racoguy Samba Member
Joined: May 15, 2010 Posts: 687 Location: new zealand
Posted: Thu Apr 19, 2018 6:15 pm Post subject: Turbo header primary pipe size |
Whats peoples thoughts on primary pipe diameter for a 2000cc turbo?
Too large will loose flow, too small would choke?
Max length of pipe work? _________________ https://www.facebook.com/pages/West-Worx/460154187360186 |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4028 Location: NW Washington
Posted: Thu Apr 19, 2018 7:10 pm Post subject: Re: Turbo header primary pipe size |
Do whatever you need to make it work.
If it's a street car anything is better than no turbo at all.
I use an El-Cheapo Sedan header with a piece of 2 inch tubing from the header flange to the turbo inlet.
Could it be better??? Maybe....but it's not that bad the way it is.
I don't think the header is going to make that big a difference unless you are trying to get every tiny bit of hp to win the race.
Use what you have and run it. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
oprn Samba Member
Joined: November 13, 2016 Posts: 12743 Location: Western Canada
Posted: Thu Apr 19, 2018 9:06 pm Post subject: Re: Turbo header primary pipe size |
Right on the money!
I would guess 1 1/2" is as large as you need to go. Just fit them up with the shortest route to the turbo, don't worry about making them equal lengths as turbos really don't care. Keeping the velocity and temperature high is more important. |
FullFender Samba Member
Posted: Thu Apr 19, 2018 10:01 pm Post subject: Re: Turbo header primary pipe size |
I've read here on some ancient posts that smaller pipe spools the turbo quicker, is there any truth to this? |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Fri Apr 20, 2018 3:50 am Post subject: Re: Turbo header primary pipe size |
No smaller tube will not make it spool faster,,,Ball Bearing Turbo will _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Fri Apr 20, 2018 5:17 am Post subject: Re: Turbo header primary pipe size |
Yes, smaller tubes will spool the turbo faster.
If you've got the money for it, get a ball bearing turbo as they spool up really fast. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
Stripped66 Samba Member
Joined: May 31, 2005 Posts: 3470 Location: Charleston, SC
Posted: Fri Apr 20, 2018 6:54 am Post subject: Re: Turbo header primary pipe size |
1 1/2" primaries, as short as possible.
How fast your turbo spools will critically depend on choosing the correct size turbo. Know what your goals are, be realistic about those expectations, and size the turbo accordingly. _________________
66brm wrote: |
Bodacious wrote: |
Why not just make a custom set of wires with a Y splice in them. Then you could just run one distributor. |
I don't think electrickery works that way |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Fri Apr 20, 2018 8:08 am Post subject: Re: Turbo header primary pipe size |
I have an 1 5/8" header on my 1776 with a Garret GT17...spools fine.
I think picking the correct size turbo is far more important than the correct size pipe. As long as you aren't sticking a 1/2" or a 4" collector on it, I think you will be fine, and the difference between say a 1 1/2" and 1 5/8" piping will be unnoticeable. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Bugsy61 Samba Member
Joined: March 20, 2011 Posts: 256 Location: Peoria, Illinois
Posted: Fri Apr 20, 2018 8:10 am Post subject: Re: Turbo header primary pipe size |
Inch and a half, or inch and 3/8 will both work fine. If I lived in New Zealand, I'd order a K03 ($100 on ebay) and a K04(also $100), have them both shipped in the same box to save on shipping. Try them both, keep your favorite, and sell the other one for a profit. K03 makes 200 HP on Audi 2 liter engines. What are you duty taxes on imported parts? |
