BugMan48 Samba Member
Joined: April 09, 2018 Posts: 4 Location: Longview Texas
Posted: Sun Apr 22, 2018 3:30 pm Post subject: Need ID Info |
Hey guys. I just scored a 65 Bug. It needs a lot of attention but the main body is not bad. However, I do not have a title. Can someone give me some more info off this serial number and suggest the best way to obtain a title for it? I am in Texas BTW.
Thanks
ZM[/url] |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9759 Location: Oregon
Posted: Sun Apr 22, 2018 3:54 pm Post subject: Re: Need ID Info |
It's a 66. Built in September 1965. The new model years began in August of the previous year.
Can't help on the no title thing. I live in Oregon.
Welcome to the samba. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Sun Apr 22, 2018 4:20 pm Post subject: Re: Need ID Info |
First thing I would do is check to make sure the VIN stamped on the chassis matches the plate in the trunk, a lot of states go by the chassis VIN if they don't match.
The Texas Department of Motor Vehicles should have information on what to do if the seller doesn't have a title. A quick look shows they do have a procedure for the current owner to get a replacement title, that would be the easiest thing. |
Posted: Sun Apr 22, 2018 4:21 pm Post subject: Re: Need ID Info |
67rustavenger wrote: |
Welcome to the samba. |
Awesome, thanks. |
Posted: Sun Apr 22, 2018 4:23 pm Post subject: Re: Need ID Info |
David_nc_72std wrote: |
The tag on the body should be the same as the one on the chassis unless it has been swapped, correct? Actually, I don't recall seeing one on the chassis. I will look again tomorrow. |
Posted: Sun Apr 22, 2018 4:34 pm Post subject: Re: Need ID Info |
BugMan48 wrote: |
Numbers should match, but body or VIN plate can get swapped around over the years. The chassis VIN is stamped on the tunnel under the rear seat.
Just remember, without a title, you DO NOT legally own the car, and if you are unfamiliar with the seller there is always the possibility it could be stolen, or the seller lacks the legal authority to sell it. |
rwf8ball Samba Member
Posted: Sun Apr 22, 2018 7:23 pm Post subject: Re: Need ID Info |
Contact a company called Classic Auto Title there in Texas as well. She did two titles for me. A little pricey, but they do all the work. You will have to have a police officer look at the vin. |
Posted: Mon Apr 23, 2018 9:48 am Post subject: Re: Need ID Info |
Awesome, I will give them a shout an see what happens. Thanks |
