knappyroots Samba Member
Joined: April 08, 2013 Posts: 112 Location: Eagle Pass
Posted: Mon Apr 16, 2018 8:44 am Post subject: Opening a motor? should I? |
I was given a(n) 1835cc rebuilt motor, with no more than 5 miles on it (test run). its been stored in the persons garage for about 6 years after it was rebuilt. then in mine for another 5 yrs. When i decided it was time to install it i changed the oil and notice it had minor sludge, not to bad, and (looks to me of some water or gas droplets). Should i just flush it and run with it? or would it be dumb of me to open the case check it and slap it back together since everything should be new in it? what to do? |
bugheadred Samba Member
Posted: Mon Apr 16, 2018 9:08 am Post subject: Re: Opening a motor? should I? |
you should change the push rod tube seals anyway (there old ) so if it was mine I would you can do the whole thing in a couple of hrs and you could put cam break in lube on the cam also |
gt1953 Samba Member
Posted: Mon Apr 16, 2018 10:00 am Post subject: Re: Opening a motor? should I? |
Well hmm how was it stored in a dry climate? or?
You could just change oil and fire it up and see what happens. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
bluebus86 Banned
Posted: Mon Apr 16, 2018 10:09 am Post subject: Re: Opening a motor? should I? |
gt1953 wrote: |
You could just change oil and fire it up and see what happens. |
Agree. why tear it apart unless you know it has problems? If you can turn it by hand, it aint seized Go for it. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Mon Apr 16, 2018 10:19 am Post subject: Re: Opening a motor? should I? |
I live in South Texas about 1 1/2 hours West of San Antonio. Climate is dry. It was rebuilt for a costumer that never paid for it so the builder gave it to me before he past on. nothing was ever wrong with it just. im just concerned about it having some sludge and smelling like old gasoline. |
carcrazed Samba Member
Posted: Mon Apr 16, 2018 3:47 pm Post subject: Re: Opening a motor? should I? |
As the old saying goes: if it ain't broke, don't fix it. my original 1200 sat for 16 years not run. I cleaned it up, replaced seals, primed it and it fired right up...no smoke, no knocking. That was 4 years ago and still runs perfect. Heck, might as well try starting it after pre oiling and prepping for dry start up. What do you have to lose? _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
Posted: Mon Apr 16, 2018 6:25 pm Post subject: Re: Opening a motor? should I? |
carcrazed wrote: |
As the old saying goes: if it ain't broke, don't fix it. my original 1200 sat for 16 years not run. I cleaned it up, replaced seals, primed it and it fired right up...no smoke, no knocking. That was 4 years ago and still runs perfect. Heck, might as well try starting it after pre oiling and prepping for dry start up. What do you have to lose? |
lmao what do you have to loose (a motor ) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Apr 16, 2018 7:33 pm Post subject: Re: Opening a motor? should I? |
carcrazed wrote: |
As the old saying goes: if it ain't broke, don't fix it. Heck, might as well try starting it after pre oiling and prepping for dry start up. What do you have to lose? |
I say do the above, start it. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Apr 17, 2018 5:15 am Post subject: Re: Opening a motor? should I? |
[email protected] wrote: |
carcrazed wrote: |
Highly doubt that if you take precautions. Done it a million times. _________________ 1965 Herbie Replica. 1776cc dual Kads.
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Tue Apr 17, 2018 5:38 am Post subject: Re: Opening a motor? should I? |
I do agree with these guys. Change the oil, and add some zinc additive, and see how it runs. You aren't going balls to the wall down a strip right after startup, so anything that's going to happen can be handled easily. Though I don't think there's going to be really anything more than a little nose from lack of oil the first few seconds. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
fl59bug Samba Member
Joined: November 23, 2005 Posts: 1976 Location: North Carolina
Posted: Tue Apr 17, 2018 12:37 pm Post subject: Re: Opening a motor? should I? |
Back the end of last year I purchased my 36hp that was mostly complete and ran. I was wanting to do nothing much more than clean it up, make a few checks, change the oil then use it as a backup for my big bore 40hp.
When I got it home I noticed the right side of the engine was missing the bottom cooling tin, and that squashed my original aspirations right then and there.
To be able to replace the cooling tin, I pulled the head off, at which point I noticed several missing cooling fins on the p&c's, made a note of it and proceeded onwards. I was still going to try to slap it back together with the cooling tin installed, but I noticed a lot of crud at the engine case/cylinder joint area so I decided to go further and tear it down to just the short block, with rods hanging out and clean it to prevent dirt ingress. Then I saw what I thought was slop in the rods and so I pulled the rods one by one and checked the big/small ends and bearings.
Long story short? next thing I know the case was gutted and at the car wash with me cleaning it top to bottom I got it all back together with many updates including new p&c's, rebuilt heads, new oil cooler seals, crank main seal, oil pump, muffler, etc..
I'm not sorry I went to that level of time and expense, but if I could have I would only have carried out my original plan.
All this said, if your engine can be cleaned/checked without tearing it apart, I'd surely go for that option if I were you. On the other hand, if you have time and are sure you'll get it back together and be able to use it, then split the case to have a look. |
mukluk Samba Member
Posted: Tue Apr 17, 2018 3:06 pm Post subject: Re: Opening a motor? should I? |
fl59bug wrote: |
I just wanted to fix that torn rear engine bay seal and, well, one thing just lead to another...
Funny how minor projects snowball. _________________ 1960 Ragtop w/Semaphores "Inga" |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Tue Apr 17, 2018 8:54 pm Post subject: Re: Opening a motor? should I? |
Don't worry.
"It's a 200-year-old Volkswagen! Wow, they really built these things, didn't they?"
Cusser Samba Member
Posted: Wed Apr 18, 2018 7:25 am Post subject: Re: Opening a motor? should I? |
KTPhil wrote: |
Don't worry. "It's a 200-year-old Volkswagen! Wow, they really built these things, didn't they?" |
Ahhh!!! Sleeper, 1973 _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Apr 18, 2018 8:57 am Post subject: Re: Opening a motor? should I? |
mukluk wrote: |
fl59bug wrote: |
Funny how minor projects snowball. |
Lol yes! |
