New Engine Compartment Seals Question
FL-Frank
FL-Frank is offline
PostPosted: Sun Apr 22, 2018 9:25 am    Post subject: New Engine Compartment Seals Question Reply with quote
We’ll be dropping the engine out of the ‘67 Beetle soon, and will replace the engine compartment seals and tar boards while the engine is out.
The new seals from WW are coated with a white milky substance that I’d like to clean off prior to installation of the seals.
Assuming the coating was applied to protect the rubber from degradation, is it
ok to remove it and what’s the best removal method?
“Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD
seethesvt
seethesvt is offline
PostPosted: Sun Apr 22, 2018 10:12 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
I believe the white residue is a release agent for the mold from manufacturing.
67rustavenger Premium Member
67rustavenger is offline
PostPosted: Sun Apr 22, 2018 10:46 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
You can likely remove the release agent with some house hold cleaner. Like 409, simple green and the like.
I installed one of those seals last weekend in my 67 and found that if you bend the upper lip of the channel that it lives in. You can almost get it to go in without a fight. It took me half an hour. But my car is not perfect so I wasn't too worried about a little scratch on the engine compartment paint.
Once the seal is installed, crawl under the rear of the car and look at the bottom of the seal channel. Mine looked good from the top side. But there were a few places where it wasn't completely in the channel. I used a flat screw driver to gently get the seal in the channel.
YMMV.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Cusser
Cusser is online now
PostPosted: Sun Apr 22, 2018 11:40 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
I sprayed my rear seal forward side with silicone lube before I installed the engine, so it wouldn't grab.
FL-Frank
FL-Frank is offline
PostPosted: Sun Apr 22, 2018 12:14 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
I found that rubbing the seals with paper towel soaked in mineral spirits removes the white residue build up. Now that they’re cleaned up, I’ll treat them with a healthy dose of glycerin.
rcooled
rcooled is offline
PostPosted: Sun Apr 22, 2018 1:04 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
FL-Frank wrote:
...what’s the best removal method?
Sounds like mineral spirits is doing the job for you. Just wanted to add that gasoline will remove that mold release from weatherstripping quick & easy.
This type of screen roller (found at most any hdwr store) can be helpful when installing an engine bay seal ↓
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
FL-Frank
FL-Frank is offline
PostPosted: Sun Apr 22, 2018 1:21 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
Yes, planning to use the screen fabric roller. Very Happy
andk5591
andk5591 is offline
PostPosted: Sun Apr 22, 2018 3:21 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
REALLY? I have never tried that - Assuming you get the top or the bottom in and then run that along the other side that isnt in....Works well?
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
rcooled
rcooled is offline
PostPosted: Sun Apr 22, 2018 6:28 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
andk5591 wrote:
REALLY? Assuming you get the top or the bottom in and then run that along the other side that isnt in....
Yes, really...and that's exactly how you do it. Use the wheel with the groove...no lubricant needed.
It also helps to make sure the whole channel is fully opened up and free of dented-in edges.
Cusser
PostPosted: Sun Apr 22, 2018 6:37 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
I learn something new every day here !!!
rcooled
rcooled is offline
PostPosted: Sun Apr 22, 2018 6:40 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
Congrats on reaching 20K posts, Cusser! Applause
andk5591
andk5591 is offline
PostPosted: Mon Apr 23, 2018 5:24 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
Gonna stop by Lowes Tuesday and snag one for the shop.....Thanks for the awesome tip....I HATE putting those seals in...
FL-Frank
FL-Frank is offline
PostPosted: Mon Apr 23, 2018 5:39 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
I’ve read on here where several recommend using the 1966 and earlier seal on the ‘67...especially if running modified exhaust. The exhaust on my ‘67 is stock, so wondering if I should use the correct for ‘67 and later seal or switch to the ‘66 and earlier seal?
Is one easier to install than the other?
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Mon Apr 23, 2018 6:04 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
The "slot" that accept said seal is pretty much the same. You have to force that bugger in there! Now the shape of the external portion of the seal is different and the later style,... well... might block one's view of their installation progess. But once installed, I'm not convinced that the early is necessarily better than the later.
Andy T.
I do not know how to fix this. All I can say is it all works fine for me with what I use, Firefox.
dodgerodder
dodgerodder is offline
PostPosted: Tue Apr 24, 2018 12:28 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
That is an awesome idea, thanks for sharing! Normally I find these things out after I struggle for hours and do it the normal way 😆
I will definitely use this idea when I get to that point
fl59bug
fl59bug is offline
PostPosted: Tue Apr 24, 2018 2:16 pm    Post subject: Re: New Engine Compartment Seals Question Reply with quote
Another tool I found pretty handy for installing seals was the seal channel opener tool available from Gab-fab (I think).
That tool will open up and restore the shape to the c channel, though I suppose you could do this without it, but it may be a little tougher.
FL-Frank
FL-Frank is offline
PostPosted: Thu May 24, 2018 9:24 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
I replaced the seals in the bug yesterday while the motor was out. The old seals were very brittle, so they came out in chunks, pieces, and bits. I found that running an exacto knife through the channels helped get all of the old material out. Luckily, the channels themselves were clean and straight so all I had to do to prep them was squirt some dawn liquid soap in them. Installation of the new seals was a breeze with the car raised on the lift and me standing in the engine compartment. All I had to do was insert the lower lip of the seal in the channel, and then push the upper seal lip into the channel using firm pressure on the screen roller tool. It took a total of about 10 minutes to remove the old seals and install the new ones.
BTW... I decided to stick with the correct for ‘67 later style seal.
Rome
Rome is offline
PostPosted: Sat May 26, 2018 8:43 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
Good going, FL-Frank.
What has worked well for me with the whitish residue is simply a rag or paper towel sprayed with WD-40 and swipe the surface a few times. Same technique to clean grease off spark plug cables.
Emeraldlion
Emeraldlion is offline
PostPosted: Sat May 26, 2018 9:54 am    Post subject: Re: New Engine Compartment Seals Question Reply with quote
As to the earlier seal on 67-later. If you search through some threads you will find some anecdotal stuff as well as pictures that the 66-earlier seal may not close up the gap to the rear tin. Depending on your exhaust the 67 later z style seal may touch your pipes so you may need to trim
