gtixpress Samba Member
Joined: June 22, 2006 Posts: 283 Location: Mahomet, IL
Posted: Mon Apr 23, 2018 6:56 pm Post subject: Making bubble flares |
I purchased a bubble flaring kit to make new lines for my Squareback. It's a Neiko brand kit. One issue I have is that the kit marks up the brake line pretty good when it's tightened down. Another is that I'm having issues getting it to make a decent flare. They tend to be off center, or just uneven and look like crap. Is there a secret to doing this short of buying a several hundred dollar flaring tool that I will only use once? The brake tubing that I'm using is 3/16th Copper Nickel tubing.
Kit:
http://a.co/cNITQqP
_________________ Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Mon Apr 23, 2018 9:02 pm Post subject: Re: Making bubble flares |
Good tools are always worth it. I have an old Snap-On, maybe Blue Point, set for flaring ends. Purchased it new 25 years. Works every time. It does not leave marks on the tubing.
What brand is the flaring tool? Where did you get it from? Maybe you got a bummed one and need a good one. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Dale M. Samba Member
Posted: Tue Apr 24, 2018 7:00 am Post subject: Re: Making bubble flares |
As long a marked area does not interfere with flare nut I don't see issue....
Probably could have bought a factory (OEM style replacement) brake line kit for cost of flaring tool.... Lot less frustration also...
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-698-996-A
Just saying...
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Tue Apr 24, 2018 7:48 am Post subject: Re: Making bubble flares |
The seal happens on the head of the bubble. Below that basically does not matter. My bubble flare kit will leave marks on the tubing but not so severe. Once the flare is complete, I just clean the marks off the tubing with a very fine file. _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
slalombuggy Samba Member
Posted: Tue Apr 24, 2018 9:31 am Post subject: Re: Making bubble flares |
Make sure the cut on the end of the tube is square. Use a tubing cutter. Dress the cut so that the end of the tube is smooth and there is no burr from cutting it. Using the die as a guide only have as much tube sticking out of the clamp as it says in the instructions, too much and it will crush and go off center.
brad |
Posted: Tue Apr 24, 2018 10:33 am Post subject: Re: Making bubble flares |
This is the flaring tool:
https://www.amazon.com/dp/B00170V64G/ref=cm_sw_r_cp_ep_dp_iNO3AbE0XCWBH
Pretty standard unit and had decent reviews. Also saw it mentioned in other sites that it worked. You really have to crank down on the tubing holder otherwise when trying to flare it, it just pushes it through holder. Which causes the scoring on the outside. I use a tubing cutter, filed down the end, and also used a reamer to clean up the inside edge. I guess I'll just practice some more with it. I figured I would ask just in case there was a trick which makes the results better. I know this isn't exactly complicated. _________________ Joe P.
JudoJeff Samba Member
Joined: May 24, 2013 Posts: 1179 Location: Near Springfield, MA
Posted: Tue Apr 24, 2018 1:41 pm Post subject: Re: Making bubble flares |
Try a little oil on it before trying to flare it. _________________ ________________________________________
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig Sold May 10, 2021
1999 Ford GTRV Westfalia camper (30% bigger Westy layout) |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Apr 24, 2018 3:33 pm Post subject: Re: Making bubble flares |
OTC ones work fine.However, I don't think you are clamping the block on right. The block should only be tightened down once and not slide while you are forming the bubble. Some of the blocks are machined out too big and slip.OTC ones are machined a little too small and do put slight indentations in the tube. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Derek Cobb Annoying
Posted: Tue Apr 24, 2018 3:45 pm Post subject: Re: Making bubble flares |
Bubble flare is such a PITA!! You have my sympathy |
Posted: Tue Apr 24, 2018 4:49 pm Post subject: Re: Making bubble flares |
My kit is OTC brand and even it leaves some marks on the tubing. As mentioned, these marks are easily removed with a small, fine file. _________________ www.LoCashRacing.org
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Tue Apr 24, 2018 5:09 pm Post subject: Re: Making bubble flares |
Ive bought 2 of those over the years, One model, I could not make an acceptable flare, the second tool, I made 2 out of 5 ok. Helps to plan to remake lines/fittings until they come out right. All had marks also.
Anybody know what are some top quality tools to make these? I'd pay a few hundred for a good tool |
Posted: Tue Apr 24, 2018 5:39 pm Post subject: Re: Making bubble flares |
OTC is not what they were in the 80's but I have had good performance from kits on this page.
https://www.summitracing.com/search/part-type/flaring-tools?ibanner=SREPD1 _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Last edited by theKbStockpiler on Tue Apr 24, 2018 8:16 pm; edited 1 time in total |
jason Samba Member
Posted: Tue Apr 24, 2018 8:04 pm Post subject: Re: Making bubble flares |
I have the Eastwood one. Makes perfect flares without marring. They also have the AN flare die for it. Any VW people in the Southbay are welcome to use it. |
Posted: Wed Apr 25, 2018 5:39 pm Post subject: Re: Making bubble flares |
Did a little more practice this evening. Kind of getting the hang of it. Although it seems like the base of the flare is a little uneven, hopefully that doesn't affect the seal at all.
jason Samba Member
Posted: Wed Apr 25, 2018 5:46 pm Post subject: Re: Making bubble flares |
They crush, will be fine. |
Posted: Wed Apr 25, 2018 6:37 pm Post subject: Re: Making bubble flares |
Those look ideal. What did you change in your process? |
Posted: Wed Apr 25, 2018 7:01 pm Post subject: Re: Making bubble flares |
Those look good. As long as they fully engage the receptacle, you are in business. _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Apr 26, 2018 10:42 am Post subject: Re: Making bubble flares |
chrisflstf wrote: |
Filed down the end of the tubing a bit more to try to make it flat, and reamed out the opening just a bit more. Also put a little dab of oil on the die. And lastly, don't tighten the die all the way against the tubing holder. Stop just before it hits. That got me the best results do far. _________________ Joe P.
