Oil pressure/ alternator light keeps coming on???
tuekwik4u
tuekwik4u is offline
PostPosted: Sun Apr 15, 2018 10:56 am    Post subject: Oil pressure/ alternator light keeps coming on??? Reply with quote
I'm new to owning a VW, so maybe I could get a little help on this issue. I was driving my thing the other day going about 65 and my oil light came on. Car was running fine nothing out of the ordinary. When I got back into town at, lower speeds, the light shut off. Also when I drive at night, my ALT light is dimly lit, maybe cause I'm running the lights??? Thanks for any input.
YDBD
YDBD is offline
PostPosted: Sun Apr 15, 2018 8:51 pm    Post subject: Re: Oil pressure/ alternator light keeps coming on??? Reply with quote
If either light comes on, pull over immediately and check! When the oil light comes on that means ZERO oil pressure. When the gen light comes on it may mean you have lost your fan belt.
Since you made it, check your oil level, check your wiring and make sure the ground wire to the speedo is connected well.
Do you have a generator or alternator? Old generators use an external regulator, alternators have an internal regulator. Increased load (lights) may cause a glow from the idiot light with the old system and may be wearing out. Check wiring for good connections.
'56 pan Dune Buggy since '69
don't live in the past...but when I did:
'67 bug
'64 baja
'60 dune buggy
'73 Personenkraftwagen Type 182 "Thing"
sam_w
sam_w is offline
PostPosted: Sun Apr 15, 2018 11:47 pm    Post subject: Re: Oil pressure/ alternator light keeps coming on??? Reply with quote
I had the same problem and it turned out it was the voltage regulator for my generator. A new regulator fixed everything
63 singlecab
73 thingster
