nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Apr 25, 2018 1:19 pm Post subject: Split beetle accessory brake light and flasher wiring challenge |
I'm working on a friends 52 split window project. He previously had a very unique neon rear brake light that operated in concert with the usual popes nose brake light.
He wants to convert the neon lights to also flash as independent turn signals.
The pieces of the system I currently have are two separate pieces of neon glass (that light up red), a 6V to 12V inverter, and a 12V power supply for neon signs.
Currently this setup will light up both neon tubes when the car brakes are applied.
What I want to do is continue to have both light up with the brake pedal, but change it so the left lights up with the left turn and the right with the right turn. Semaphores will only raise and light up, no flashing.
Ideally the neon brake light will be on continuously on one side and flash on the other when turning, and both will light up when only braking.
I'm wondering if anyone can help me with the proper wiring and power supply(s) I will need to get this working?
Here's how the original setup worked
Here's all the components I believe will be involved in making the changes.
consvws Samba Member
Joined: April 07, 2009 Posts: 950 Location: Roseburg, OR
Posted: Wed Apr 25, 2018 2:59 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
can you use a later 6 wire turn signal switch? Assuming you are using a 3-wire switch now. |
Posted: Wed Apr 25, 2018 4:29 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
consvws wrote: |
It's a semaphore switch on the dash not the steering column.
So no |
busdaddy Samba Member
Posted: Wed Apr 25, 2018 5:04 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Sounds to me like a job for a separate signal to combined brake/signal trailer light converter box and 2 flashers, one in each sides circuit leading to the box. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Wed Apr 25, 2018 9:18 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
*Edited _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Thu Apr 26, 2018 5:59 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
_________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc |
Posted: Thu Apr 26, 2018 11:26 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Thanks caleb0101
One thing I forgot is the semaphore indicator. Where would that be wired?
And would your drawing result in flashing semaphores or normal operation?
I need them to operate normally (no flasing). |
Posted: Thu Apr 26, 2018 11:31 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
nlorntson wrote: |
Thanks caleb0101
Semaphores would work like they do now and the indicator stays the same as it is now _________________ Ruby red 1967 beetle sedan with a 2021cc
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Thu Apr 26, 2018 6:13 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
I acquired this 1950 standard on a 1972 pan, titled as a '72 in 1978... the state of NJ made me install functioning signals and EMERGENCY FLASHERS. I went to a NAPA store, bought that whole kit, for an old hot rod upgrade... installed snow flakes and used the front parking lights too...
I left the switch in the dash center for the semaphores and added a stalk switch on the column... was real easy to do.
Later, I bought a 1950 title and removed all that modern BS and ran just semaphores... do the same today, in 2018 with my early oval... just semaphores.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sat Apr 28, 2018 7:02 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Thanks zen
The friend wants to stay stock so nothing on the steering column.
I've collected most of the parts I think I need and hope to prototype it all this weekend.
First though, I need to get a malfunctioning turnsignal sorted out in my SO44.
Did I mention how much I don't enjoy electrical problems? Wish me luck. |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Sat Apr 28, 2018 7:53 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Wow! ... Is this so the ISS will be able to tell when the brakes are applied?
j/k ... kinda neat actually.
I suppose I shouldn't laugh... As I've actually thought about making a set of LED tubes to fit behind the 3 longest steel vent lines on either end of my ovals rear vents. _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
EVfun Samba Member
Posted: Sun Apr 29, 2018 1:42 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
I used to do neon work, so I love this!
A good basic setup was presented already by Calab. I'd only add that each flasher may need its own load relay to make it flash and/or the the converter box function (some of those trailer boxes need to "see" bulbs on the flasher to work.)
Also, is the Bug going to be 6v or 12v? I don't know if any of the trailer converters will work on a 6v. It wouldn't be hard to hand roll a system on a solderable breadboard that would take the inputs (power, signal L, signal R, brake) and roll them into 2 relay outputs to drive the 2 neon power supplies.
You will need 2 neon power supplies as shown, the high voltage that drives a neon tube makes normal transistor or relay switching impossible on the output side There are old-school parts that could do that but they are large and use considerable switching power. _________________
Wildthings wrote: |
Posted: Sun Apr 29, 2018 3:04 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
EVfun...
Car will be 6V
Trailer flasher - I have one on my 62 beetle (also 6v) for my single wheel trailer lighting so it seems to work just fine there.
Neon power supply- yes, two power supplies so the neon can run independently. Each will take the 12v DC and con vert to 5000V AC
6V DC to 12V DC step up to power the neon PS - I'm leaning towards two of these also. I'm not sure what Amp output I'll need if I go with one versus two.
Any ideas? |
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Tue May 01, 2018 12:59 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
That's one very cool idea!
Pretty cool actually that the light units are arrow shaped like the split window.
It cannot get more clear than this for the person behind you.
Any picture from the rear already? What color are the tubes when not switched on? _________________ My 1958 PGSG project topic |
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 491 Location: behind the wheel
Posted: Tue May 01, 2018 11:21 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Peter_N wrote: |
Any picture from the rear already? What color are the tubes when not switched on? |
They are simply clear glass (neon-filled) which lights up red when on.
I'm looking forward to the finished results.
Thanks everyone for your input and suggestions on this puzzler.
Final completed photos will be posted and shared.
-Grant
_________________ 1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water |
Posted: Fri May 04, 2018 8:07 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
I THINK we have the electrical portion of this project sorted out. I hope to do a mock up of the system in the next days.
Now, what suggestions does anyone have for attaching the neon to the car?
As you can see in the picture above, the neon is slightly smaller than the opening.
The previous installation tried using double stick tape, little plastic wiring clips, and zip ties. You can see some if it still attached to the neon tubes.
This worked for a while, but the heat and vibration caused the clips to become unstuck from the glass and it really didn't look very nice.
The neon cannot be glued directly to the glass because of the high voltage.
So what ideas are out there for holding the neon tubes? It will be another few days before the car leaves for the paint shop.
Thanks all! |
Posted: Fri May 04, 2018 10:36 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Custom bent clips that look like a question mark without the dot that tuck in between the glass and rubber seal? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat May 05, 2018 7:49 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
if you can post up some dimensions and better pictures of the neon tubes i might be able to design something for you _________________ Ruby red 1967 beetle sedan with a 2021cc
Posted: Sat May 05, 2018 8:16 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
I'm not sure what the dimensions you need might be. The neon tube is 8mm diameter.
You can see where the seal sits on the glass.
Posted: Sun May 06, 2018 1:22 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
nlorntson wrote: |
Thanks zen
I know here in Tulsa there are electrical mechanic shops... they'll figure it out, to meet your desires... just might cost you... The guy in town here has a kinda' big nose and nicknamed Gonzo. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
