metropoj Samba Member
Posted: Fri Apr 20, 2018 5:27 am Post subject: Add your $0.02. Westy contemplation of 1.8T & flipped tranny |
So, being amazed with things such as reversed 1.8t, regular 1.8t's, flipped trannies, I started collecting bits and Research the hell out of things.
The plan I settled on is AEB 1.8t 20deg install with flipped PASSAT DVX tranny.
I have drawn the following conclusions and would like some input from the more talented people on if what I have concluded makes sense
My 86 Westy is currently running a well sorted TiiCo with stock tranny. HP around 118HP. at 120kmh ( 70 MPH ) I turn around 3900 rpm in 4th. I run CLK's at a height of 27.2in.
My concern is if the Passat 5spd DVX + AEB 1.8T makes sense based on weight, HP and torque given my situation. I don't run mountains but don't want to be downshifting all the time either.
Stock AEB HP and Torque are way up there in RPM ( around 5500 for HP ) .
However, Stage 1 chip brings this all down into the 3500 rpm range. Graph at far bottom....
I have tried to compare what RPM I will be turning at 120kmh ( Approx 70 MPH ) in 5th to see where it lies WRT HP and Torque.
DVX vs AUF:
Flint had mentioned about the AUF tranny and that it wasn't a whole lot different than the stock Passat offerings of the late 90's (in North America )
Sure enough, the number show that a 4.11 R&P will mean the motor will turn at 3k at 120kmh.
The DVX ( what I have ) will turn at 2880rpm at 120 kmh.
Both are a little low IMO but I'm more interested in widely available tranny than what we would deem "oddball" here in North America. When I say 'oddball', I mean other 012 trannies not widely available in our market space.
AUF numbers:
DVX Numbers:
What I'm trying to figure is if the HP and torque around that Vertical Red Line I drew on the torque graph would suffice for a Westy.
I am thinking I MAY be OK?
The Red Veritcal Line falls around 240 Torque and 125 hp.
This should allow for some decent cruising in fairly flat terrain with a family of 4. I suspect if I rev much lower like at 100 kmh I'll have to stay in 4th.
Curious if you would think the RPM range are OK of if I should just stay with a 4 speed and be happy screaming along at 3900 ... _________________ John.
86 TiiCo powered Westy. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Fri Apr 20, 2018 6:46 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
Do some research on clearances, mounting heights, CV joints and all that.
I say this because I have a friend who was working on this project on a '78 Bus.
He had the transmission and all that, and spent a lot of time and money trying to make it all work.
However, the output flanges end up pretty high in relation to the body of the gearbox when it is flipped. So you end up needing high-angle CVs and still have a low-hanging oil sump.
Depending on how you plan to use the Van, this might not be an issue. But if you want to go off-road a little, then certainly read about this before you pull the trigger.
My friend is abandoning the flipped gearbox, he is going to regear a standard Bus transmission instead. _________________ Dave Cook
1973 Wild Westerner
My Thing |
Zeitgeist 13 Samba Member
Posted: Fri Apr 20, 2018 7:16 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
Yeah, I think this approach will require lowering the drivetrain and raising the suspension like on my ALH build. I like that combo. How will you deal with the bellhousing? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1039 Location: san diego
Posted: Fri Apr 20, 2018 7:29 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
There's a good bit of information on the brick-yard and the club8090 sites.
Look for ultimate engineering, also I think they offer a kit.
Why not run the engine reverse rotation,it seems that it works every bit as well, the effort in flipping the transmission and getting it to function properly, surely it would be easier to modify the engine.
I'm now sat here wondering if a Subaru engine would run backwards. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Fri Apr 20, 2018 8:14 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
I'll fill in the rest of the story for fun but I didn't want to get into any particulars on this yet besides the HP / Torque side of things ... it muddies the waters. If the HP / Torque doesn't work well, there is not much sense in proceeding IMO.
I will proceed as follows on the rest:
1. I will use the Ultimate Engineering adapter.
2. I haven't decided on Tims' 130mm Flower Pot Drive axle shaft adapters or something else. I contemplated to get my 108mm axle shafts drilled to mate 100mm CV's and push the spacers to the wheel side of the axle shafts. I need to get proper clearance in the trailing arms and axle shaft length correct for the articulation.
There is a fellow I'm discussing with who can make 20mm thick 108mm to 100mm CV adapters for a reasonable amount. My next concern is if 40mm of space on the CV's will cause issues. I believe a max of 30mm has been discussed. I can't cut the adpaters down as it'll be too thin to hold the torque.
2. I am planning to not cut the Bellhousing at first. I have followed the German website link that did a 15mm flywheel spacer instead. A fellow in Quebec here is doing something similar and presented a good idea on a solution. I cut the end off a Manual crank 1.8T and drilled out the threads. This will be machined to fit onto my auto crankshaft engine and provide a spacer / pilot bearing holder for my flywheel.
