kymmitsu Samba Member
Joined: January 02, 2018 Posts: 7 Location: Melbourne Vic Australia
Posted: Sat Apr 21, 2018 8:22 pm Post subject: Idles Rough |
Hi
Wondering if I could get some advice on my 71 STD Beetle.
I purchased it 6 months ago - it ran OK but when cold was a bugger to keep running. Found Choke spring broken.
Its a AB engine - which should be a 1300 but PO insisted its a 1600. Anyway externally I can tell???
It had a 34 PICT 3 Bocar on it - it needed a kit - so I though I would buy a Solex from Volksbitz. Also had a 009 Distributor
A service sheet from PO showed Compression ~ 120 all cylinders.
I have done
Valves
Spark Plugs - Bosch W8AC .6mm
New Leads
Solex Carb - set by Tim for Vac Adv
Coil
Dist - Vac Adv Electronic.
Tested with "start you bastard" for Vaccum leaks.
Whilst I waited for the Carb (US to AU) I added the above - didn't run up.
Also moved Fuel Filter to under car
Once arrived I fitted - ran through the setting up of the Carb - Ran .. Ok but it would take 5 or so seconds to return to idle. Felt really strange downshifting Ran through the settings again.
Took it for a spin - wouldn't idle correctly had to use throttle to keep running.
I discounted the Carb so I started to add back some of the old parts replaced.
Started with the Dist - back to the 009, then the coil. Strangely - after the coil was replaced it returns to idle as expected - no delay???? still not a smooth idle.
Any ideas why the delay on the coil ?????
Cleaned the carb idle jet (one on righthand side) + turned it 1/4 of a turn with no real difference. Even cleaned and put the Bocar Idle jet in.
So I am thinking Ill need to clean the carb - maybe some gunk from rebuild or more likely when I moved the filter has gone through.
Is there anything I can do before removal.
If I need to remove any pointers to what I should be looking for when opening it up?
(I have put on the Electronic Ignition and Coil again)
Any advice is appreciated
engine Pic incase
Ricksurfin Samba Member
Joined: September 02, 2017 Posts: 295 Location: Huntington Beach, CA
Posted: Sat Apr 21, 2018 8:26 pm Post subject: Re: Idles Rough |
Not sure if it’s the answer to your problem, but you said you adjusted valves to .15mm? Spec is .006mm. |
Posted: Sat Apr 21, 2018 8:28 pm Post subject: Re: Idles Rough |
double post |
Posted: Sat Apr 21, 2018 8:32 pm Post subject: Re: Idles Rough |
Ricksurfin wrote: |
Good spotting - thanks - Typo |
mukluk Samba Member
Posted: Mon Apr 23, 2018 3:16 pm Post subject: Re: Idles Rough |
Ricksurfin wrote: |
Spec is .15mm or .006 inch -- .006mm would be waaay too tight. _________________ 1960 Ragtop w/Semaphores "Inga" |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Apr 23, 2018 3:28 pm Post subject: Re: Idles Rough |
Make sure the two ports on the rear of the carb are not sucking vacuum and are plugged inside. If they are sucking vacuum, it will never idle right. |
