Vmvw Samba Member
Joined: April 20, 2018 Posts: 1 Location: North Carolina
Posted: Fri Apr 20, 2018 3:55 pm Post subject: Bus starts but turns off right away |
I have 1973 bus I rebuilt the engine completely and changed everything. Broke the engine on a stand and it sounded good. I put the engine in and was able to drive it around for the day. I filed up my gas tank and found a gas leak from the gas tank. Fixed the hole and not more leak. Put the gas tank back in and now the bus starts but turns off right away. I push on the gas peddle but still cuts off. I read some forums on here and they said vacuum leak. I checked all hoses and they are braned new hoses and no where for it to leak. I checked again because that what you guys say and after that I checked again and again and again. The electric fuel pump works checked the wires all good. I do not know what else to look at. Please help |
Xevin Samba Member
Posted: Fri Apr 20, 2018 4:31 pm Post subject: Re: Bus starts but turns off right away |
I’m kinda interested in what induction set up you running.
Welcome to the Bay forum _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Apr 20, 2018 5:21 pm Post subject: Re: Bus starts but turns off right away |
Welcome to The Samba, vmvw. It's good to see you checked other threads for this problem. I'm pretty new to the ACVW scene, but have learned a lot in the past year and a half since I got my money pit.... I mean van.
The problem can be caused by a few things, but most likely is a vacuum leak. Hoses aren't the only source of leaks. Connections can just be a little too loose, or an elbow may have a crack that is invisible. I bought a vacuum leak tester on eBay which is very helpful. It blows low pressure smoke thru the vacuum system, and little puffs of smoke reveal the problems. You can also make one yourself. Just do a a Google search.
And good luck! Post some pics of yours when you get a chance. Sambanistas love seeing new bays. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Fri Apr 20, 2018 5:37 pm Post subject: Re: Bus starts but turns off right away |
Where in NC are you located? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
kurtwil Samba Member
Posted: Fri Oct 05, 2018 2:56 pm Post subject: Re: Bus starts but turns off right away |
I have the same issue now, can't figure it out I've been playing with the wiring diagram and multimeter for a couple of day still no joy.
Is your bus fixed?
It start every time but die right away, gaz pedal has no effect.
1975 FI.
New AFM in the mail. probably not going to fix it. _________________ 1975 westy |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Oct 05, 2018 3:08 pm Post subject: Re: Bus starts but turns off right away |
kurtwil wrote: |
Is your bus fixed?
1975 FI.
New AFM in the mail. probably not going to fix it. |
First confirm the AFM is plugged in, if that doesn't solve it test for power at the fuel pump terminals while cranking and running, also when the flap in the AFM is depressed (key on). Report back with what you find. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Oct 05, 2018 3:24 pm Post subject: Re: Bus starts but turns off right away |
AFM is plug in but has the same symptom unplug. the reason I jumped the gun and order one, should be in early next week.
power get to the fuel pump. key on and AFM flap open the pump is running, I've put my hand and felt the pump running. with the pump disconnected the bus doesn't want to fire, plug it back and it fire right away but dies right away.
crank the motor, the RPM goes up and dies right away. it fire quite nicely but it seams like the ignition switch doesn't want to stay engage.
All ground are good, tested from ECU plug, pin 5 and the other 2 pin 15 pin 16 I think. _________________ 1975 westy |
Our79Westy Samba Member
Joined: August 08, 2012 Posts: 97 Location: Bronson, FL
Posted: Fri Oct 05, 2018 3:47 pm Post subject: Re: Bus starts but turns off right away |
me too..
one minute my bus is running great...then I shut it off...then the next startup it would fire but not stay running:
one time it was because I didn't plug in the ECU (i.e. the brain box),
one time it was the s-boot to inlet plenum,
one time the aux air regulator hose cracked where I couldn't see,
one time the vacuum hoses from the engine ventilation AND deceleration valve looked like they was seated in the s-boot, but weren't,
one time the vacuum hose fell off the broken fitting of my airbox charcoal filter vent valve,
one time the vacuum hose to my deceleration valve disintigrated,
one time my fuel pump was wired in reverse. ...yes it will run in reverse...sounds aweful!
one time the vacuum hose slipped off my disributor because I replaced it with too big a hose,
one time my brake booster hose split...
I'm sure I missed a few others
so welcome to the one time club sounds like you have fire and gas, now you need to find air...
theres a lot to learn about vacuum leaks, good luck and please keep us posted on your status/solution. _________________ 1979 Westfalia DELUXE 2.0 FI manual
Mexican beigeutiful and mostly original.
See the most up to date status of Constance on YouTube
https://m.youtube.com/channel/UCvO1ZedS22IepvvRYaTxiPQ
My 1979 Westfalia Campmobile's sundry Tales of Constance
http://www.thesamba.com/vw/forum/viewtopic.php?t=620965
1990 Vanagon, Red, Driven 70,000 miles till sold. |
Posted: Fri Oct 05, 2018 3:49 pm Post subject: Re: Bus starts but turns off right away |
OK, sounds like a huge vacuum leak, but lets rule out the ignition switch first.