3. 100mm 944 CV's will articulate to 22 deg which is the plan to try out first.
4. The tranny nose mount drops the drivetrain 40mm. That's 1.5 inches. This doesn't seem like a huge deal to me but in practice maybe is ...
I have the option to create a Vanabarrow for mock up whilst I play with all this so I've got little to lose if this doesn't pan out... _________________ John.
Posted: Fri Apr 20, 2018 8:17 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
Oh, the thing about most of the UK stuff is that they are all Diesel guys with Diesel trannies. That's a whole other different set of torque and HP relationships that mean little to my scenario. I don't want to go Diesel. _________________ John.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Fri Apr 20, 2018 12:09 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
PM me to get some adapters at a better price, I have a friend in Europe who ran a small batch, I think he has a couple kits left.
I drove one with a M-Tdi engine, that's such a sweet combo! I loved flooring it and having my back against the seat, I was giggling and not afraid of breaking the transmission _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Fri Apr 20, 2018 1:12 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
You will be ok with that gearing and a tuned AEB. You will have to drop a gear to pass a car or for a long incline but it should pull fine in 5th on the highway.
You can just use 108mm CVs on the stock Vanagon axles to bolt them directly to your flanges, part #701498350X, these have the same spline as Vanagon axles and 108mm diameter. |
Posted: Fri Apr 20, 2018 3:38 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
xoo00oox wrote: |
No need the "X" in the part number, better for researches X means rebuilt in VAG parts listings.
I found out about these CV's back in 2011 when I mounted my ZF/Renault UN1 transmission with DeLorean Löbro style drive flanges and I wanted something plug and play. Took me 20 hours of reading specs in a massive chinese catalog to find them out (108mm , 33 splines) Only model they were mounted on was T4's til July 1994.
Happy swapping guys! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Mon Apr 23, 2018 5:08 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
xoo00oox wrote: |
Thanks Andrew for the real world experience and assurances. You trailblazing has been quite inspiring.
I had originally planned on the 108mm Early Eurovan with the matching Vanagon splines for my project.
I was cautioned by Tim that some issues arose, I assume with the articulation that a flipped tranny will introduce, that made them difficult to assemble into the vehicle and keeping the CV together.
This is why the suggestion to go 130mm to 100mm adapters that carried a decent price to them. _________________ John.
Posted: Mon Apr 23, 2018 7:00 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
metropoj wrote: |
xoo00oox wrote: |
This is why the suggestion to go 130mm to 100mm adapters that carried a decent price to them. |
Interesting, maybe they're relying on that adapter as also being a spacer. I can get away with no spacer on my jobs but I guess with the trans being flopped, the hubs are up much higher. Good luck with your project, It'll be nice to follow it along.
Andrew- |
Posted: Mon Apr 23, 2018 7:05 am Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
xoo00oox wrote: |
Andrew- |
Bingo. Yes, I believe 20mm on one side and 10mm on the other, not 100% sure on that off the top of my head though. _________________ John.
pechaaa Samba Member
Joined: July 05, 2017 Posts: 38 Location: Europe, Latvia
Posted: Mon Oct 28, 2019 12:50 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8t & flipped Tranny |
ALIKA T3 wrote: |
xoo00oox wrote: |
Happy swapping guys! |
I would like to see that! |
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Mon Oct 28, 2019 3:13 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8T & flipped tranny |
If I was ten years younger I'd peruse a mid engine 1.8T.
Cut out below the rear seat, fit the 1.8T and transmission behind it, Box in the transmission and have trunk space.
I think Furryotter did a midengined Subaru, but had to cut the rear suspension arms and weld them narrower to fit the Subaru motor. The I.8T is taller and narrower, just might fit. |
Posted: Mon Oct 28, 2019 3:35 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8T & flipped tranny |
I've been cogitating on that longitudinal mid-engined approach for a while now. Now that someone has done the transverse middy, I'm also contemplating that kind of wild project. VW was kind enough to offer us lots of options for drivetrain swaps. _________________ Casey--
y u rune klassik? |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Oct 28, 2019 5:02 pm Post subject: Re: Add your $0.02. Westy contemplation of 1.8T & flipped tranny |
About that APR graph you show with the stage 1 tune, I contacted apr and several of their distributors and they said no-go for specifically the aeb.
This was several years ago and things may have changed since then, but they said they quit doing the aeb because they couldn't flash it.
Only year 2000 and up.
There are chipped ecu's available for the aeb, but I believe you will only see up to about 190-195 h.p. on that.
I'm guessing others on here will know if this is at all correct.
Also with the auf (that's what I have) I think you really won't be happy with tires that are 27" diameter.
I have 225/55/16 at 25.7 and I think it's about perfect for city driving, but still have to downshift climbing.
Don't get me wrong, I seriously love this engine and trans combo, but it wouldn't be fun climbing with 27.2"
Just my lonely opine.
Also I do have a chipped ecu. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
