Tangerine Samba Member
Joined: May 09, 2016 Posts: 41 Location: North Central Arkansas
Posted: Fri Apr 20, 2018 7:10 pm Post subject: Undercoating Opinion |
I have a 71 Super with original floorpans and most body panels (only 1 fender has been replaced). I've removed some of the undercoating and the paint/metal under that has been (so far) 99% rust free. Since the undercoating is 46 years old and pretty much dry and cracked. I'm planning on removing all of it (eventually), as I've heard that loose undercoating can collect and hold water, causing rust issues. Should I put new undercoating on or leave it bare? If replace, any suggestions on brands would be appreciated also. Thanks. _________________ 68 Variant FI
71 SB Sedan
73 SB Cabriolet |
Buggeee Samba Member
Joined: December 22, 2016 Posts: 4421 Location: Stuck in Ohio
Posted: Fri Apr 20, 2018 7:45 pm Post subject: Re: Undercoating Opinion |
Chris Vallone of buggin youtube fame has a video explaining that he likes to put a light coat of rubberized undercoat just under the fenders. When the fenders were just paint under there he had some rocks occasionally ding the metal from underneath, causing a star patterned cracking of the paint on the top side of the fender. He said the rubber coating stopped that from occurring. He seemed to think the undercoating all over the place, however, would trap water if I remember. So he just does the fenders. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Sat Apr 21, 2018 3:57 am Post subject: Re: Undercoating Opinion |
The undercoating has preserved your car to this point, I’d say clean the old off & reapply. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
vamram Samba Member
Posted: Sat Apr 21, 2018 6:43 am Post subject: Re: Undercoating Opinion |
Agreed, clean it off well, clean the surface, and re-apply. Well-worth the trouble in my experience.
But yes, water getting in where it's dried out and cracking will become rust at some point. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sat Apr 21, 2018 7:07 am Post subject: Re: Undercoating Opinion |
i prefer a rocker schutz or bedliner style product thats paintable....the foamy spray can stuff is crap...its primary function is to conceal really bad welding and attempts at rust repair on a vehicle you're trying to sell |
vamram Samba Member
Posted: Sat Apr 21, 2018 7:10 am Post subject: Re: Undercoating Opinion |
I've not had any issues w/the sprayable stuff. Although it's not nearly as durable as the stuff the dealerships slathered on.
I will try the paintable stuff when I go over the pans this summer... _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
MI-Bug Samba Member
Joined: March 12, 2016 Posts: 117 Location: Marne, MI
Posted: Sat Apr 21, 2018 8:30 pm Post subject: Re: Undercoating Opinion |
I like the painted look so am going to try clear "chip guard" under the fenders and wheel wells... once I have all the old undercoating cleaned off. |
Posted: Sun Apr 22, 2018 8:38 am Post subject: Re: Undercoating Opinion |
Thanks for your suggestions/thoughts. I was wondering if the spray can stuff was any good. Some better than others?
Also, on same car but different issue, I'm rebuilding the front end with the TopLine kit and have a question about that. I got their Caster-Fix option, but I'm not sure if I should install it. The car is original height/stance. Should the Caster-Fix option be used if I'm not going to lower the car any or change the springs? If I did install it, what would be the result of increased caster? I'm not a suspension person, but I'm assuming a stronger 'centering' function?
71 SB Sedan
73 SB Cabriolet |
vamram Samba Member
Posted: Sun Apr 22, 2018 8:46 am Post subject: Re: Undercoating Opinion |
The caster adjust kit is only for cars that are lowered. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
bluebus86 Banned
HippyTom Samba Member
Joined: December 18, 2013 Posts: 676 Location: Florida, West Pasco
Posted: Sun Apr 22, 2018 4:47 pm Post subject: Re: Undercoating Opinion |
I painted the inside of my fenders and wells. No undercoat or bedliner.
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sun Apr 22, 2018 4:55 pm Post subject: Re: Undercoating Opinion |
MI-Bug wrote: |
Factory Chip Gaurd rusted as fast as not having it on.
You want something like this.
https://www.amazon.com/Approved-Brushable-Asphalt-Bitumen-Base-Undercoating/dp/B002HOG28G
If you want a cheap solution, tree wound spray works good. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
modok Samba Member
Posted: Sun Apr 22, 2018 7:46 pm Post subject: Re: Undercoating Opinion |
I used Morton epoxy bedliner. It's holding up very well about nine years later. |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Mon Apr 23, 2018 10:21 am Post subject: Re: Undercoating Opinion |
I used flex seal. Yes, the stuff the crazy guy on the tv sells. It takes about 7 cans to do the whole floor pan and all the fenders. One can doesn't go very far. Its expensive. But it works, and it looks great. My whole interior is done with the stuff too. Its holding up much better than I expected. But my car is by no means anywhere near a show car. |
AlmostHeavenWV_VW Samba Member
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Tue Apr 24, 2018 11:55 am Post subject: Re: Undercoating Opinion |
Anybody figure out how to coat the inside of the heater channel or Napoleon hat? Actually done it? I have used the Internal frame coat inside the tunnel and frame head. Also inside the frame horns. Fluid film would work well too but since it's oil based it could cause grief if you ever needed to do any welding or bodywork/paint in those areas.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Zundfolge1432 Samba Member
Posted: Tue Apr 24, 2018 12:13 pm Post subject: Re: Undercoating Opinion |
I wonder what particularly harsh environmental areas would call for, say North Sea oil rigs with constant exposure to salt spray or military and commercial aircraft which see heavy duty cycles 7 days a week. Going from 90 degrees plus temp on the ground to 50 below at altitude in less than half an hour. I bet they ain’t using the shit available at auto zone Walmart or harbor freight.... or some rubberized crap that traps and hides moisture or the stuff Uncle Bob spayed in his truck bed. As Glenda the good witch of the north observed “ “You had the secret dear all along it’s the ruby slippers” now click them together three times and say there’s no place like home... |
dualbay Samba Member
Posted: Tue Apr 24, 2018 12:21 pm Post subject: Re: Undercoating Opinion |
Undercoating sprays are not sealers - you would first have to apply your usual sealing coats of paint then from that point adding undercoating is up to you, but in general I don't see the point. |
Posted: Tue Apr 24, 2018 12:29 pm Post subject: Re: Undercoating Opinion |
That product is mainly meant to "encapsulate" existing rust - using it over bare metal to "prevent" future rust does pretty much nothing that primer sealer couldn't. |
Frodge Samba Member
Posted: Thu Apr 26, 2018 3:00 am Post subject: Re: Undercoating Opinion |
I had floor pans installed a couple years ago. There is no undercoating on my pans. I had this discussion with the installer, who had done 100s of pan installations. He said the undercoating traps moisture once it gets a loose spot. He went in to say to check the paint a couple times a year. |