Connect a jumper wire (alligator test lead) between the terminal on the coil with all the black wires on it (should be #15) and the battery + terminal. If the problem persists the ignition switch is likely good, if it still dies move on to vacuum leaks, disconnect that test lead as soon as the test is done. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Oct 05, 2018 5:22 pm Post subject: Re: Bus starts but turns off right away |
No joy, still the same issue.
At least I didn't tore the whole steering wheel to get to the switch. Earlier today I started there with the multimeter, chasing a short or open wire.
This is a great little trick to rule out the switch.
I have a petronix module and I already bought a second one, thinking that could be the culprit, but no.
By the way thank you.
Going to bed and ill be back on it tomorrow. _________________ 1975 westy |
SGKent Samba Member
Posted: Fri Oct 05, 2018 6:50 pm Post subject: Re: Bus starts but turns off right away |
Pour a teaspoon of gasoline in the S-boot / plenum - then start it. see if it runs longer or shorter. That will tell you if it is fuel related.
Put a timing light on it and start it. See if the light dies at the same instant it starts to die.
You could have something as simple as the distributor is not all the way in so once the RPM comes up it jumps out of the drive gear etc. Or you could have a vacuum leak as others have suggested.
If it is fuel related put a pressure gauge on it and do the AFM flap test again. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Oct 06, 2018 1:02 pm Post subject: Re: Bus starts but turns off right away |
Update; putting fuel in the s boot this morning and it did run for 2 sec more.
So I test the pump again. I removed the fuel line behind the fuel pressure regulator pinch the line to the tank. I ran the fuel pump and lots of fuel was coming out. at least it cleaned the line. Tomorrow Ill go buy the T adaptor for my fuel pressure gauge and a new fuel filter just in case.
It might be a vacuum line. I started playing with the 2 screw ( one on the AFM and the one on the throttle body) and unscrewing them pretty munch all the way out, I was able to get the RPM up with the pedal floored in. but like always the bus die right away. normally the RPM would go to 2k and die now its 3k but I was able one to get the bus to 4-5k RPM.
now putting fuel in the boot worked once but I tried a second time and I flooded the spark plug. so I changed the spark plug.
I retested the double relay, rechecked all the ground, I tested the resistance of the fuel injector by the ECU all 4 was at 4ohm.
I put a new battery I the bus and as I play around I have my car running connected with boosting cable.
This one is a good one _________________ 1975 westy |
SGKent Samba Member
Posted: Sat Oct 06, 2018 1:52 pm Post subject: Re: Bus starts but turns off right away |
so the problem is somewhere in the fuel or induction system. You can rule out ignition I think. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sat Oct 06, 2018 2:04 pm Post subject: Re: Bus starts but turns off right away |
kurtwil wrote: |
Tomorrow Ill go buy the T adaptor for my fuel pressure gauge and a new fuel filter just in case. |
There is a test port on the fuel rail between #3 & #4 injector (LH side of engine), don't lose the little plug bolt or the washer under it. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Oct 06, 2018 2:17 pm Post subject: Re: Bus starts but turns off right away |
I saw the test port but my adaptor don't fit in there I don't think I saw thread on
the exterior of the test port.
That screw is small and my adaptor don't screw on the inside. _________________ 1975 westy |
Posted: Sat Oct 06, 2018 3:44 pm Post subject: Re: Bus starts but turns off right away |
Clamp a 5/16" hose over the outside of the test port. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Mon Oct 08, 2018 9:28 am Post subject: Re: Bus starts but turns off right away |
Update; so this morning it did the same thing and realize it was shutting down when the alternator lite would come on.
I disconnect the plug on the alternator and the BUS WAS RUNNING GREAT.
so I went and use the boosting cable to keep my battery charge and it shut down. connecting battery to battery.
the bus run with out the alternator and the boosting cable. as soon as the voltage go up it wants to shut down. pretty weird. now im in the diagram and CHASING a ghost.
any idea?voltage regulator? _________________ 1975 westy |
SGKent Samba Member
Posted: Mon Oct 08, 2018 10:00 am Post subject: Re: Bus starts but turns off right away |
I'd stop for a second and give some folks here a chance to think this one thru. Electrical problems can get worse really quickly due to the nature of electricity. Can you remove the battery cable in the mean time? _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Oct 08, 2018 10:04 am Post subject: Re: Bus starts but turns off right away |
Battery is disconnected and charging right now. I've tested the wire going to the voltage regulator to alternator no short to ground and all have continuity.
weird that as soon as I connectect boosting cable it die. if I connect the plug on alternator in die. it runs perfect without the 14v _________________ 1975 westy |
Posted: Mon Oct 08, 2018 11:09 am Post subject: Re: Bus starts but turns off right away |
kurtwil wrote: |
weird that as soon as I connectect boosting cable it die. if I connect the plug on alternator in die. it runs perfect without the 14v |
Maybe you had a reverse charge on the battery? Do the jumper cables spark much when you hook them up? Does the alternator spark much when hooked up? |
