nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Sun May 06, 2018 5:51 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
I hooked up the old electronics just to be sure the neon portion was still working. It's pretty cool!
My plan is to mock up all the components together and then figure out where I want to mount everything.
The flashers I'm using have a tone when they flash so hopefully the owner will not be one of "those" split owners that drive around with the semaphore out for miles |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Sun May 06, 2018 8:45 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
"I've never done that!!!" _________________ John Henry
'57 Deluxe
'56 Single Cab |
sled Samba Member
Posted: Sun May 06, 2018 8:52 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
nlorntson wrote: |
does that happen to people who don't have the red 'idiot' light on the dash indicating the semaphore is still up?
that red light always freaks me out, thinking the belt came off and Im about to fry my 25hp! Definitely don't leave the turn signals on... _________________ drive your split. |
Posted: Wed May 09, 2018 9:15 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
sled wrote: |
nlorntson wrote: |
that red light always freaks me out, thinking the belt came off and Im about to fry my 25hp! Definitely don't leave the turn signals on... |
You'd be surprised. I have driven splits for decades and am *totally* embarrassed when I realize that I have driven with a sem out in spite of the fact that that red light is on. Somehow it escapes the periphery....... _________________ John Henry
'57 Deluxe
'56 Single Cab |
sled Samba Member
Posted: Wed May 09, 2018 9:26 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
johnshenry wrote: |
sled wrote: |
nlorntson wrote: |
You'd be surprised. I have driven splits for decades and am *totally* embarrassed when I realize that I have driven with a sem out in spite of the fact that that red light is on. Somehow it escapes the periphery....... |
scary! what does that mean if your generator light is on? _________________ drive your split. |
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 491 Location: behind the wheel
Posted: Wed May 09, 2018 10:54 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
johnshenry wrote: |
"I've never done that!!!" |
Well, I certainly have.
Maybe this new setup will help w/ that.
I'm super psyched to have it all dialed in and letting those trailing me know I'm stopping.
Thanks for the test teaser and all your efforts on this Nancy! Carry on.
Grant _________________ 1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water |
René R. Samba Member
Joined: July 06, 2015 Posts: 1711 Location: No. Calif.
Posted: Thu May 10, 2018 7:54 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
A suggestion for the warning lights in the dash -- change to LED bulbs. Those suckers are bright! They're hard to miss. _________________ Gone but not forgotten: 1950 Hoffman split (restored in 1966) - another 1950 Hoffman split (restored in 1996) |
Posted: Tue May 22, 2018 7:44 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
So I've been playing around with this set up. I've got it wired up as shown
But it doesn't work.
I can connect 6V directly to the 6V to 12V step up and the neon works on both sides.
I can add a flasher inline on the + side and then into the step up, and it flashes (albeit way too fast so I need to figure out a different flasher).
As soon as I put the 3-->2 converter between the flasher and the step up, I get nothing at the neon. I actually get nothing through the converter.
I have all the grounds connected to the - side of the power input.
I'm using a bench power supply so I can set the incoming voltage to 6V
I was expecting that power in on one side of the converter should show power out on the same wire on the other side, but nothing. I checked OhMs through the converter and also get nothing. I compared these results to one working on a friends car and they are the same so the converter is OK, I just don't have something connected properly
I have not connected both sides and the brake at the same time. Maybe I need to?
I have not tried to input + on the brake circuit
What am I missing here? How does the converter work so power goes out to a light? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51128 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 22, 2018 9:01 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Unless I'm missing something it looks like you are attempting to power a whole lotta 12v stuff with 6 v, the tail light converter will likely need 12v.
You may have to move the 6-12v converters to the wires between the semaphores and the flashers (if those are 12v flashers). The fast flash might be due to the load from the converters etc.. they are meant for 2 bulbs, you might need heavy duty flashers for use with trailers as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні!
Posted: Tue May 22, 2018 9:04 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
busdaddy wrote: |
Unless I'm missing something it looks like you are attempting to power a whole lotta 12v stuff with 6 v, the tail light converter will likely need 12v |
It's all 6v to the step up which converts it to 12v for the neon power supply.
