Teeroy Samba Member
Joined: April 20, 2003 Posts: 3685 Location: Eastern WA
Posted: Thu Apr 12, 2018 11:16 pm Post subject: Dyno Time |
So tomorrow it's finally time for a little dyno time. Any estimates on whp and torque?
2165cc 9.7 to 1
Web 86 B
Tim's Stage 2 Mexico 043 castings
44 IDFs 36mm vents, jetted per specs and 1800 ft elevation
A1 1 5/8 Sidewinder
All balanced
Tight deck .045 _________________ Pres. Rivercity VW Club www.rcvwclub.org
Founder Derr Wheat Panzers (DWP)
ARR #3
www.autosportsnorthwest.org |
Vanillagurilla Samba Member
Joined: November 21, 2017 Posts: 1061 Location: California
Posted: Fri Apr 13, 2018 12:32 am Post subject: Re: Dyno Time |
150hp 140ftlbs, probly gain 10hp or so with 48ida carbs. We are talking engine dyno not chassis dyno correct? Let me know how close this is, so far it's been pretty damn close.
Paul.H Samba Member
Posted: Fri Apr 13, 2018 4:50 am Post subject: Re: Dyno Time |
That dyno simulator is pretty good. Just did an engine very similar but with bigger heads and it made 175 fwhp with 45mm throttle bodies but it lost 10-12hp on the top end with 36mm throttles. The 44IDF's will restrict the top end and if peak power occurs high the belt losses will be substantial |
mazza89 Samba Member
Joined: January 16, 2008 Posts: 109 Location: Pittsburgh, Pa
Posted: Fri Apr 13, 2018 4:55 am Post subject: Re: Dyno Time |
Teeroy wrote: |
2165cc 9.7 to 1
Web 86 B
A1 1 5/8 Sidewinder
All balanced
Tight deck .045 |
Check my post history just ran on a mustang dyno and ended up 150/150 at the wheels 2276cc 9.5:1 c45 cam 1.25 rockers all balanced and same carbs.
I am guessing you will be right around there or 10 hp less from the small displacement.
I was going to go FI and fuel injection over winter but that didn't happen, so considered 48's which would definitely help instead I am holding off and will go the Fuel Injection and turbo down the road. |
superpro56 Samba Member
Posted: Fri Apr 13, 2018 4:57 am Post subject: Re: Dyno Time |
I got one:
2180 9:1
Tims Stage 2's
Dual 44 IDF's
Bugpack 4065-12 cam
1.4 rockers
1-5/8 exhaust |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7210 Location: Videbaek Denmark
Posted: Fri Apr 13, 2018 4:58 am Post subject: Re: Dyno Time |
Whp, impossible to say as it can be all over the place.
Built well I´d say about 157 - 160 hp and 210 Nm using SAE corrections (77 deg. F. 29,6") and at sea level, which is about 143 hp at 1700 feet. |
74 Thing Samba Member
Posted: Fri Apr 13, 2018 7:06 am Post subject: Re: Dyno Time |
That should be a fun engine/car to drive.
Get it tuned and have fun! |
Teeroy Samba Member
Teeroy Samba Member
Posted: Fri Apr 13, 2018 8:36 am Post subject: Re: Dyno Time |
It is very fun to drive, very smooth, not pesky or temperamental _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
mark tucker Samba Member
Posted: Fri Apr 13, 2018 9:51 am Post subject: Re: Dyno Time |
136-147...153 possiable |
Posted: Fri Apr 13, 2018 2:16 pm Post subject: Re: Dyno Time |
Soo, tomorrow is today. What´s the verdict? |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Fri Apr 13, 2018 3:31 pm Post subject: Re: Dyno Time |
Alstrup wrote: |
As they say......a dyno makes a liar out of you......
It also makes a grown man cry.......
I was 25 crank hp short of my hopes........
I'll guess 142 whp and 155 torque.......but what do I know.
It is just a guess which will depend on how far in rpm his cam will make power. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Teeroy Samba Member
Posted: Fri Apr 13, 2018 6:59 pm Post subject: Re: Dyno Time |
Sorry just got home for a minute, had to check on my bus at a multi day car show as soon as I got done at the dyno. So we had time to do 5 pulls today, AF looked good at full throttle so we left jetting alone for now (might get a few more horse if we lean it out a little), but we played with the timing a little. Best pull was 148hp and 149ft tq, (left the readout in my bus), don't remember exact rpm for each. So that dyno app was pretty close! I thought the hp and tq would be a further apart, my bus is 10-15 apart? Torque curve is nice and flat from about 2800-6600, with a quick climb above 1500 rpm. There is a dip in the 1800-2500 zone and goes rich (not sure which is causing which). Very happy with results! VW transaxles 10 or 15% hp loss? _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Teeroy Samba Member
Posted: Fri Apr 13, 2018 7:03 pm Post subject: Re: Dyno Time |
I'm happy so the only change I will consider at the moment will be fine tuning the jetting. But if I were to want more power out of my combo what would be next step? Bigger carbs or exhaust? 1.5 rockers? (have 1.4 installed) or even more compression (now 9.7 to 1, no ping on 92 E-10 pump) _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Fri Apr 13, 2018 7:52 pm Post subject: Re: Dyno Time |
Teeroy wrote: |
I'm happy so the only change I will consider at the moment will be fine tuning the jetting. But if I were to want more power out of my combo what would be next step? Bigger carbs or exhaust? 1.5 rockers? (have 1.4 installed) or even more compression (now 9.7 to 1, no ping on 92 E-10 pump) |
EFI Turbo........more power than you can ever hope for.
Come to Springmeet in Bellevue the 28th of April. If the weather is dry I'll take my buggy and I'll give you a ride with almost 200 whp now that I'm back to 22.0 lbs boost.
You will have to look me up though. PM for a phone # or find Mario if he has a booth.....I'll probably be hanging with him. _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Teeroy Samba Member
Posted: Fri Apr 13, 2018 9:58 pm Post subject: Re: Dyno Time |
There is a handful of us coming over, I'll be swapping out of the micro _________________ Pres. Rivercity VW Club www.rcvwclub.org
ARR #3
Posted: Fri Apr 13, 2018 10:04 pm Post subject: Re: Dyno Time |
Compression bump, 1.5s, and idas.
Paul.H Samba Member
Posted: Sat Apr 14, 2018 3:00 am Post subject: Re: Dyno Time |
Vanillagurilla wrote: |
That's good ! Even the shape of the graph and the peak is very close.
Can you drop some 40 dells with 30mm venturis in there see what it says ? |
Posted: Sat Apr 14, 2018 6:36 am Post subject: Re: Dyno Time |
so who nailed it? or got the closest? how far were you off? |
Paul.H Samba Member
Posted: Sat Apr 14, 2018 6:47 am Post subject: Re: Dyno Time |
Dub Dyno nailed it |
