Thing speedo broken
Panheadguy
Panheadguy is offline
PostPosted: Thu Apr 19, 2018 8:57 am    Post subject: Thing speedo broken Reply with quote
Anyone know if beetle speedo will interchange and if so what one?
Thanks so much
The police never think it's as funny as I do...
Semper_Dad
Semper_Dad is offline
PostPosted: Thu Apr 19, 2018 9:41 am    Post subject: Re: Thing speedo broken Reply with quote
Beetle Speedo will fit but may be slightly off due to different wheel ratios.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
Panheadguy
PostPosted: Thu Apr 19, 2018 11:16 am    Post subject: Re: Thing speedo broken Reply with quote
Semper fi from a tin can sailor.
Your point is taken; the diameters of a 14" tire can be different than a 15". I would think the speedo will read faster than actual road speed and maybe a good thing. Any other possible differences like mounting? Broke speedo is still in the Thing.
doublecanister
doublecanister is offline
PostPosted: Thu Apr 19, 2018 11:22 am    Post subject: Re: Thing speedo broken Reply with quote
hey Panheadguy,
do you know what specifically is wrong with it?
I had a beetle one in my THING and swapped it out for a spare I got but it had a cracked plastic gear, I contacted http://www.odometergears.com/products/Volkswagen/Mechanical+Speedometer/19 and they got me the parts I needed.
I made the "new" one match my other one's mileage
and
even buffed out the plastic lens cover with some Mothers plastic polish I had from a headlight lens restore kit and made it look like new.
I cant find the post's on it (been a few years back) but if you search in the 68' and up beetle forms for speedo fix or odometer gear you should find a few posts discussing the subject of repair and photos too.
Hope it helps, try it you may can fix it.
[prying it apart was fun but do-able]
T
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
Panheadguy
PostPosted: Thu Apr 19, 2018 11:37 am    Post subject: Re: Thing speedo broken Reply with quote
I haven't taken it out or apart yet. The fuel gauge needle is missing. I just bought this to tow behind my motorhome. This to replace my 68 type 1 once I trust it. Bought off a guy in IL that was no mechanic.
doublecanister
PostPosted: Thu Apr 19, 2018 11:44 am    Post subject: Re: Thing speedo broken Reply with quote
hey Panheadguy,
Gotcha there, well I understand that, well if you do get a chance and wanted to muck with it...
I think this was the link that I used to give mine a overhaul and fix the cracked gear and reset it to match the one I removed.
Hope it helps!
T
1973 - Thing
Panheadguy
PostPosted: Thu Apr 19, 2018 12:16 pm    Post subject: Re: Thing speedo broken Reply with quote
Thanks double C. Probably will come to that. I might have a speedo or three around here someplace.
