Xevin Samba Member
Posted: Sun Aug 19, 2018 12:49 pm Post subject: Re: “Mullet The Bug” a bugs story. |
wcfvw69 wrote: |
Manufactures date stamp on this Bosch coil is April 1973. |
wow and it’s still kicking. Worked well before the build. I’ll put a meter on it to verify the health. Can’t wait to see how your 034 distributor and Tim’s 34-3 carb play together. Thanks for the info Bill. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
AlmostHeavenWV_VW Samba Member
Posted: Sun Aug 19, 2018 7:18 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Awwww yeahhhh!!!
Makin' progress on Mullet's heart
"We have the technology, we can rebuild him!"
keep on Bussin' & fixin' (till Mullet gets back on the road)
Then it's time to:
Keep on Buggin' Xevin! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Xevin Samba Member
Posted: Mon Aug 20, 2018 9:43 am Post subject: Re: “Mullet The Bug” a bugs story. |
Who did the balancing work?
I use Steve's in Tigard.
Keep up the good fight brother! |
Didn’t mean to leave you hanging. My friends machinists does only ACVW. However, his clients keep him just the right amount of busy, so he doesn’t have
a public shop. I’m sure a lot of the cars you see at Woodburn raceway use his services. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Clatter Samba Member
Joined: September 24, 2003 Posts: 7537 Location: Santa Cruz
Posted: Mon Aug 20, 2018 5:57 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Stoked!
If you want me to talk to Xatie, and pontificate upon the long-term benefits of a job well done, let me know..
I’m voting for the whole 100% stock treatment - with working/clean heat risers, thermostat/flaps, oil bath cleaner with functional stovepipe, pea-shooters, the whole enchilada.
Your mild cam and SVDA mod won’t ruin the effect.
Once you get it all 100% like Mother Volkswagen intended,
The experience is unreal.
The flawless cold-starts and warm-up/running is something to experience.
It’s like this precision sewing machine or something.
The quiet grace, the reserved manners, the flawless low-end pull..
Too often we have driven these beaters with some obnoxious header or some stupid open filter or some such...
If you set the depth of the pea-shooters correctly, so they pull lots of hot air thru the manifold heater tube - Nirvana.
VERY few these days have experienced what it was all about back in the beginning..
Once you experience it, you will understand fully.
Do it right, and you’ll see what I mean.
You GO brother! _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Mon Aug 20, 2018 6:02 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Oh, and have them do a full dynamic balance job on the rotating assembly..
Yes, it’s hard to find someone to do it.
Yes, you have to send the pulley, crank, flywheel, pressure plate and all the bolts.
Yes, it costs a “lot” of money.
Yes, it’s another delay.
Yes, many say you don’t need it on a stock motor.
But, if you don’t do it now, then when??
Balance on new pressure plates these days licks hairy dog balls..
Do you want me to talk to her for you? _________________ Bus Motor Build
Xevin Samba Member
Posted: Tue Aug 21, 2018 12:56 am Post subject: Re: “Mullet The Bug” a bugs story. |
Clatter wrote: |
Stoked!
Yes. All the encouragement to Xatie is appreciated
Yes. It will have all the working original fixins you mentioned (74 is paper filter) except exhaust. I haven’t found an original exhaust I like yet. Haven’t looked that hard. But it will happen at some point. If any of the three of you reading this thread have a lead on an original exhaust for this build. Let me know. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Tue Aug 21, 2018 10:21 am Post subject: Re: “Mullet The Bug” a bugs story. |
And the hunt is on.... _________________ Bus Motor Build
Posted: Tue Aug 21, 2018 10:36 am Post subject: Re: “Mullet The Bug” a bugs story. |
Xevin wrote: |
If any of the three of you reading this thread have a lead on an original exhaust for this build. Let me know. |
Make it 'four', Xevin
https://www.thesamba.com/vw/classifieds/detail.php?id=2187438
Also, I know it's not original, but discussion on proper=fitting aftermarket mufflers came up a little while ago:
https://www.thesamba.com/vw/forum/viewtopic.php?t=704421&highlight=muffler
Quote: |
TDCTDI wrote: |
I just installed a Bosal unit, great fit, sounds a bit throatier than an original German one but still gets a bit of that original "fweem" under acceleration. |
Tim Donahoe wrote: |
I just checked out the reviews on the Bosal muffler. It seems that TDC may be into something. The manufacturer brags about the perfect fit. They also mention quality, too; but a good fit is a good start.
