ELFRIED Samba Member
Posted: Tue Apr 24, 2018 9:15 am Post subject: Dismantling |
did do a lot of work lately
motor out
all glass out
headliner out
whole interior out
steering wheel out
all the bolts that hold the chassis to the fame out -went remarkable smoothly
chassis now loose and lifted it a bit up
and off course here some questions
- is it normal they used nails to fasten trims rubbers etc...
- removed the mud plates looks as we smuggled some American soil into Europe
this is how it looked inside normal?
this is a bad piece of rocker the rest looks fine and I can see the inside heater channel looks pretty good , how to check the rest of the heater channel?
the dash looks pretty good except one place
is this possible to fix?
next making a dolly and begin to fix the new pans in.... |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1031 Location: Jacksonville, FL
crocteau Samba Member
Joined: March 31, 2005 Posts: 1203 Location: Philaburbia
Posted: Tue Apr 24, 2018 10:45 am Post subject: Re: Dismantling |
ELFRIED wrote: |
- is it normal they used nails to fasten trims rubbers etc... |
Yes. For example these are the original tacks that were used to anchor the lower end of the rear windlace in my '71 cabriolet.
Here's a photo before countersinking the screws I used to replace the tacks.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32433 Location: Reading Pennsylvania
The aussie Trimmer Samba Member
Joined: July 05, 2006 Posts: 385 Location: Western Australia
Posted: Wed Apr 25, 2018 2:14 am Post subject: Re: Dismantling |
When I was a young apprentice, they were called Drive Nails; and yes we drove thousands of them through the floor pans to hold the carpets down, now I look back and cringe thinking about all the rust I was guilty of inflicting on owners cars, _________________ Cheers,
Kev.
Drive with your lights on (Be aware be seen) help others GIVE Blood |
Posted: Thu Apr 26, 2018 1:52 am Post subject: Re: Dismantling |
ok so the nails are correct
now how to remove them?
and what to use instead or re use them?
difficult I think because the opening will be to wide no? |
