Hatmpatn Samba Member
Posted: Sat Apr 14, 2018 8:43 am Post subject: Fiberglass body kit (Baja)- Which/where to buy? |
Hello! Im going to buy a VW bug within a month. And after this convert it to a Baja.
I want it to look as mean as this one(I found the image on Google):
Two questions:
1. Which bug should I buy? Is 1302 -68 a good choice? Im also planning to swap to a Subaru EJ22. Are there any model that has a preferrable transmission that can take the double power?
2. Where can I buy the exact fiberglass body kit that the car in the image wears? |
YDBD Samba Member
Joined: February 25, 2017 Posts: 891 Location: Bavaria, Germany
Posted: Sat Apr 14, 2018 9:22 pm Post subject: Re: Fiberglass body kit (Baja)- Which/where to buy? |
Hard to say as you are in Sweden and parts may be hard to come by.
Bugs in Europe would be slightly different than US models of the same year.
Look for:
IRS transaxle with CV joints rather than swing axle
I prefer link pin front end vs. ball joint, especially for off roading.
limited rust in body, unless it's a part that's going to be cut off.
Fiberglass parts for baja's mostly likely will come from the US, you might have to pay a lot just for shipping, not to mention Swedish/EU taxes. Look on the web for EU based manufacturers as well as bug/buggy/baja/VW clubs that might be in the EU and someone may have a connection.
The one in the pictures has been modified to suit the owner, many of the kits are about the same.
As far as the Subbie motor, do a search on the Samba, there are a few who have gone that route.
Enjoy! _________________ '56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing" |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Sun Apr 15, 2018 8:06 am Post subject: Re: Fiberglass body kit (Baja)- Which/where to buy? |
that is an extreme example. wider and higher front and rear, probably a 6 inch wider front beam and 3X3 rear trailing arms
start here: Baja Bugs For Volkswagen Virgins _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
dustymojave Samba Member
Posted: Mon Apr 16, 2018 6:23 pm Post subject: Re: Fiberglass body kit (Baja)- Which/where to buy? |
My car has Mk V Fiberglass.
They are in Nevada, USA.
https://markvfiberglass.com/product-catalog/
Same style as the silver car above. But when mine was made, their factory was a mile from my home. EMPI sells fiberglass. They use Mark V for their supplier. They have become nearly the only manufacturer of Baja Bug kits these days. _________________ Richard
SoCalBajas Member
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Wed Apr 18, 2018 5:28 pm Post subject: Re: Fiberglass body kit (Baja)- Which/where to buy? |
Hatmpatn wrote: |
Is 1302 -68 a good choice? |
In the US a 1302 is a 1971-1972 Super Beetle, with McPherson Strut front suspension, which is not good for a baja.
In the US a 1303 is a 1973-onward Super Beetle, also with McPherson Strut front suspension, which is not good for a baja.
In the US a 1301 is a standard beetle, with torsion bar front suspension. This is the one you want for a baja.
These off road dudes seem to use a bus transmission for a strong motor. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