Trailer converter doesn't care if it's 6v or 12v from what I read. |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Thu May 24, 2018 4:58 am Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
busdaddy wrote: |
move the 6-12v converters to the wires between the semaphores and the flashers (if those are 12v flashers). |
try this along with removing the flashers and testing the left, right, and brake functions with out the flashers _________________ Ruby red 1967 beetle sedan with a 2021cc
1967 beetle sedan baja project
April 60 euro spec ragtop beetle with a 1641cc |
Posted: Thu May 24, 2018 6:44 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
I made some progress on this project. I've got two problems to solve.
The first is the trailer converter to get my neon lights working as both brake and turns. The second is the step up and neon power supply appear to need a minimum of 4.4V input to be able to light the neon.
Upstream from that is a trailer converter that seems to need some amount of resistance from an incandescent bulb on the car side in order to work and send the flasher signal through to the trailer side (power step up).
If I connect incandescent bulbs to emulate trailer lights rather than the step up and neon power supply, I get flashing lights.
So I think what my problem is insufficient current in the right places.
From what I read there are trailer converters that work with LED lights maybe that would help?
Another idea might be to move the step up further upstream.
EDIT: I think that is what Caleb010 is suggesting so I'll try that next. |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Thu May 24, 2018 7:44 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Main question: Why?
Also, why not go 12 volt? _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Posted: Fri May 25, 2018 1:37 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Splitdog wrote: |
Main question: Why?
Also, why not go 12 volt? |
Why not.
Owner wants it to stay 6V. |
EVfun Samba Member
Posted: Fri May 25, 2018 3:35 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
Is this split going to have front turn signals?
This looks like a situation where 2 relays would do the job better than a trailer converter. The relay coil would be operated by the dash semephore switch (1 left, 1 right) along with the semephores. The normally closed contacts would be connected to the brake lights. The normally open contacts would be connected to a flasher. The switching contacts would be connected to the neon transformers.
Scew 12 volts, I've never bothered to convert an old Bug and with modern electronics the reasons to do so are less than ever. _________________
Wildthings wrote: |
Posted: Fri May 25, 2018 4:48 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
EVfun wrote: |
This looks like a situation where 2 relays would do the job better than a traier converter. The relay coil would be operated by the dash semephore switch (1 left, 1 right) along with the semephores. The normally closed contacts would be connected to the brake lights. The normally open contacts would be connected to a flasher. The switching contacts would be connected to the neon transformers.
Scew 12 volts, I've never bothered to convert an old Bug and with modern electronics the reasons to do so are less than ever. |
No front turns. Just the neon turn/brake lights in the split windows |
Posted: Fri May 25, 2018 4:56 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
EVfun wrote: |
Scew modern electronics, I've never bothered to convert an old Bug and with 12 volts the reasons to do so are less than ever. |
Fixed it. To each their own..... _________________ CH³NO²
Z = z² + C
#notacallooker |
EVfun Samba Member
Posted: Fri May 25, 2018 5:24 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
To each their own, but let me explain...
With the popularity of USB powered devices there is a lot of stuff that operates on just 5 volts, often at 1 amp or less. Many bluetooth devices are just 3.3 volt inside. LEDS use a lot less current than incandescent bulbs, though you may have to roll your own. There are modern electronics available, and many of them where designed to run on small, low voltage, rechargeable batteries! _________________
Wildthings wrote: |
Posted: Fri May 25, 2018 6:17 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
That is true. I always like to be as close to stock as possible. (even though I have a lowered, turbocharged split). Lol. But 12 volting gives a lot of advantages and still appears stock. On vintage cars LED's have a look that doesn't look vintage. Like 17" wheels, modern sound systems, etc. But again, to each their own. I have seen a lot of modification in my day. At some point, I just jump in my 7 series and go to Vegas. With air, bluetooth, at 90 mph, etc. _________________ CH³NO²
Z = z² + C
#notacallooker |
Posted: Fri May 25, 2018 6:35 pm Post subject: Re: Split beetle accessory brake light and flasher wiring challenge |
nlorntson wrote: |
I'd consider adding a bulb to each circuit to provide a load, bury them somewhere in a box or under the back seat out of sight, just a thought to move this project along _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
