zitty2016 Samba Member
Joined: October 12, 2015 Posts: 76 Location: canton ohio
Posted: Tue Apr 17, 2018 9:47 am Post subject: cabinet edge |
what causes this and how do I fix it? |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 925 Location: Calgary, Canada
Posted: Tue Apr 17, 2018 10:28 am Post subject: Re: cabinet edge |
My understanding is that the rubber shrinks with excess heat. then I suspect it creeps along the groove in the cabinetry. Perhaps repeated cycles causes it to loop as shown.
Were the ends of your trim short of the cabinet ends?
Haven't had this problem on the stove cabinet, but on the rear shelf. My cure was to remove the trim, heat it considerably in hot water and stretch it.
Then with Goop, Gorilla Glue or similar, glue one end and force the trim back into the groove along its length. Perhaps dabs of glue along the groove would also help.
Next a small nail or tack through the trim into the groove in the wood held the ends in place. Haven't had further shrinkage in about 9 years. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Tue Apr 17, 2018 12:46 pm Post subject: Re: cabinet edge |
thanks so much for the help.
Yes the wood is exposed for a considerable distance on both ends. Its interesting that if heat is the culprit, that the looping is on the sink side of the cabinet instead of the stove side.
After you took the trim off and heated it in hot water, did you have to use a lot of force to stretch it out? How long did you heat it for? Also, did you reapply the trim while it was still hot? Thanks it advance for your response. |
jimf909 Samba Member
Posted: Tue Apr 17, 2018 6:17 pm Post subject: Re: cabinet edge |
I’ve used a heat gun when I extracted a portion of a trim run to heat up the trim and reinsert it. A harbor freight heat gun on high can deform the trim so use caution.
Just another way to trim a cat...or something. _________________ - Jim
Abscate wrote: |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Wed Apr 18, 2018 6:53 am Post subject: Re: cabinet edge |
In the desert SW that stuff shrinks like no ones business. Mine are 2" short in some sections. Ive resorted to using salvage material to fill in. Hadnt thought of heating it and stretching it. Goood idea. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Wed Apr 18, 2018 12:45 pm Post subject: Re: cabinet edge |
Zitty, Sorry I can't recall how long it needed heating. Just hung a weight on one end while the other was hung up. Then re installed it while a little bit warm - not hot nor cold.
I suspect the reason the sink end would be shrunk would be heat from the driver's window on a hot sunny day, rather than heat from the propane stove.
As jimf said - be wary of using a heat gun! _________________ '88 VW Westfalia
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Wed Apr 18, 2018 5:08 pm Post subject: Re: cabinet edge |
Heat & (re)stretch?
Fantastic tip !!!
I’ve been waiting for that tip for a LONG time. Thank you!
I’ve cut out the rib at corners so it bends easier, but have never re-glued.
....KTMs, GasGas, SPOT mtb |
Michael4104 Samba Member
Joined: February 09, 2014 Posts: 340 Location: Livermore, Ca
Posted: Thu Apr 19, 2018 8:52 am Post subject: Re: cabinet edge |
Heat and stretch, but also add a nail to the end to keep in place. I use a small finishing nail. _________________ 1990 Wolfsburg Carat with new poptop.
1985 Westy now sporting a 1995 Jetta ABA 2.0L. Sold |
Posted: Fri Apr 20, 2018 2:33 pm Post subject: Re: cabinet edge |
thanks for the help! |