So ... when the time comes, I’m going to give the Bolton a shot. It certainly can’t be worse than Dansk, and it might deliver the quality and fit the mention.
Tim |
Keep on Bug'n! _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Xevin Samba Member
Posted: Wed Aug 22, 2018 10:45 am Post subject: Re: “Mullet The Bug” a bugs story. |
AlmostHeaven. Thank you so much for the links. Remember the rules when you get out to Oregon, “You fly I buy”.
Before I go down the exhaust rabbit hole. I’m not entirely sure if my 74 bug is California or Federal spec. Is there a difference for exhaust. Or will any 1600cc
Exhaust fit? I think they will. But want to confirm. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
sb001 Samba Member
Posted: Wed Aug 22, 2018 10:52 am Post subject: Re: “Mullet The Bug” a bugs story. |
Is this worth the impending breakup? _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Posted: Wed Aug 22, 2018 10:59 am Post subject: Re: “Mullet The Bug” a bugs story. |
Xevin wrote: |
I agree to abide by those terms & conditions,Xevin
Xevin wrote: |
Exhaust fit? I think they will. But want to confirm. |
Only difference for a 1974 between the two (Cali vs Federal) is solely a dual-heat riser set up, I believe. Fitment otherwise should be the same.
Cali (dual pre heat pipes)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113251053BG
Federal (single pre heat pipe)
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113251053AJ _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Xevin Samba Member
Posted: Fri Aug 24, 2018 2:58 am Post subject: Re: “Mullet The Bug” a bugs story. |
Well, the engine is together. Kinda. Was going for long block today.
My buddy just wasn’t satisfied with the AutoLinea heads. So off to the machinists they went, today. The beauty of this is he went straight to work on
them tonight. He was texting pictures while I did other mundane tasks. Sorry no pictures, they are on my buddies phone. But holy crap they look proper. Castings cleaned up. And a whole lot of techniques being used Clatter tought me. Probably more then this stockish engine deserved. I’m not going to complain should be back this weekend.
Meanwhile my buddy dug out some heater boxes he wanted to use instead of the crap that came with the bug. He had me clean them up. He said go light in the solvent tank as to not saturate with solvent. Ok cool. Knock off some gunk and good to go. So I did.
Then he said. “ We going to paint them.” Ah shit. That means hours of prep. So I did. Brush, pick, scrape, sand, scuff, and repeat. Brush, pick, scrape, sand, scuff, and repeat.Brush, pick, scrape, sand, scuff, and repeat.Brush, pick, scrape, sand, scuff, and repeat.Brush, pick, scrape, sand, scuff, and repeat.Brush, pick, scrape, sand, scuff, and repeat. So I did. This is half way through this ass whipping process.
Pretty sure an electric wire wheel and a Dremel would have cut my time in half.
But it was a nice night listening to an entire album of Kurt Vile and The War on Drugs while I meticulously dicked with these heater boxes.
Clatter wrote: |
SGKent wrote: |
Posted: Wed Aug 29, 2018 6:43 am Post subject: Re: “Mullet The Bug” a bugs story. |
Just a thought or two,
From someone paralyzed by retentivity..
The Bentley shows how you are supposed to drill out the spot-welds,
So you may properly clean the sludge/stink from within heater boxes.
This might allow a proper (ceramic?) coating of the tin,
And perhaps the use of an insulation product besides asbestos.
(Company Thermal Zero sells a nice replacement on Amazon)
Additionally,
Those GO1 heads have valves and guides of DogDoo quality.
Certainly worth it, while you are in there,
To get a better set of stock-sized valves.
