Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Thu Apr 19, 2018 1:34 pm Post subject: Need longer studs for converting to Type 4 or Type IV oil cooler |
I have a couple of Type IV oil coolers in my parts stash and I intend to use these on the next couple of upright engines I build. My question is, does anyone sell the longer studs needed to attach the thicker oil cooler to the doghouse adapter? I had at least one set but they seem to have vanished.
I recall Gene Berg Enterprises being an early proponent of this modification however checking their website, I didn't see anything AT ALL about oil coolers. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Thu Apr 19, 2018 1:59 pm Post subject: Re: Need longer studs for converting to Type 4 or Type IV oil cooler |
Lo Cash John wrote: |
I recall Gene Berg Enterprises being an early proponent of this modification however checking their website, I didn't see anything AT ALL about oil coolers. |
If you cant find any...Bel metric should have some that are either spot on or need minor brinding to length. Ray |
woodsbuggy Samba Member
Joined: December 15, 2007 Posts: 208 Location: NE Indiana
Posted: Thu Apr 19, 2018 5:32 pm Post subject: Re: Need longer studs for converting to Type 4 or Type IV oil cooler |
I used bolts instead of studs, worked fine for me and much easier to find.
Good Luck
Kenric _________________ The empty can rattles the most! |
KROC Samba Member
Joined: February 20, 2006 Posts: 359 Location: Vancouver B.C.
74 Thing Samba Member
