Posted: Tue Apr 24, 2018 10:52 am Post subject: Re: Guess what it is? |
ShuraVin wrote: |
Honda Accord 1994 N2S4 transmission.
The transmission rotates in the opposite direction.
I had no idea what the engine was, but that's exactly what I though you did for the gearbox. Nice job! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6349 Location: Honolulu,Hawaii and France
Posted: Tue Apr 24, 2018 10:55 am Post subject: Re: Guess what it is? |
I sometimes lurk via Google image on what they do in Russia on Vanagons, these guys have skills!! Poland is a great place for swaps as well. It's usually hard to stumble across these threads but they're out there
Nice job! Looks fun
http://fanclub-vw-bus.ru/forum/viewtopic.php?f=43&t=23203 _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
ShuraVin Samba Member
Posted: Tue Apr 24, 2018 10:57 am Post subject: Re: Guess what it is? |
bobbyblack wrote: |
Watch that coolant hose passing under the cut-off section of bulkhead at the front of the engine bay. That would turn a good day to bad if it chaffed through.
-bobby |
The gap is sufficient. Distortions on the photo. |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Tue Apr 24, 2018 10:58 am Post subject: Re: Guess what it is? |
Is there a 4WD Honda gearbox that can be used? _________________
....KTMs, GasGas, SPOT mtb |
E1 Samba Member
Joined: January 21, 2013 Posts: 6532 Location: Westfalia, Earth
Posted: Tue Apr 24, 2018 11:08 am Post subject: Re: Guess what it is? |
Very interesting conversion... Cool.
And, Welcome! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10371 Location: Sunshine Coast B.C.
Posted: Tue Apr 24, 2018 11:17 am Post subject: Re: Guess what it is? |
ALIKA T3 wrote: |
http://fanclub-vw-bus.ru/forum/viewtopic.php?f=43&t=23203 |
edit:
I meant to include this:
the list below indicates a lot of dedication and determination! Thanks for sharing. end of edit.
https://translate.google.ca/translate?sl=auto&...mp;act=url
"1. The stove. Coaxiality of the crankshaft with the primary shaft of the gearbox is 0.025mm. 4hours
2. Spacer under the flywheel. Manufacturing from one installation. The accuracy is + -0,003. 5 o'clock
3. Bolts of a flywheel. 10 hours
4. Remaking the clutch disc. 3 hours.
5. Flywheel rail.20min
6. Making a new squeeze out, by crossing the Hondo with a renamed .5 clock
7. Manufacturing of the starter housing.10 hours
8. Manufacturing of an arm to support the starter shaft for 15 hours.
9. Manufacturing of a bracket of the gauge of position коленвала. 2 hours.
10. Adapter from the transmission to the left half-axle. 5 hours
11. Adapter from the gearbox to the right axle shaft. 15 hours.
12. Centering conductors of axle shafts and their welding .25 hours
13. Motor brackets. hours for 15 for each
14. Bulkhead checkpoint. 20 hours
15. The shift switch. Hours 20
16. The pallet. 30 hours
17. Remaking oil intake. 3 hours
18. Exhaust. 2 hours. Probably the most simple.
19. The air filter. 5 o'clock
20. Cooling system. 20 hours
21. Installation of the "foreign" master cylinder of the clutch. 6 hours
22. Posting 20 hours. " _________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN
Posted: Tue Apr 24, 2018 11:40 am Post subject: Re: Guess what it is? |
ALIKA T3 wrote: |
Beautiful and high-tech solutions in America more. As an example of SUBARUGEARS.
In this project I want to get joy from creativity. Everything is made from spare parts that are available. As they say in Russia "
made of feces and scotch tape"
There is a workshop with a lathe, a milling machine. All kinds of welding. It helps a lot.
We do not have such machines in good condition. Very heavy operating conditions. This Vanagon looked for a very long time. |
metropoj Samba Member
Posted: Tue Apr 24, 2018 12:07 pm Post subject: Re: Guess what it is? |
ShuraVin, Welcome and thanks for posting your progress.
This is very impressive work and your English is better than most of our English lol.
I look forward to seeing more of your project as you work on it. _________________ John.
86 TiiCo powered Westy. |
Posted: Tue Apr 24, 2018 12:10 pm Post subject: Re: Guess what it is? |
ShuraVin wrote: |
ALIKA T3 wrote: |
Creativity often comes from the need. You are a pionneer and it is very interesting to see these kind of ingenous builds.
Aloha! _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Gizmoman Samba Member
Joined: September 10, 2011 Posts: 1554 Location: Nevada
Posted: Tue Apr 24, 2018 1:10 pm Post subject: Re: Guess what it is? |
Nice job - lots of creative genius there. _________________ 82 Vanagon Westy - AAZ 1.9 TD, HE200 Holset, WAIC, 27.75 dia tires, Electric power steering, 5-speed AAP w/.078 5th
Oversize spare carrier - stock location (no longer for sale). |
Gauche1968 Samba Member
Posted: Tue Apr 24, 2018 1:30 pm Post subject: Re: Guess what it is? |
An engine that is going to fall out when it hits its first Russian pothole? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
Posted: Tue Apr 24, 2018 1:31 pm Post subject: Re: Guess what it is? |
metropoj wrote: |
The merit of my "English" is entirely owned by GoogleTranslate.
Unfortunately there is not enough communication with native speakers. |
Posted: Tue Apr 24, 2018 1:40 pm Post subject: Re: Guess what it is? |
Gauche1968 wrote: |
An engine that is going to fall out when it hits its first Russian pothole? |
You're right. Unfortunately in our country there are still bad roads. But recently they have greatly improved. Or I will learn not to drive on potholes. Or I'll wait when all the roads are perfect. Do you think what option will suit me? |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Tue Apr 24, 2018 2:57 pm Post subject: Re: Guess what it is? |
ShuraVin wrote: |
Sorry for my english.
As long as you're really sorry I guess it's ok. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Tue Apr 24, 2018 3:29 pm Post subject: Re: Guess what it is? |
Many thanks. You know how to give optimism. |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2753 Location: San Luis Obispo, CA
Posted: Tue Apr 24, 2018 3:43 pm Post subject: Re: Guess what it is? |
So... Does that trans rotate that way from the factory or did something get flipped to rotate in the right direction?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Apr 24, 2018 4:00 pm Post subject: Re: Guess what it is? |
Samba is starting to freak me out a little bit today...
- Dave
PS: Welcome! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Tue Apr 24, 2018 4:09 pm Post subject: Re: Guess what it is? |
hdenter wrote: |
Hans |
Of course not. On old Honda engines had a left rotation. Primary shaft, too. Now the motor and the primary shaft have a right rotation. |
Posted: Tue Apr 24, 2018 8:56 pm Post subject: Re: Guess what it is? |
How was the transmission rotation changed? Did you flip the ring gear? That motor is not likely easy to find here, but that trans is bound to be fairly common. If it is easy to flip, a lot of people might look more.closely at using inline four swaps.
How strong is that trans? Hondas are pretty light. Can that trans handle both higher horsepower and a much heavier load than it was designed for?
'84 sunroof vanagon
'85 weekender |
Paulbeard Samba Member
Posted: Tue Apr 24, 2018 9:02 pm Post subject: Re: Guess what it is? |
tencentlife wrote: |
I've been waiting for someone to show off a front-engine transverse engine/driveline unit packed in the back of a van, it's always seemed to me to be so much more elegant an approach to conversion than cobbling different engines to the stock transaxle with all its limitations. |
Me too…seems like there are a lot of unexplored options there. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
