Charlo Samba Member
Joined: March 19, 2015 Posts: 50 Location: Southwest Oregon
Posted: Wed Apr 18, 2018 10:31 am Post subject: '69 Bug - Rear Wheelhouse Mounting Studs |
Hello Forum Members,
I continue on with my ground-up restro of my '69 Bug.
In searching the forum, and going through all of my various vendor catalogs, I'm not able to determine the purpose of the mounting studs on the rear wheelhouses - as shown in the pics - some orig paint showing, and painted over stud(s). This was an orig California car - if that might help in figuring out the purpose of the studs.
I'd certainly appreciate any/all input on this. Thank you much!
right rear 1
right rear 2
left rear 1
left rear 2
_________________ 1969 Type 1171 Sunroof Sedan |
TheViking Samba Member
Posted: Wed Apr 18, 2018 10:41 am Post subject: Re: '69 Bug - Rear Wheelhouse Mounting Studs |
They are for the Z bar |
johneliot Samba Member
Joined: August 29, 2005 Posts: 2189 Location: Chico, CA
Posted: Wed Apr 18, 2018 10:43 am Post subject: Re: '69 Bug - Rear Wheelhouse Mounting Studs |
In the previous years they had what was called a "Z" bar. It served the same purpose of a sway bar. To save money, VW just left the attachment on instead of having to redo the whole body just to get rid of the mounting points. _________________ John
There is no distinctly American criminal class - except Congress.
Mark Twain
69 bug - "The Grey Ghost" |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Wed Apr 18, 2018 10:58 am Post subject: Re: '69 Bug - Rear Wheelhouse Mounting Studs |
Just to clarify, the Z-bar functions with a swing axle. It's not a sway bar, and isn't compatible with the later IRS.
Discussion regarding the function of the Z bar will end up in differing opinions and long winded debates.... _________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
Charlo Samba Member
Posted: Wed Apr 18, 2018 11:18 am Post subject: Re: '69 Bug - Rear Wheelhouse Mounting Studs |
Wow. TheSamba Forum rocks, and comes through once again!
Without the forum, and sometimes YouTube, I'm sure my project could take 2 to 3 times longer to complete...
Thanks to all! _________________ 1969 Type 1171 Sunroof Sedan |
Posted: Wed Apr 18, 2018 12:00 pm Post subject: Re: '69 Bug - Rear Wheelhouse Mounting Studs |
The z bar’s function was to work as an extra damper. They could have softer torsion springs to give the car better handling when there was only one or two persons in the car. When there was a lot of luggage and many person the z bar would «activate» and work as an extra damper to get a little stiffer car |
Posted: Wed Apr 18, 2018 1:00 pm Post subject: Re: '69 Bug - Rear Wheelhouse Mounting Studs |
From Bentley’s Official Service Manual (’66-’69—Blue Manual)
Transmission and Rear Axle, Page 70, Section 11, Equalizer Springs:
“The purpose of the equalizer is to produce an additional progressive spring action to assist the torsion bars when under load. Because the operating levers slant in opposite directions, the action of the equalizer spring does not affect body roll, and the front axle assembly is there-by enabled to absorb more roll to give better cornering of the vehicle.” _________________ John
Mark Twain
