crankbait09 Samba Member
Joined: October 10, 2016 Posts: 1304 Location: Cincinnati, Ohio
Posted: Sat Apr 14, 2018 11:06 am Post subject: uh oh, I got a rear wheel bearing cover problem |
I torqued the cover retaining screws on the drivers side with ZERO problems. All went well. For some reason none of the bolts were tight, so the backing plate slightly shifted side to side. So drivers side is now at 45 ft-lbs
Made my way over to the passenger side. As I tightened the bolts, something didn't feel right with the lower left bolt. It got to a point where it got slightly tight, then not at all. One more turn, and the bolt was sheared off. As I pulled out the front half, the bolt was VERY wet. Saturated with oil/grease or whatever it was. Along with the grease, came a chunk of something, maybe a piece of rubber gasket sealer. Looked like rubber, but wasn't sure. It was quite odd how wet this area was behind those bolts. The drivers side certainly didn't look that way.
I did not pull that cover off to look any further. Wasn't sure what steps to take at this point. I have the bug me video for this seal removal instruction, but with the broken bolt, it kinda changes things.
So, with that, what kind of trouble have I gotten in to, and what do I do now?
bluebus86 Banned
Posted: Sat Apr 14, 2018 11:39 am Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
the backing plate should not move around once the bearing retainer is installed correctly. Please recheck the assembly, please note that VW did make changes over the years, for instance the oil slinger change. make sure you have the correct parts and are following the correct instructions for your Bug. a loose backing plate could cause tranny lube loss, and brake contamination with lube, brake shoes ruined at best, destroyed tranny or a crash at worse
for the side with the sheared bolt, you may want to drill it out and use an extractor. make sure no drilling chips get into the assembly. once the stud is out, check the female threads for damage, they may need to be repaired, but maybe fine
torque of 29 to 32 ft lbs is correct for the backing plate bolts on early cars per my 1957 manual. , not 45 ft lbs
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
anthracitedub Samba Member
Posted: Sat Apr 14, 2018 11:53 am Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
X2 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sat Apr 14, 2018 12:04 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
bluebus86 wrote: |
for the side with the sheared bolt, you may want to drill it out and use an extractor. make sure no drilling chips get into the assembly. once the stud is out, check the female threads for damage, they may need to be repaired, but maybe fine |
This would be a perfect situation to use a left-hand drill bit. I bought a set online. Better hardware stores like Ace Hardware sometimes stock those. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sat Apr 14, 2018 12:23 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
Agreed. I still have the VA left hand drill bit set that I bought 20 years ago when I was a mechanic, plus a larger, much cheaper set I got many years later at Harbor Freight. IMHO, they are the best solution for broken off bolts, but it requires a level of precision. (center punch it and drill it as best you can, at dead center) _________________ Andy T.
Posted: Sat Apr 14, 2018 12:32 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
bluebus86 wrote: |
Bug On! |
this is where I got the 40-47 ft-lbs from. Which one do you go by?
https://www.thesamba.com/vw/archives/manuals/1965withoutguesswork/108-109.jpg
Posted: Sat Apr 14, 2018 12:34 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
at this point, is it safe to assume that I should disassemble the whole assembly, down to the back to make sure all seals are ok? Or no need to go back that far? |
Posted: Sat Apr 14, 2018 12:39 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
And I'm the one that quoted that book to you. The Light Blue Bentley for 66-69, it says 6mkg / 43 lb feet, by the way, which is consistent with the 40-47 range given in Without Guesswork. _________________ Andy T.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sat Apr 14, 2018 12:41 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
Just fix the one.
No need to fix what's not broken.
Just make sure to torque to the correct setting as the bus has mentioned above.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
bluebus86 Banned
Posted: Sat Apr 14, 2018 12:44 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
crankbait09 wrote: |
bluebus86 wrote: |
Bug On! |
this is where I got the 45 ft-lbs from. Which one do you go by?
https://www.thesamba.com/vw/archives/manuals/1965withoutguesswork/108-109.jpg |
My 1957 Manual is what I got the value from.
For your 1965 then go with that higher value per your data, but make sure all the parts are 1965 type, not a mix of types. My 1970 thru 1978 manual says 43 ftlbs. evidently the value changed at some time between 1957 and 1965.
as stated, the assembly changed over the years in both parts and torque values. make sure your following the correct assembly instructions for your type, and all the parts are correct for that type.
Evidently something is wrong with the busted bolt, at what torque did it fail at, less than 45 ft lbs?
also use a bolt tightening pattern, get them all snug criss cross to near final torque in stages before final torque, that may help square things up.
