Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jan 22, 2019 1:33 pm Post subject: Re: 1966 Beetle starts and dies after five seconds |
Awesome! Thanks for the update! _________________ In Stereo, Where Available! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Tue Jan 22, 2019 2:05 pm Post subject: Re: 1966 Beetle starts and dies after five seconds |
calebthebaeleb wrote: |
I used weedwhacker line, carb cleaner, and an air compressor to remove a blockage that was in the metal line running to the rear of the car.
It seems as though the mesh filter in the tank was removed in the past |
The missing tank sock was probably the reason the line got plugged. It was put there for a reason! |
calebthebaeleb Samba Member
Joined: April 09, 2018 Posts: 74 Location: Bay Area, California
Posted: Tue Jan 22, 2019 3:05 pm Post subject: Re: 1966 Beetle starts and dies after five seconds |
KTPhil wrote: |
For sure! That's on my list of replacements next time I have the tank out. I have to do a bit of steering work pretty soon so I'll make sure to get a new filter when I have it out. I may just do a whole fuel tank restoration too. _________________ 1966 Pearl White Pigalle Edition w/Sunroof |
Posted: Tue Jan 22, 2019 3:36 pm Post subject: Re: 1966 Beetle starts and dies after five seconds |
For sure! That's on my list of replacements next time I have the tank out. I have to do a bit of steering work pretty soon so I'll make sure to get a new filter when I have it out. I may just do a whole fuel tank restoration too. |
You can also add in a fuel tap, so you can have a gallon reserve amount of fuel, and be able to shut off fuel flow when you need to remove the engine or replace the flexible fuel lines. _________________ In Stereo, Where Available! |
roger m prier Samba Member
Joined: September 28, 2016 Posts: 5 Location: san fernando valley
Posted: Thu Jan 24, 2019 10:36 am Post subject: Re: 1966 Beetle starts and dies after five seconds |
make sure electromagnetic cutoff valve clicks when voltage is applied or swap out a manual type replacement |
Saavedra R Samba Member
Posted: Fri Aug 23, 2019 12:47 am Post subject: Re: 1966 Beetle starts and dies after five seconds |
1966 Bug won't start unless you hold key down . When you let go of key car dies and blows fuse from 30 ignition switch to fuse box . I've already replaced Ignition switch and starter . Baffled please help. |
Posted: Fri Aug 23, 2019 8:18 am Post subject: Re: 1966 Beetle starts and dies after five seconds |
Saavedra R wrote: |
Check the fuse box wiring and make it stock, so that the ignition is not fused.
Not sure what you mean by "hold key down". Ignition should have only three positions "Off", "Run", "Start". _________________ In Stereo, Where Available! |
