over kill, but I can use it in other situations and I don't want my van to burn down.
I plan on adding a switch to turn the charger off when solar is not in use. I still have not decided how to do the install. It will depend on where I decide to mount the charger.
- mount behind seat
- mount below back seat
- mount on clothes cabinet
I have all the parts and have tested to make sure the controller and panel are working. _________________ 1967 L633 VW beetle (currently being restored...slowly)
1991 Orly Blue Vanaru 2.5L |
RichBenn Samba Member
Joined: November 16, 2005 Posts: 703 Location: Lake Tahoe, NV
Posted: Sun Apr 15, 2018 7:57 pm Post subject: Re: Solar install suggestions |
physast wrote: |
There can be a big difference. If the wire going ftom the battery to the fuse panel shorts to ground, ALL of the energy from the battery will go to the point of contact. It could create a fire. This is why you need to either have a fuse close to the battery or the wire from the battery physically protected. _________________ Rich |
jimf909 Samba Member
Posted: Sun Apr 15, 2018 9:02 pm Post subject: Re: Solar install suggestions |
RichBenn wrote: |
physast wrote: |
There can be a big difference. If the wire going ftom the battery to the fuse panel shorts to ground, ALL of the energy from the battery will go to the point of contact. It could create a fire. This is why you need to either have a fuse close to the battery or the wire from the battery physically protected. |
Yep. I have my system set-up as the OP described above and also have an inline fuse about two inches from the battery pos. terminal (plus the wire is routed through a sleeve. What I haven’t done is replace my charge controller and mount it on a heat sink (work in progress):
_________________ - Jim
Abscate wrote: |
Posted: Wed Apr 18, 2018 4:50 pm Post subject: Re: Solar install suggestions |
Done! I installed everything yesterday.
- Installed the rover 20A MPPT behind the driver seat
- installed the gowesty solar hook up box (replaces city water)
- ran wires from the box to the charge controller
- ran wires from the battery to the charge controller
- 20a inline fuse from the solar panel to the charge controller
- 20a fuse from the charge controller to the battery
- cut off switch at the battery for when solar not in use
The rover 20A controller uses 100ma when idle and this was more than I wanted drawing power off the house batteries when not in use.
Right now I am storing the flexible panel between the upstairs bunks. At some point I would like to add a place on the roof that can easily be taken down when needed.
Tested and all works! Thanks for the help. _________________ 1967 L633 VW beetle (currently being restored...slowly)
izzydog Samba Member
Posted: Thu Apr 19, 2018 5:31 pm Post subject: Re: Solar install suggestions |
Now comes the fun part: deciding whether you mount the panel to the van or keep it separate.
I have a 100W flexible panel that I store upstairs like you. My panel is attached to 50 feet of big-arse speaker cable so I can park the van any which way (sometimes you don't get a choice) and deploy the panel at the best location/angle. I ran the aforementioned cable from my under-back-seat battery location, out through the firewall and into the engine compartment and left an Anderson Powerpole connector on the ledge behind the license plate door. That way I can plug in my moveable panel right at the license plate and I didn't have to drill any holes in the body. I also have a 110V charger under my rear seat who's plug also exits at the license plate door which allows me to charge the house battery with an extension cord when I need to.
The last part of the puzzle for me is finding a suitable way of holding up my solar panel when its outside collecting sunlight. I like the idea of some kind of adjustable stand that would clamp the panel and hold it tight as well as allow the stand to be weighted with a log or rock, etc. I'm going to try out a portable artist easel like this one: https://tinyurl.com/ybqgnvxo
It's adjustable like a tripod and clamps the solar panel at the top and bottom. It can be adjusted to keep the panel low to the ground and not tip over in wind. It can also be easily weighted with a strap and a water jug to prevent it from being blown over by stronger wind. Resting a solar panel against a picnic table or your bumper works great if there's no wind. Once the wind picks up, your panel will sail away - been there, done that.
Lots of folks attach their panels to the roof, etc., but why beat up your panel with wind and rain and road grime by attaching it to your roof? You don't need the panel until you camp so it's really not doing you any good on the roof while you are driving around. Less holes in your roof is also a good thing... |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Thu Apr 19, 2018 6:49 pm Post subject: Re: Solar install suggestions |
Don’t be buy a single component until you buy, read, reread, and comprehend Don Casey’s treatise on boat wiring.
Chafe relief
Strain relief
Gauging
....Is where most wiring projects are deficient. _________________ .ssS! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
Posted: Thu Apr 19, 2018 10:22 pm Post subject: Re: Solar install suggestions |
izzydog wrote: |
This last paragraph is just not true. Millions of people have panels on their vans, Motorhomes and trailers, not to mention a few hundred million on homes and solar farms with rare failures, no leaks, no problems. The glass used is rated for hailstorms that would pock mark your tin top or crack your fiberglass. _________________ Rich |
Posted: Thu Apr 19, 2018 10:34 pm Post subject: Re: Solar install suggestions |
Abscate wrote: |
Chafe relief
Strain relief
Gauging
....Is where most wiring projects are deficient. |
Is this the treatise that you’re referring to?
https://www.amazon.com/Sailboat-Electrics-Simplified-Don-Casey/dp/0070366497/ref=nodl_
I’d like to graduate beyond hackdom.
My dad taught me a lot but he combined a balance of knowledge of how to do it the right-way along with gumption and risk-taking knowing that “this will get it done”. That’s hard to pass on to a borderline knucklehead like me.
A year or so ago, Dampcamper (40 years of electrical experience) here PMd me a correspondence course on how to select components, where to buy to marine electrical stuff here in Seattle (Fisheries Supply, Ancor brand terminals, etc.) and even a project or two. My skills and abilities improved (giving me ideas on how to improve the wiring in my rig). Thanks, Dampcamper!
If that’s the book you’re referring to I’ll add it to my coursework.
Thanks. _________________ - Jim
Abscate wrote: |
Posted: Thu Apr 19, 2018 10:46 pm Post subject: Re: Solar install suggestions |
That’s it. A sailboat fire is like a Vanagon fire that you have to watch while in your seat waiting for the gas Tank to burn. You wire somewhat differently thinking that way. You become aware of every force and place where the wire touches the car. _________________ .ssS! |
