PeteSC Samba Member
Posted: Fri Nov 02, 2018 11:20 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
^^That's fantastic! It sounds great...nice work! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Fri Nov 02, 2018 1:16 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
Better test fit in the car now to see if you have any clearance issues as was cautioned. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
MAMEDE Samba Member
Posted: Fri Nov 02, 2018 3:11 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
PeteSC wrote: |
Thanks dude!! |
MAMEDE Samba Member
Posted: Fri Nov 02, 2018 3:13 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
Mike Fisher wrote: |
Better test fit in the car now to see if you have any clearance issues as was cautioned. |
Yes, now is the next step. Put in the bus and finish the all details. |
MAMEDE Samba Member
Posted: Fri Nov 02, 2018 3:18 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
We have work a lot. We need finish the project in 20 days for go to a show here. Lets drive 2000miles with this engine in the 59 bus. I will post some pics of everything
Thanks a lot all guys!! |
MAMEDE Samba Member
Posted: Sat Nov 03, 2018 1:39 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
sled Samba Member
Posted: Sat Nov 03, 2018 4:34 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
that EMPI distributor is trash, you should REALLY find a Bosch cast distributor.
otherwise looks cool! _________________ drive your split. |
MAMEDE Samba Member
Posted: Sat Nov 03, 2018 4:48 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
I have the original Bosch but my choice is the empi because I will use the eletronic ignition. I worked with this distributor for many years. Checking everytime the point and I havent had anything |
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Fri Nov 09, 2018 3:50 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
What a beast of an engine! What's the copper line for going into the Judson?
Btw, are you hooking this up to a bus on RGB's or a different gearbox? _________________ My 1958 PGSG project topic |
PeteSC Samba Member
Posted: Fri Nov 09, 2018 7:33 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
I had those same 7mm plug wires on my engine, and had several people recommend against them saying that they arc in short time. I was having what I appeared to be firing issues (turned out to be a fuel delivery issue instead) and thought it best to replace the wires as a first step in figuring things out. Since I really liked the look of the cloth wire I bought some 8mm wire from Lowbrow Customs and made my own. It's a much more sturdy feeling wire, and so far it's performing well. The cut-to-length is a nice bonus too.
Those wires may work great for you over a long period of time, but just thought I'd share in case any issues with them came up.
Beautiful engine you've put together there!
8mm wire on left, 7mm on right.
MAMEDE Samba Member
Posted: Sat Nov 10, 2018 3:00 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
Peter_N wrote: |
Btw, are you hooking this up to a bus on RGB's or a different gearbox? |
Thanks Peter.
The copper line for Judson is for oil lubrification.
I will change the transaxel, I will put the gear box from 65, for more speed and engine life!! 🤣 |
MAMEDE Samba Member
Posted: Sat Nov 10, 2018 3:04 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
PeteSC wrote: |
Thanks Pete for your share with us. I will change when I can. Ignition problem in a Judson engine is a big problem.
Very nice engine you have. Congratulations |
brisbane6 Samba Member
Posted: Tue Nov 26, 2019 6:19 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
MAMEDE wrote: |
Looks great... How did it fit? Did you find a way to install air-cleaner? |
Braukuche Samba Member
Posted: Fri Nov 29, 2019 9:30 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
That engine sounds great! Can't wait to hear how it performs. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7182 Location: Videbaek Denmark
Posted: Thu Dec 19, 2019 4:24 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
Hello.
I can only agree, a very nice looking, - and responsive engine. You did the right thing with modifying the 1300 manifold to the 1200 based engine. That alone makes a very significant difference in engine performance and behaviure.
Wrt the Judson equipped engines running hot. There is definitely an issue, but it can be worked with. first, the charger needs to be perfect. A somewhat worn propeller or "scratched" housing can make the charger increase temps to very high levels. Next, good oil cooling and of course a proper functioning cooling system has to be. The use of a late model shroud and oil cooler helps tremendeously. You need to play a little with the fan gearing to make it good. Last thing. It is not used much, but the addition of an SVDA type distributor can help decrease especially cylinderhead temps along with better fuel efficiency uo cruise, along with even better throttle response. (That above engine does not seem to suffer from issues with throttle response though) |
D-train Samba Member
Posted: Sat Dec 28, 2019 4:07 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
MAMEDE wrote: |
New air cooled tins for 36hp
Where are these from? Any better with keeping cool? _________________ shiny paint doesnt make it worth any more |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sat Dec 28, 2019 10:37 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
Sure looks like "Cool Air" tin or what ever it's called for 1600 based engines. I'll never run that on any of my engines. I'm just surprised that someone would go to the trouble of designing it for a 36hp engine. |
Posted: Sat Dec 28, 2019 11:18 pm Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
motofly196 wrote: |
Type 3 under cylinder tin. I didn’t know they made them for 36hps. That’s why I’m inquiring. Interesting. _________________ shiny paint doesnt make it worth any more |
Posted: Tue Feb 11, 2020 2:18 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
D-train wrote: |
MAMEDE wrote: |
Where are these from? Any better with keeping cool? |
Info or a link to these? _________________ shiny paint doesnt make it worth any more |
Joined: June 24, 2015 Posts: 715 Location: Rialto. CA
Posted: Tue Feb 11, 2020 11:46 am Post subject: Re: 1959 Vintage Speed Bus - Opinions? |
D-train wrote: |
D-train wrote: |
MAMEDE wrote: |
Info or a link to these? |
I dont mind folks looking for better ideas ..i do it all the time lol ..but There has been researched in the past that those cool tins don't work for a upright engine ...but some say they work some say they don't..lots of folks say they just a marketing tool to buy when they don't really work for the upright engines...those cool tins were made for the type3 fan system...if you install these your bottom shoe box won't fit ....if you really want these you should really look into it ..if they will really be for you the performance form talks about them...i guess you really gotta try them for yourself and see how the engine runs ....i thought about putting them on a 36hp to in the past but I did research on what folks had to say but mixed reviews mostly bad so I never did make a pair for my engine but it's nice to see that someone had the same idea as I did but who knows if they really work 🤷♂️... but it's all hear say no one really has data if they work or not ..... |