Good Luck, Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Apr 14, 2018 12:51 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
67rustavenger wrote: |
Just fix the one.
Good Luck. |
I kinda worded that wrong, I meant....should I disassemble THIS rear wheel oil seal assembly since I will need to remove the cover to get to this bolt? |
Posted: Sat Apr 14, 2018 1:04 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
While it will be a bit messy since all the oil in the hollow axle tube will run out, but that's to be expected. I would take it off. While you might be able to do the reverse drill bit thing with the cover on there, I think having it off would be better.
Incidentally, I just looked up the 1961 edition of Without Guesswork, it says 5.5 - 6.0 mkg / 36-43 lb-feet on the torque. The Spanish 1964 edition says 5.5 - 6.5 mkg, but then has a hilarious typo for the lb-foot rating, where it says 40-70 pound feet. I'm pretty sure I've always gone around 45.
Back in the 60s most people were using beam style torque wrenches which didn't really have the precision of the clicker style that we see now days. _________________ Andy T.
Posted: Sat Apr 14, 2018 1:09 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
I think when I remove the cover, I am going to remove the oil seal and check that o-ring behind it. just to be safe.
I have a 63 beetle, so I will back off the torque too. I'll take it to 30 ft-lbs. |
Posted: Sat Apr 14, 2018 1:15 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
The bearing cover changed in 1965, but the spec in the 1964 book I mentioned above would be the same for a 1963, and it's the that same range of 5.5-6.5 metric (40-47 pound feet) I don't know why your bolt broke, but I think those are 10.9 hardness bolts which should be good for over 50! _________________ Andy T.
Posted: Sat Apr 14, 2018 1:20 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
glutamodo wrote: |
The bearing cover changed in 1965, but the spec in the 1964 book I mentioned above would be the same for a 1963, and it's the that same range of 5.5-6.5 metric (40-47 pound feet) I don't know why your bolt broke, but I think those are 10.9 hardness bolts which should be good for over 50! |
It's really hard to say. I've only owned this bug for a month +, so I don't know the history of why things were done the way they were. I wonder since that bolt couldn't be tightened, the PO lightly tightened the bolts all the same, to keep them consistent. Hard to say. Maybe there was an issue with the hole/bolt all along. But I didn't know it till I tried torquing. |
bluebus86 Banned
Posted: Sat Apr 14, 2018 1:24 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
Just fix the one.
Good Luck. |
you may not need to remove the cover to remove the busted bolt, if the bolt is flush with the inner bearing carrier they may be no advantage to removing the outer cover. with outer cover removed, metal chips more likely to get in bearing, so tape it off well to keep chips out. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Apr 14, 2018 1:26 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
bluebus86 wrote: |
Just fix the one.
Good Luck. |
you may not need to remove the cover to remove the busted bolt, if the bolt is flush with the inner bearing carrier they may be no advantage to removing the outer cover. with outer cover removed, metal chips more likely to get in bearing, so tape it off well to keep chips out. |
OK. I'm gonna attempt to use a LH drill bit tomorrow to get this out. Leaving everything assembled as is. |
Your photo didn't include the top of the broken bolt, did it have "10G" on it? That's the 10.8 grade.
I've seen it where bearing cover bolts are not tight and the action of braking makes everything shifts every time you brake, and then shift the other way when you're reversing and brake. This can, over time, add up to a lot of unintended stress for the fasteners and may have well contributed to the failure you experienced. _________________ Andy T.
bluebus86 Banned
Posted: Sat Apr 14, 2018 1:37 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
glutamodo wrote: |
Back in the 60s most people were using beam style torque wrenches which didn't really have the precision of the clicker style that we see now days. |
mathematically "ft lb", and "lb ft" are the same unit.
I recall from spanish class, which I got a D- in, that they sometimes phrase things backwards to english. example... Red house = Casa de roja. The words red and house are reversed in order english to spanish. so maybe that is what gives? A literal word by word translation verses a translation of the entire phrase. Example... it would be wrong to state" house of red" in english (ie "casa de roja"), and wrong to state "roja casa" in spanish (ie "red house")
Maybe that is why I got such a grade poor in spanish errr.. I mean poor grade in spanish!
Bug On Amigo! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Sat Apr 14, 2018 1:40 pm Post subject: Re: uh oh, I got a rear wheel bearing cover problem |
The head of the bolt that broke says "DERA 10k" on top of it.
here are a couple more pictures. That bolt did not break off flush with the hole. It's down inside. I tried spraying some brake cleaner in there to clear it out, but I can't see a thing.