The guides in mine came loose in short order,
So it is likely that a bit o’ fittin’ With a better set of guides,
Maybe the next size up,
Would ensure a long, happy life for your motor.
Perhaps even beyond your own,
Should your overextension bring her wrath.. _________________ Bus Motor Build
Xevin Samba Member
Posted: Wed Aug 29, 2018 10:54 am Post subject: Re: “Mullet The Bug” a bugs story. |
^^^ this coming from a guy who sent all his fasteners to be replated out of state
Thank you Clatter, I got you brother. All is sorted out. Just like you taught me at your place my buddies are very experienced with these heads. Just got them back from the machinist. Cast flashing clean up was last night.
http://shoptalkforums.com/viewtopic.php?t=115095
Thought about going inside heater boxes. I know the drill. Going to run them for now. Later I will rip into them if necessary.
And anyone interested in a type 3 work of art. Check out Clatter’s thread. It’s about a hundred pages But truly remarkable.
https://www.thesamba.com/vw/forum/viewtopic.php?t=...7d37956024 _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
wcfvw69 Samba Purist
Posted: Wed Aug 29, 2018 7:44 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Xevin wrote: |
https://www.thesamba.com/vw/forum/viewtopic.php?t=...7d37956024 |
On your heater boxes, don't cut them open. Get a bucket big enough to submerge them in. Fill it with hot water and a degreaser. Let them soak overnight. If you can find round brushes to push inside them to scrub, even better.
I did this with two nasty, used bus heater boxes on my bus. They came out super clean inside and out. Zero smell when I turn on the heat in the bus.
Another option is to find a shop with a big ultrasonic parts cleaner. Mine isn't big enough. However, the parts I clean in it come out sparkling clean in a short time. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Thu Aug 30, 2018 8:29 am Post subject: Re: “Mullet The Bug” a bugs story. |
Can’t believe you found that 11-year-old STF thread!
Funny that the end of that story years later was the guides falling out..
A new set of guides, though, and away we go..
Wanna make sure you have all cooling tin in place;
Haven’t seen one of these with a complete set of tins in -years-.
There was a little show here a while back,
Had at least 100 cars,
And I counted exactly -three- that had a thermostat.
I want to see a picture of your Hoover Bit in place!
No skipping that one! _________________ Bus Motor Build
Xevin Samba Member
Posted: Sun Sep 02, 2018 6:29 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Clatter wrote: |
No skipping that one! |
Good call on the Hoover Bit. I didn’t have one. However my buddy has a box of them. He picks them up at swap meets when he sees them.
Thermostat will be in there as well.
Question about Tin. I recall in another thread seeing these little rectangular pieces of tin with a notch in them. Can’t remember exactly where they go or what to ask for when searching.
Ha! never mind found them here
http://www.awesomepowdercoat.com/Cylinder_head_internal_deflectors.html
Does anybody know if I need these on the AutoLinea heads. Or are they unique to German VW heads? I suppose I should just call Clark at AP. _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9755 Location: Oregon
Posted: Sun Sep 02, 2018 7:30 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Can't hurt to have them.
I need a set too for my Tim's heads.
Xevin's a cool guy. Considering he's a jerk!
He refuses to share his super secret machinist with me. Lol! _________________ I have learned over the years.
Buy Once, Cry Once!
Xevin Samba Member
Posted: Sun Sep 02, 2018 8:20 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Clatter wrote: |
So Clatter. I was being sarcastic and asked my buddy if he and the machinist had plans to do a full “Dynamic Balance job” on this build showing him your absurd reply....
There was a pause, and he said “It’s was” you are right. It’s not cheap
Sweet Jesus this is going to be nice. Way nicer then I or the bug deserve. Hope Xatie digs it. I might be living out of a bus and have a bug for a daily driver soon _________________ Keep on Busin'
Clatter wrote: |
SGKent wrote: |
Posted: Sun Sep 02, 2018 8:32 pm Post subject: Re: “Mullet The Bug” a bugs story. |
Xevin wrote: |
I might be living out of a bus and have a bug for a daily driver soon |
