btracy Samba Member
Posted: Sun Apr 22, 2018 3:09 pm Post subject: spindle nut |
how tight do i make the locking front spindle nut, the one that has the allen bolt running through it.thanks for any info. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Sun Apr 22, 2018 3:16 pm Post subject: Re: spindle nut |
If I installed new bearings, I will snug it up to where the wheel will drag a little then back it off until I can slide the big thrust washer back and forth with a big flat blade screwdriver. You want it to take just a little effort to move it, but you dont want it so loose that it will slip around on its own. The allen screw gets tightened pretty tight. Cant give you a torque spec. Just tight as you can with a standard hex key. _________________ D-Dubya Manx clone - 63 Short pan,1914.
jgcooney Samba Member
Joined: December 02, 2013 Posts: 21 Location: North Carolina
Posted: Sun Apr 22, 2018 4:09 pm Post subject: Re: spindle nut |
andk5591 wrote: |
If I installed new bearings, I will snug it up to where the wheel will drag a little then back it off until I can slide the big thrust washer back and forth with a big flat blade screwdriver. You want it to take just a little effort to move it, but you dont want it so loose that it will slip around on its own. The allen screw gets tightened pretty tight. Cant give you a torque spec. Just tight as you can with a standard hex key. |
That's the way to do it. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sun Apr 22, 2018 5:30 pm Post subject: Re: spindle nut |
andk5591 wrote: |
I have seen 7 - 9 ft lbs for these allen head screws. I cut a little 6mm allen wrench and use that in a 6mm socket. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
