kaseyp Samba Member
Posted: Sat Apr 21, 2018 7:52 pm Post subject: Gap between Steering wheel and column |
I am replacing the aftermarket wheel that came with my 72 standard with an OEM wheel. Pulled off the old one and put the OEM one on and there is a gap between the wheel and column. Is this normal or could there be an adapter I need to remove? There is a plastic tab in the column side of the OEM wheel that creates the gap. Any ideas or suggestions? Thanks!! |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Sat Apr 21, 2018 10:12 pm Post subject: Re: Gap between Steering wheel and column |
Suppose to be around 1/8 inch gap. It is adjustable. But what is the adapter mentioned? Pictures? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Apr 22, 2018 5:16 am Post subject: Re: Gap between Steering wheel and column |
Cant remember for sure whats in a 72, but take a look underneath the dash and you should have 2 hex bolts or 2 allen heads that can be loosened and the outer column should be able to be slide forward or back maybe 1/4" or more. _________________ D-Dubya Manx clone - 63 Short pan,1914.
vamram Samba Member
Posted: Sun Apr 22, 2018 6:39 am Post subject: Re: Gap between Steering wheel and column |
The '72 has a single hex bolt underneath for this adjustment.
_________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Patrick_S Samba Member
Joined: June 23, 2016 Posts: 60 Location: The Netherlands
Posted: Sun Apr 22, 2018 7:06 am Post subject: Re: Gap between Steering wheel and column |
How big is the gap? The gap must be 2-4mm according to Bentley. Make sure it is not too tight or the steering wheel slides against the steering column. You will ruin multiple components of the steering column/wheel this way. Experience.
And there should be a metal circlip that holds the steering wheel at a set distance on the steering shaft. Right behind the grooves onto which the steering wheel slides is an indentation into which the circlip should sit. Make sure it is there.
After that there are two hex bolts along the steering shaft somewhere under the dashboard that allows the column tube+steering column to slide up and down. Use that to set the correct gap.
After all this is done. Turn around the steering wheel a few times, make sure that it doesn't touch the steering column at any point. But do make sure that the steering wheel touches the flexible copper plate on the steering column, or you will have no horn. |
