Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Mon Oct 08, 2018 11:14 am Post subject: Re: Bus starts but turns off right away |
First thought, from a bit of a newbie, how is your positive battery cable connection? If a bad connection gets too much power through it, it'll cut out sometimes all together from the increased resistance? (something I've seen more than I could explain) This would prevent power to your ignition and therefore your spark. If it is kinda loose or corroded, I'd start by fixing that.
Id also check all the connections off the alternator. Follow the wires and just make sure they aren't corroded or loose and that they match the diagrams. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
kurtwil Samba Member
Posted: Mon Oct 08, 2018 4:17 pm Post subject: Re: Bus starts but turns off right away |
ill check for reverse charge but no spark when I connect anything.
Tomorrow ill check the ground strap on the transmission and go from there.
I have a battery charger right now on the battery charging at 2amp and the bus run great. As soon as I switch it to 10amp the bus die.
Im using a deep cycle crank battery right now in the bus.
ill change the positive cable from the Batt to the Starter tomorrow, it is the original cable still.
I tried removing the batt al together and use the booster cable from my running car and no joy. _________________ 1975 westy |
Posted: Mon Oct 08, 2018 4:23 pm Post subject: Re: Bus starts but turns off right away |
Maybe a bad coil or condenser that can't handle the higher voltage, these parts see a much higher voltage than the rated 12v so if you are upping the voltage from say 9 volts to 12 volts they may actually see a voltage jump from 200 volts to 300 volts which could cause internal arcing. |
Posted: Mon Oct 08, 2018 4:42 pm Post subject: Re: Bus starts but turns off right away |
Wildthings wrote: |
Maybe,
I use a petronix system and just bough a new one , thinking it was the issue.
The coil is at 3 ohm, I do have a spare one, ill try.
bus runs great with out the alternator. I can rev it up with no problem. lots of power. _________________ 1975 westy |
SGKent Samba Member
Posted: Tue Oct 09, 2018 6:53 am Post subject: Re: Bus starts but turns off right away |
My thoughts on this fall into two paths - the first being a reverse battery or revered charge. The other being that the additional voltage changes the wave form on the electronic ignition just enough that the ECU can't use the baseline form to make injector pulses. It is known that some electronic ignitions do not work with FI. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
kevin77westy Samba Member
Joined: November 12, 2004 Posts: 795 Location: Ocean Springs, MS
Posted: Tue Oct 09, 2018 5:48 pm Post subject: Re: Bus starts but turns off right away |
If it runs without the VR wired up then I would suspect that or the alternator. Easy enough to swap out the VR. If its not the fix then you have a spare. I had a bad one that would make my bus shut down but it took minutes, not seconds. VR got sizzling hot in that short amount of time. Replaced it with a Bosch solid state and was back on the road. Tell us about your alternator. I can't help but think its some weird demon in the charging system. |
Posted: Tue Oct 09, 2018 6:01 pm Post subject: Re: Bus starts but turns off right away |
Today I replaced the strap on the transmission (ground) I also redid de ground
terminal on the left side of the plenum and the ground for the double relay.
I changed the coil, distributor cap. had a spare VR so I swap it.
I also removed all fuse S1-S12. removed the fuse for the backing up switch.
I have the alternator disconnect but only the plug. tomorrow I'll disconnect it completely and Ill keep just the essential wire on the starter.
Received the new AFM, definitely runs better but will shut down.
The bus ran for 1 hr today but as soon as I put more current it die.
While it was running I though about checking the timing. I couldn't plug my meter it die right away. _________________ 1975 westy |
SGKent Samba Member
Posted: Tue Oct 09, 2018 6:13 pm Post subject: Re: Bus starts but turns off right away |
do you have the old distributor with points in it? If so try it. Some electronic ignitions will not work well with FI. The reason is that the FI system uses the waveform from the coil to initiate the injector pulse. If that waveform is other than how the ECU was built to work with the ECU fails to read it so the injector pulse goes away. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Oct 10, 2018 6:41 pm Post subject: Re: Bus starts but turns off right away |
Ok today I Replaced the batt cable going to starter, replaced all terminal on the
wire going to the starter.
Disconnecting all wire and only keeping the essential to run the bus did nothing.
Im suspecting the ECU, Coil, maybe the alternator.
Maybe the bus is not able to run while a battery charger on the batt at 10 amp.
but it should, I can't even boost the bus.
I think what happen is I had the bus in the garage with a trickle charger on the
batt and the key stayed in the on position for a while and fried something..... but what?? double relay? coil? ECU? VR?
It run but only with the alternator disconnected.
I tried to go for a drive but the batt was getting low so it was bucking a bit.
Tomorrow Ill double check the blue wire going to the alt light on the dash. _________________ 1975 westy |
Posted: Fri Oct 12, 2018 3:29 pm Post subject: Re: Bus starts but turns off right away |
just to close this thread.
The issue was the Coil and ignition module. put the point back in and the issue disappear.
Its funny that for 10 year the ignition system work, replaced it and the same
snag was there. so I got a bad one from CIP1and the old one got broken from
me letting the key on in the bus all winter with a charger on ( bad move on my part).
Thank for all the help. now the bus can go in the garage all winter and im ready for the spring. _________________ 1975 westy |
