Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Mon Jan 14, 2019 7:58 pm Post subject: Re: Solar feedback thread #1000 |
And while you have a 23w lightbulb in hand, see if the panel can light it. A 50w panel can light two blinker bulbs (46w). _________________
....KTMs, GasGas, SPOT mtb |
Paulbeard Samba Member
Posted: Mon Jan 14, 2019 8:51 pm Post subject: Re: Solar feedback thread #1000 |
I'll post results when the sun returns and I'm not at work while it's out. Might be a couple of weeks. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Posted: Sat Jan 26, 2019 12:45 pm Post subject: Re: Solar feedback thread #1000 |
Just to close this up…
The panel was dead. It shows ample voltage but no amperage, no matter the conditions. I suspected the diode in the junction box had given out (the manufacturer glued it to the front of the panel, to make it easier to mount as a low profile install) but I peeled it off and tested the leads directly. Even at 200 mA in full sun, there is no measurable flow. I had considered replacing the diode but it seems like that will be a waste of time. If there is no power at the bare leads, I don't think it's repairable.
It would have been useful to know to test that earlier in the game. It isn't much use testing amperage to the controller if the target battery is full: nothing will pass and there is no way to tell is the panel is working or not. Testing the panel before installation, without anything connected, is best. Then you know where you are.
A new 100w panel is here and tested at 2.75A in full sun, .13A in shade, so I know it works.
So check your warranties. Mine was not on the list of warrantable products so that vendor is dead to me. They have no comparable replacement, by which I assume this is a dead product line as well. The idea of a lightweight flexible panel is appealing but quality varies. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Sat Jan 26, 2019 1:01 pm Post subject: Re: Solar feedback thread #1000 |
RIP solar panel. It was time to upgrade anyway. You going back with the Victron controller? _________________ Brandon
Instagram @joannthevan |
Posted: Sat Jan 26, 2019 1:31 pm Post subject: Re: Solar feedback thread #1000 |
shagginwagon83 wrote: |
RIP solar panel. It was time to upgrade anyway. You going back with the Victron controller? |
it was 2 years old. There was no reason to replace it. I could getting more but *in addition to* not instead of…
Not sure if I need the Victron…though if I had one to start with, I might have caught this earlier when charging dropped to 0. I'm OK with a trickle charge in the shade/low solar angle but 0 is 0. Had I to do it over, I might go with one for the ability to see the performance over time. But that would mean a total replacement of every component but the wire over about two years. Not really something you want. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
Posted: Sat Mar 16, 2019 1:31 pm Post subject: Re: Solar feedback thread #1000 |
My aging transaxle has me off the road but at the same time, the sun is getting stronger each day. House battery is up to 13V and the ACR will occasionally combine the two batteries, so the starter will benefit as well. Just confirmation that the new panel is good and everything else works as expected. Having something like the Victron would save me having to meter the batteries and would also keep a running log, so I'm still thinking on that. The controller I have is good but maybe not for this application. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
— dhaavers |
jimf909 Samba Member
Posted: Sat Mar 16, 2019 1:54 pm Post subject: Re: Solar feedback thread #1000 |
Good news. The day's won't be shorter until mid-September so make hay while the sun shines...or something like that. _________________ - Jim
Abscate wrote: |
